查看: 3250|回复: 0
MNS[原创]
发表于 2002-6-7 15:16:00 | 显示全部楼层 |阅读模式
[实用菜单&O]
ID_mypaper     [插入图框]^C^C^P(if (null B_DRAWING) (load "B_DRAWING")) (B_DRAWING) ^P
ID_mypaper_d   [修改属性]^C^C_ddatte
ID_mylay_o_o_a [->图层管理]
ID_mylay_o_o_a   [打开所有层]^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "5") ^P
ID_mylay_o_o_a   [只开目标层]^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "1") ^P
ID_mylay_o_o_a   [<-关闭目标层]^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "2") ^P
ID_mylay_o_o_a [到目标层]^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "4") ^P
ID_mylay_o_o_a [改变线层]^C^C^P(if (null B_CHANGE) (load "B_CHANGE")) (B_CHANGE) ^P
ID_mycenter    [中心线]^C^C^P(if (null B_CIRCLINE) (load "B_CIRCLINE")) (B_CIRCLINE) ^P
ID_myccd_y     [加工光洁度]^C^C^P(if (null B_BASE) (load "B_BASE")) (B_BASE "Y") ^P
ID_myccd_n     [未加工光洁度]^C^C^P(if (null B_BASE) (load "B_BASE")) (B_BASE "N") ^P
ID_mybase      [基准符号]^C^C^P(if (null B_BASE) (load "B_BASE")) (B_BASE "B") ^P
ID_mym_l       [内螺纹]^C^C^P(if (null B_WHORL) (load "B_WHORL")) (B_WHORL "I") ^P
ID_mym_w       [外螺纹]^C^C^P(if (null B_WHORL) (load "B_WHORL")) (B_WHORL "E") ^P
ID_mynut       [内六角园柱头螺钉]^C^C^P(if (null B_SCREW_COLUMN) (load "B_SCREW_COLUMN")) (B_SCREW_COLUMN) ^P
ID_mynut       [螺母]^C^C^P(if (null B_NUT) (load "B_NUT")) (B_NUT) ^P
ID_sprocket    [链轮]^C^C^P(if (null B_SPROCKET) (load "B_SPROCKET"))(B_SPROCKET) ^P
ID_technology  [技术要求]^C^C^P(if(null B_TECHNOLOGY_REQUIRE) (load "B_TECHNOLOGY_REQUIRE")) (B_TECHNOLOGY_REQUIRE) ^P
GMT+8, 2026-1-21 04:29 , Processed in 0.153612 second(s), 25 queries , Gzip On.
