楼主: 半听可乐
求贱人工具箱里【文字表格居中】程序源码
发表于 2020-6-18 22:42:09 | 显示全部楼层
这个功能很强大
发表于 2023-1-17 09:05:06 | 显示全部楼层
这个支持文字 实体
;对象居中:by zml84 2009-06-15 此基础上修改:by 忘霄
(defun C:EC (/ box en_tmp ent i pt0 pt1 ss tmp)
  (setvar "CMDECHO" 0)
  (vl-load-com)
  (princ "\n选择需要居中的对象:")
  (if (setq ss (ssget))
      (defun box (e / ll ur)
        (vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur)
        (mapcar 'vlax-safearray->list (list ll ur))
      (setq i -1)
      (command "undo" "be")
      (while (setq ent (ssname ss (setq i (1+ i))))
        (setq tmp (box ent))
        (setq tmp (mapcar '+ (car tmp) (cadr tmp)))
        (setq pt0 (mapcar '* tmp '(0.5 0.5 0.5)))
        (entdel ent)
        (setq en_tmp (bpoly pt0))
        (entdel ent)
        (setq tmp (box en_tmp))
        (setq pt1 (mapcar '* tmp '(0.5 0.5 0.5)))
        (command "move" ent "" "non" pt0 "non" pt1)
        (entdel en_tmp)
      (command "undo" "e")
    (princ "\n没有选择对象!")
发表于 2024-6-27 18:38:28 | 显示全部楼层
谢谢各位大佬的无私分享
GMT+8, 2026-1-14 01:10 , Processed in 0.164885 second(s), 19 queries , Gzip On.
