楼主: 取则行远12
圆中的文字怎么输出?
发表于 2013-3-24 09:23:56 | 显示全部楼层
[post=5]
  1. (defun c:tt ()
  2. (setq fn (if (= (type fn) 'STR) fn ""))
  3. (setq fn (getfiled "输出文件名" fn "txt" 4))
  4. (if (setq ss (ssget '((0 . "CIRCLE") (40 . 5.0)))) (progn
  5.   (setq i -1)
  6.   (setq fp (open fn "w"))
  7.   (repeat (sslength ss)
  8.    (setq pc (cdr(assoc 10 (entget(ssname ss (setq i (1+ 1))))))
  9.          p1 (mapcar '+ pc (list 5 5))
  10.          p2 (mapcar '- pc (list 5 5)))
  11.    (if (= (sslength(setq ss1 (ssget "C" p1 p2 '((0 . "TEXT"))))) 2) (progn
  12.     (setq ent1 (entget(ssname ss1 0)) ent2 (entget(ssname ss1 1))
  13.           pt1 (cdr(assoc 10 ent1))    pt2 (cdr(assoc 10 ent2)))
  14.     (if (> (cadr pt1) (cadr pt2))
  15.      (princ (strcat(cdr(assoc1 1 ent1)) (cdr(assoc 1 ent2))) fp)
  16.      (princ (strcat(cdr(assoc1 1 ent2)) (cdr(assoc 1 ent1))) fp)
  17.     )
  18.    ))
  19.   )
  20.   (close fp)
  21. ))
  22. (princ)
  23. )
[/post
发表于 2013-5-9 15:38:23 | 显示全部楼层
Z版好程序,今天才看到!
发表于 2013-7-12 00:06:56 | 显示全部楼层
Z版好程序,好久出手一回,学习中
发表于 2013-7-28 16:10:31 | 显示全部楼层
版主的程序略做改造,也可以输出到word
发表于 2013-7-29 08:43:04 | 显示全部楼层
(defun wbdc_defun        ()
  (defun wbdc_set        (se)                        ;将文本实体选择集转换为含实体名的表
    (setq l1   (sslength se)
          i    0
          set0 nil
    (repeat l1
      (setq e0         (ssname se i)
            set0 (cons e0 set0)
            i         (1+ i)
  (defun wbdc_sorten (se axis)                ;实体按x、y排序
    (setq ss   nil
          sexy (mapcar
                 '(lambda (x)
                    (axis (trans (cdr (assoc 10 (entget x))) 0 1))
                 se
    (repeat (length se)
      (setq mc          (apply 'max sexy)
            ii          0
            i          -1
            list1 nil
            list0 nil
      (while (= ii 0)
        (setq i          (1+ i)
              sei (nth i se)
              xy  (axis (trans (cdr (assoc 10 (entget sei))) 0 1))
        (if (= mc xy)
          (setq        ss (cons sei ss)
                ii 1
          (setq        list1 (cons (nth i sexy) list1)
                list0 (cons sei list0)
      (setq sexy (append (reverse list1) (cdr (member mc sexy)))
            se         (append (reverse list0) (cdr (member sei se)))
    (setq ss (reverse ss))
  (defun wbdc_row        ()                        ;将实体分行
    (wbdc_sorten set0 cadr)
    (setq row  1
          set1 (cons (cons (car ss) row) nil)
    (mapcar
      '(lambda (x)
         (if (<        (+ (cadr (trans (cdr (assoc 10 (entget x))) 0 1))
                   (cdr (assoc 40 (entget x)))
                (cadr (trans (cdr (assoc 10 (entget (caar set1)))) 0 1))
           (setq row (1+ row))
         (setq set1 (cons (cons x row) set1))
      (cdr ss)
    (setq set1 (reverse set1))
  (defun wbdc_col        ()                        ;将实体分列
    (setq ss (reverse (wbdc_sorten set0 car)))
    (setq col  1
          set2 (cons (cons (car ss) col) nil)
    (mapcar
      '(lambda (x)
         (setq ym nil)
         (mapcar
           '(lambda (y)
              (if (= (cdr y) col)
                (setq tmp (entget (car y))
                      ym  (cons
                            (+ (car (trans (cdr (assoc 10 tmp)) 0 1))
                               (caadr (textbox tmp))
                            ym
           set2
         (if (>        (car (trans (cdr (assoc 10 (entget x))) 0 1))
                (apply 'max ym)
           (setq col (1+ col))
         (setq set2 (cons (cons x col) set2))
      (cdr ss)
    (setq set2 (reverse set2))
  (defun wbdc_main ()
    (while (not fn)
      (setq fn (getfiled "文本文件" "CADwrod" "doc" 13))
    (if        (findfile fn)
        (initget "Add wbdcite")
        (setq fs (getkword "\n覆盖W/<附加A>: "))
        (if (= fs "wbdcite")
          (setq fs (open fn "w"))
          (setq fs (open fn "a"))
    (initget "Normal Tab")
    (setq wmode (getkword "\n制表模式T/<普通文本N>: "))
    (if (= wmode nil)
      (setq wmode "Normal")
    (wbdc_set se1)
    (wbdc_row)
    (wbdc_col)
    (setq ij 0)
    (repeat row
      (setq l1 nil
            ij (1+ ij)
      (mapcar
        '(lambda (x)
           (if (= (cdr x) ij)
             (setq l1 (cons (car x) l1))
        set1
      (setq l1 (reverse (wbdc_sorten l1 car))
            j1 1
      (mapcar
        '(lambda (x)
           (setq j2 (cdr (assoc x set2)))
           (if (= wmode "Tab")
               (repeat (- j2 j1)
                 (princ "\t" fs)
               (princ (cdr (assoc 1 (entget x))) fs)
               (repeat (- j2 j1 1)
                 (princ " " fs)
           (setq j1 j2)
        l1
      (princ "\n" fs)
    (close fs)
(defun c:wbdc (/             axis    col     e0             fn             fs             i             ii
             ij             j1             j2             l1             list0   list1   mc             olderr
             oldsnp  oldzin  row     se             set0    set1    set2    ss
             text_name             tmp     wmode   x             y             ym             wbdc_col
             wbdc_main wbdc_m_pt wbdc_row  wbdc_sorten             wbdc_set  na
  (command "color" (getvar "cecolor"))
  (princ "\n选取文本: ")
  (setq se1 (ssget '((0 . "TEXT"))))
  (if se1
      (wbdc_defun)
      (wbdc_main)
    (princ "\n空选择集。")
(princ "\n**Text文本写入文件,ljs5178@126.com**")
(princ "\n**命令:wbdc")
发表于 2013-8-18 18:38:13 | 显示全部楼层
学习一下!
发表于 2023-1-15 14:45:02 | 显示全部楼层
    (setq l1   ( ...
感谢大佬分享,学习了
GMT+8, 2026-1-15 19:51 , Processed in 0.252058 second(s), 19 queries , Gzip On.
