楼主: 半听可乐
5币求画线截断直线程序,要源码
发表于 2012-7-6 17:55:08 | 显示全部楼层
(defun c:jd()
(setq pt1 (getpoint "\n指定第1点:"))
(setq pt2 (getpoint pt1 "\n指定第2点:"))
(setq pt3 (getpoint "\n指定第3点:"))
(grdraw Pt1 pt2 1)
(command "line" pt1 pt2 "")
(setq tg (entLast))
(command "trim" tg "" "f" pt1 pt3 pt2 "" "")
(entdel tg)
 楼主| 发表于 2012-7-7 00:08:23 | 显示全部楼层
hao3ren 发表于 2012-7-6 17:55
(defun c:jd()
非常感谢!但还有bug:当截断多条线时有些线截断不了,还没找到规律性~~望好人继续完善
发表于 2012-7-7 01:18:40 | 显示全部楼层
  1. (defun c:QTR ( / a ang ce cm ent obj op p1 p2 p3 p4 p5 sset)
  2.   (defun *error* (msg)
  3.     (setvar "osmode" a)
  4.     (command "undo" "e")
  5.     (setvar "CMDECHO" CM)
  6.     (setvar "CECOLOR" CE)
  7.     (if (and
  8.           msg
  9.           (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,*EXIT*,"))
  10.         )
  11.       (princ)
  12.     )
  13.   )
  14.   (setq a (getvar "osmode"))
  15.   (setq CM (getvar "CMDECHO"))
  16.   (setq CE (getvar "CECOLOR"))
  17.   (setvar "CMDECHO" 0)
  18.   (SETVAR "CECOLOR" "1")
  19.   (command "undo" "be")
  20.   (cond
  21.     ((vl-cmdf "_.line" (setq p1 (getpoint "\n指定第一点: "))
  22.               (setq p2 (getpoint p1 "\n指定第二点: "))
  23.               ""
  24.      )
  25.       (setq ent (entlast))
  26.       (setq p3 (getpoint "\n点击修剪边: "))
  27.       (setq obj (vlax-ename->vla-object ent))
  28.       (setq op (vlax-curve-getclosestpointto obj p3))
  29.       (setq ang (angle op p3))
  30.       (setq p4 (polar p1 ang 1))
  31.       (setq p5 (polar p2 ang 1))
  32.       (setq sset (ssget "_f" (list p1 p2)))
  33.       (command "_.trim" sset "" "f" p4 p5 "" "")
  34.       (command "_.erase" ent "")
  35.     )
  36.   )
  37.   (setvar "osmode" a)
  38.   (setvar "CMDECHO" CM)
  39.   (setvar "CECOLOR" CE)
  40.   (command "undo" "e")
  41.   (princ)
  42. )
 楼主| 发表于 2012-7-7 12:10:43 | 显示全部楼层
Gu_xl 发表于 2012-7-7 00:54
[/post]
G版出马,什么都是浮云,哈哈,对我来说功能非常完美了,谢谢!
 楼主| 发表于 2012-7-7 19:57:02 | 显示全部楼层
Gu_xl 发表于 2012-7-6 15:57
[/post]
奇怪,我的回复怎么看不见~~这么好的程序,我得再三感谢G版了,非常完美,感谢感谢!
发表于 2012-7-9 08:54:03 | 显示全部楼层
G版出手,非常感谢
发表于 2012-7-9 09:22:48 | 显示全部楼层
[/post]
测试在确定第二点时,不能捕捉。
发表于 2012-7-9 09:25:28 | 显示全部楼层
[/post]
G版出手,不同凡响,顶!
发表于 2012-7-10 07:55:42 | 显示全部楼层
学学,看看,长见识
发表于 2012-7-10 10:05:04 | 显示全部楼层
G大侠的程序不错,只是捕捉第二点时最好还是有交点、垂足、最近点之类的带选择性更好。你的F8,F3选择不太适用。
同感啊,有人修正就好了  发表于 2012-7-11 08:54
GMT+8, 2026-1-8 20:36 , Processed in 0.166768 second(s), 22 queries , Gzip On.
