楼主: hehoubin
大家帮忙看下这个关闭专用图层的LSP,。当关闭当前层要怎么写。
 楼主| 发表于 2012-11-25 17:04:23 | 显示全部楼层
那个要在别专用图层外为当前层时不是也把当前能关了吗,我是要当当前层在专用图层在某一图层上关闭当前图层,要是不在专用图层是就不关闭当前图层,
发表于 2012-11-25 17:14:31 | 显示全部楼层
你这个话把我给绕晕了.
 楼主| 发表于 2012-11-25 17:23:53 | 显示全部楼层
(DEFUN c:ftc ()
        (setvar "CMDECHO" 0)
        (setvar "Expert" 1)
        (command ".-layer" "off" "bh" "")
        (command ".-layer" "off" "acx" "")
        (command ".-layer" "off" "a01" "")
        (command ".-layer" "off" "a02" "")
        (command ".-layer" "off" "a03" "")
        (command ".-layer" "off" "a04" "")
        (command ".-layer" "off" "a05" "")
        (command ".-layer" "off" "a06" "")
        (command ".-layer" "off" "a07" "")
        (command ".-layer" "off" "a08" "")
        (command ".-layer" "off" "a09" "")
        (command ".-layer" "off" "a10" "")
        (command ".-layer" "off" "a11" "")
        (command ".-layer" "off" "a12" "")
        (command ".-layer" "off" "a13" "")
        (command ".-layer" "off" "a14" "")
       (setvar "Expert"0)
        (princ "\n ◆ a01--a14 已关闭")
(princ))
谢谢Andyhon 老师,我刚才写错了,这个是完整的,谢谢。
发表于 2012-11-26 12:32:47 | 显示全部楼层
(command ".-layer" "off" "a*" "")行不行?
 楼主| 发表于 2012-11-27 02:00:14 | 显示全部楼层
可以谢谢
发表于 2013-4-19 20:11:33 | 显示全部楼层
关闭当前层的同时,设置另外一个层为当前层。。就像关闭全部层一样
GMT+8, 2025-12-18 10:33 , Processed in 0.138851 second(s), 19 queries , Gzip On.
