查看: 1767|回复: 5
捕捉的设置
发表于 2012-8-1 21:19:55 | 显示全部楼层 |阅读模式
请问如何将下面这段代码修改为:复制前为插入点捕捉,复制完成后修改为后面那种捕捉方式。谢谢。
(DEFUN C:CZ ()
(command "osnap" "INS" )
(COMMAND "COPY"  (ssget) "")
(command "osnap" ",END,MID,INT,EXT,APP,CEN,NOD,QUA,PER,TAN,NEA,PAR")
(PRINC))
发表于 2012-8-1 21:33:31 | 显示全部楼层
(DEFUN C:CZ ()
   (SetVar "OsMode" 64 )
   (while (= (logand (getvar "CmdActive") 1) 1) (command pause))
   ;; (command "osnap" ",END,MID,INT,EXT,APP,CEN,NOD,QUA,PER,TAN,NEA,PAR")
   (SetVar "OsMode" (+ 1 2 ....))  ; Ref OsMode 系统变量  / http://bbs.mjtd.com/thread-95818-1-1.html
   (PRINC)
 楼主| 发表于 2012-8-2 10:04:46 | 显示全部楼层
上面的代码只能复制一次,要怎么修改才能复制多次呢?
发表于 2012-8-2 22:06:46 | 显示全部楼层
Andyhon 发表于 2012-8-1 21:33
(DEFUN C:CZ ()
学习了~~
发表于 2012-8-2 22:22:04 | 显示全部楼层
...复制多次...
(COMMAND "COPY"  (ssget) "" "M")
GMT+8, 2026-1-20 05:15 , Processed in 0.208048 second(s), 25 queries , Gzip On.
