查看: 1747|回复: 4
注册键根未知
发表于 2012-9-29 14:22:38 | 显示全部楼层 |阅读模式
(defun c:hh()
(setq f(open "F:\昌立线束软件/gx.reg" "W"))
(write-line "Windows Registry Editor Version 5.00" f)
(write-line "" f)
   (write-line "[HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R17.1\\ACAD-6001:804\\Profiles\\<<未命名配置>>\\Dialogs\\Appload\\Startup]" f)
   ;(write-line "\"forceguest\"=dword:00000000" f)
(write-line "\"NumStartup\"=\"2\"" f)
   (write-line "\"1Startup\"=\"F:\\\\昌立线束软件[url=]\\\\bom.lsp\[/url]"" f)
   (write-line "\"2Startup\"=\"F:\\\\昌立线束软件[url=]\\\\EF_Library.lsp\[/url]"" f)
   (write-line "" f)
   (close f)
  (vl-registry-write "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6001:804\Profiles\<<未命名配置>>\Dialogs\Appload\Startup" "forceguest" 0)
;(startapp "regedit.exe" "gx.reg")
执行这个代码的时候提示:注册键根未知
请各位大师帮我看看问题出在什么地方了
发表于 2012-9-29 15:17:58 | 显示全部楼层
不确定合汝原意...
  1. (defun c:hh ()
  2.   (setq f (open "F:\昌立线束软件/gx.reg" "W"))
  3.   (write-line "Windows Registry Editor Version 5.00" f)
  4.   (write-line "" f)
  5.   (write-line
  6.     "[HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R17.1\\ACAD-6001:804\\Profiles\\<<未命名配置>>\\Dialogs\\Appload\\Startup]"
  7.     f
  8.   )
  9.   ;; (write-line ""forceguest"=dword:00000000" f)
  10.   (write-line ""NumStartup"="2"" f)
  11.   (write-line
  12.     ""1Startup"="F:\\\\昌立线束软件[url=]\\\\bom.lsp\[/url]""
  13.     f
  14.   )
  15.   (write-line
  16.     ""2Startup"="F:\\\\昌立线束软件[url=]\\\\EF_Library.lsp\[/url]""
  17.     f
  18.   )
  19.   (write-line "" f)
  20.   (close f)
  21.   (vl-registry-write
  22.     "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6001:804\Profiles\<<未命名配置>>\Dialogs\Appload\Startup"
  23.     "forceguest"
  24.     0
  25.   )
  26.   ;; (startapp "regedit.exe" "gx.reg")
  27. )
 楼主| 发表于 2012-9-29 15:19:06 | 显示全部楼层
Andyhon 发表于 2012-9-29 15:17
不确定合汝原意...
谢谢大哥!!我测试一下
 楼主| 发表于 2012-9-29 15:20:12 | 显示全部楼层
dcl1214 发表于 2012-9-29 15:19
谢谢大哥!!我测试一下
命令: hh
; 错误: 注册键根未知:
"HKEY_CURRENT_USERSoftwareAutodeskAutoCADR17.1ACAD-6001:804Profiles<<未命名配置>>Dial
ogsApploadStartup"
命令:
还是这个提示啊
发表于 2012-9-29 15:50:10 | 显示全部楼层
GMT+8, 2025-5-23 17:58 , Processed in 0.190563 second(s), 30 queries , Gzip On.
