楼主: wjl1014
裁剪——————裁剪矩形选择框外的所有图形。
发表于 2013-9-7 11:35:30 | 显示全部楼层
springwillow 发表于 2012-12-10 14:50
这也是我想知道的啊!普通的框内外裁剪很好弄,关键就是在块和填充的处理上!支持郞哥
同感啊。填充到好说,最头疼的就是这些个嵌套块,分好几次才能炸开的,以及Text,Mtext格式的文字。
还是用G版的《完美局部放大》好  发表于 2013-9-7 11:55
发表于 2013-9-8 06:35:48 | 显示全部楼层
试试这个:
;;;    EXTRIM.LSP
;;;    Copyright ?1999 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;Extended-TRIM - cookie-cutter routine
;Select a polyline, line, circle or arc and a side to trim on
(load "acetutil.fas")
(defun c:te        (/ na e1 e2 p1 redraw_it lst n keep)
        (acet-error-init
                (list
                        (list        "cmdecho"                0                                                "highlight"        0                                                "regenmode"
                                                1                                                "osmode"                0                                                "ucsicon"                0
                                                "offsetdist"                                                0                                                "attreq"                0
                                                "plinewid"        0                                                "plinetype"        1                                                "gridmode"
                                                0                                                "celtype"                "CONTINUOUS"                                                "ucsfollow"
                                                0                                                "limcheck"        0
                        T ;flag. True means use undo for error clean up.
                        '(if
                                redraw_it
                                (redraw na 4)
                ) ;list
        ) ;acet-error-init
;local function
        (defun dxf (a b /) (cdr (assoc a b))) ;defun
        (princ
                "\n拾取多段线、直线、圆、圆弧、椭圆、图像或文字来剪切边界..."
        (setq        na (acet-ui-single-select
                                                 '((-4 . "<OR")
                                                         (0 . "CIRCLE")
                                                         (0 . "ARC")
                                                         (0 . "LINE")
                                                         (0 . "ELLIPSE")
                                                         (0 . "ATTDEF")
                                                         (0 . "TEXT")
                                                         (0 . "MTEXT")
                                                         (0 . "IMAGE")
                                                         (0 . "LWPOLYLINE")
                                                         (-4 . "<AND")
                                                         (0 . "POLYLINE")
                                                         (-4 . "<NOT")
                                                         (-4 . "&")
                                                         (70 . 112)
                                                         (-4 . "NOT>")
                                                         (-4 . "AND>")
                                                         (-4 . "OR>")
                                                 T
                                         ) ;acet-ui-single-select
        ) ;setq
        (if        na
                        (setq e1 (entget na))
                        ;;setq
                        (if        (or        (equal "TEXT" (cdr (assoc 0 e1)))
                                                        (equal "MTEXT" (cdr (assoc 0 e1)))
                                                        (equal "ATTDEF" (cdr (assoc 0 e1)))
                                                        (equal "IMAGE" (cdr (assoc 0 e1)))
                                        ) ;or
          ;;保留*******
                                        (setq keep na)
                                        (setq lst (acet-geom-object-point-list na nil))
                                        (setq n 0)
                                        (command "_.pline")
                                        (repeat        (length lst)
                                                (command (nth n lst))
                                                (setq n (+ n 1)) ;setq
                                        ) ;repeat
                                        (if        (not (equal (car lst) (last lst) 0.0000001))
                                                (command "_cl")
                                                (command "")
                                        ) ;if
                                        (setq        na (entlast)
        e1 na
                                        ) ;setq
                                ) ;progn then draw a temp pline to be the cutting edge.
                                (setq e1 nil)
                        ) ;if
                        (redraw na 3)
                        (setq redraw_it T)
                        (setq p1 (getpoint "\n指定要修剪的一侧:")) ;setq
                        (redraw na 4)
                        (setq redraw_it nil)
                        ;;剪切
                        (if        p1
                                (xtrim na p1)
                        ) ;if
                        ;;删除
                        (setq e2 (entget na))
                        (if        (or        (= (dxf 0 e2) "LWPOLYLINE")
                                                        (= (dxf 0 e2) "POLYLINE")
                                                        (= (dxf 0 e2) "CIRCLE")
                                                        (= (dxf 0 e2) "ELLIPSE")
                                  (xdel na p1 keep)
                        (if        e1
                                        (if        (setq p1 (acet-layer-locked (getvar "clayer")))
                                                (command "_.layer" "_un" (getvar "clayer") "")
                                        ) ;if
                                        (entdel e1)
                                        (if        p1
                                                (command "_.layer" "_lock" (getvar "clayer") "")
                                        ) ;if
                                ) ;progn
                        ) ;if
                ) ;progn
        ) ;if
        (acet-error-restore)
) ;defun c:extrim
;;删除封闭多边形以内或以外的所有实体
(defun xdel        (edge         pt                 keep         /                 pts         side         edge2 edge3 a1
                                                 a2                 pts2         wpt         p1                 p2                 oss         iss         na                 n
        ;;确定是删除内部还是外部实体
        (setq pts (acet-geom-object-point-list edge nil))
        (command "_.area" "_ob" edge)
        (setq a1 (getvar "area"))
        (command "offset" (acet-geom-pixel-unit) edge pt "")
        (setq edge2 (entlast))
        (command "_.area" "_ob" edge2)
        (setq a2 (getvar "area"))
        (if        (> a1 a2)
                (setq side "I")
                (setq side "O")
        (setq pts2 (acet-geom-object-point-list edge2 nil))
        (entdel edge2)
        (setq        wpt        (acet-geom-list-extents pts)
                                p1        (car wpt)
                                p2        (cadr wpt)
;(command "_.zoom" "_w" p1 p2)
        ;;选择删除部分实体
        (setq oss (ssget "_x"))
        (if        (= side "O")
                (setq        iss        (ssget "_wp" pts2)
                                        iss        (ssadd edge iss)
                (setq iss (ssget "_cp" pts2))
        (if        (not iss)
                (setq iss (ssadd))
        (setq n 0)
        (repeat        (sslength iss)
                (setq na (ssname iss n))
                (if        (ssmemb na oss)
                        (setq oss (ssdel na oss)) ;setq then
                ) ;if
        ) ;repeat
        (if        keep
                        (if        (ssmemb keep oss)
                                (setq oss (ssdel keep oss))
                        (if        (ssmemb keep iss)
                                (setq iss (ssdel keep iss))
        ;;删除实体
        (if        (= side "I")
                (command "erase" iss "")
                (command "erase" oss "")
;(command "_.zoom" "_p")
        ;;再次选择并删除
;Entity-TRIM function
;takes: na - entity name
;  a - a point, the side to trim on
;NOTE: This function does not allow for the possible miss of
;      non-continuous linetypes.
(defun xtrim (na         a                /                 la                b                 d                e1         lst        lst2 n                j
                                                        k                 m                ss         na2        na3         na4        x                 y                z                 flag        flag2
                                                        flag3                        zlst
        (setq e1 (entget na)) ;setq
        (if        (or        (setq flag (equal (acet-dxf 0 e1) "POLYLINE"))
                                        (setq flag (equal (acet-dxf 0 e1) "LWPOLYLINE"))
                                        (equal (acet-dxf 0 e1) "LINE")
                                        (equal (acet-dxf 0 e1) "CIRCLE")
                                        (equal (acet-dxf 0 e1) "ARC")
                                        (equal (acet-dxf 0 e1) "ELLIPSE")
                                        (equal (acet-dxf 0 e1) "TEXT")
                                        (equal (acet-dxf 0 e1) "ATTDEF")
                                        (equal (acet-dxf 0 e1) "MTEXT")
                        ) ;or
                        (if        (and flag
                                                         (equal 8 (logand 8 (acet-dxf 70 e1)))
                                        ) ;and
                                (setq flag nil)
                        ) ;if
                        (setq a (trans a 1 0)) ;setq
                        (command "_.ucs" "_View")
;;;find extents of selected cutting edge object
                                                lst         (acet-geom-list-extents lst)
                                                x                 (- (car (cadr lst)) (car (car lst)))
                                                y                 (- (cadr (cadr lst)) (cadr (car lst)))
                                                x                 (* 0.075 x)
                                                y                 (* 0.075 y)
                                                z                 (list x y)
                                                x                 (list (+ (car (cadr lst)) (car z))
        (+ (cadr (cadr lst)) (cadr z))
        ) ;list
                                                y                 (list (- (car (car lst)) (car z))
        (- (cadr (car lst)) (cadr z))
        ) ;list
                                                zlst (zoom_2_object (list x y))
                        ) ;setq
;(command "_.zoom" "_w" x y)
      (command "_.zoom" "_w" (car zlst) (cadr zlst))
                        (entupd na)
;;;update the ent. so it's curves display smoothly
        na
        (/ (acet-geom-pixel-unit) 2.0)
                        ) ;setq
                        (if        (or        (not flag)
                                                        (not (acet-geom-self-intersect lst nil))
                                        ) ;or
;then the object is valid and not a self intersecting polyline.
                                        (if        (and flag
        (equal (car lst) (last lst) 0.0001)
                                                        ) ;and
                                                (setq flag3 T)
;then the polyline could potentialy need a second offset
                                        ) ;if
                                        (if        (setq la (acet-layer-locked (getvar "clayer")))
                                                (command "_.layer" "_unl" (getvar "clayer") "")
                                        ) ;if
                                        (command "_.pline")
                                        (setq b nil)
                                        (setq n 0) ;setq
                                                (setq d (nth n lst))
                                                (if        (not (equal d b 0.0001))
        (command d)
        (setq lst2 (append lst2 (list d))) ;setq
        (setq b d) ;setq
                                                        ) ;progn
                                                ) ;if
                                                (setq n (+ n 1))
                                        ) ;repeat
                                        (command "")
                                        (setq        na2        (entlast)
        ss        (ssadd)
        ss        (ssadd na2 ss)
        lst        nil
                                        ) ;setq
                                        (acet-ss-visible ss 1)
                                        (setq lst2 (get_fence_points na2 a lst2 flag3 flag)) ;setq
                                        (if        la
                                        ) ;if
                                        (command "_.ucs" "_p")
;Move the ents to force a display update of the ents to avoid viewres problems.
                                        (setvar "highlight" 0)
                                        (if        (setq ss (ssget "_f" (last lst2)))
                                                (command "_.move" ss "" "0,0,0" "0,0,0")
                                        ) ;if
                                        (if        flag
                                                        (if        (setq la (acet-layer-locked (acet-dxf 8 e1)))
        (command "_.layer" "_unl" (acet-dxf 8 e1) "")
                                                        ) ;if
                                                        (acet-ucs-set-z (acet-dxf 210 e1))
                                                        (command "_.copy" na "" "0,0,0" "0,0,0")
;(entdel na)
                                                        (acet-ss-visible (ssadd na (ssadd)) 1)
;make it invisible for a while.
;rk 12:01 PM 3/10/98
                                                        (setq        na3        na
        na        (entlast)
                                                        ) ;setq
                                                        (command "_.pedit" na "_w" "0.0" "_x")
                                                        (if        la
        (command "_.layer" "_lock" (acet-dxf 8 e1) "")
                                                        ) ;if
                                                ) ;progn
                                        ) ;if
                                        ;;将栏选线上的所有块(及内嵌块)、填充线、尺寸线炸开
                                        (setq n 0)
                                        (repeat        (length lst2)
        (nth n lst2)
        '((-4 . "<OR")
        (0 . "INSERT")
        (0 . "HATCH")
        (0 . "DIMENSION")
        (-4 . "OR>")
                                                (explodex ss)
                                                (setq n (1+ n))
                                        (command "_.trim" na "")
                                        (setq m (- (length lst2) 1)) ;setq
                                        (setq k 0)
                                                (setq lst (nth k lst2))
                                                (setq a (trans (car lst) 0 1))
                                                (setq n 1)
                                                (repeat        (- (length lst) 1) ;repeat each fence list
                                                        (setq b (trans (nth n lst) 0 1))
                                                        (if        (equal a b 0.0001)
        (setq flag2 T)
        (setq flag2 nil)
                                                        ) ;if
                                                        (setq na4 nil) ;setq
                                                        (setq j 0) ;setq
                                                        (while (not flag2)
;repeat each segment of the fence until no new ents are created.
        (setq na4 (entlast)) ;setq
        (command "_F" a b "")
        (if        (and (equal na4 (entlast))
        (or (not (equal k m))
        (> j 0)
        ) ;or
        ) ;and
        (setq flag2 T)
        ) ;if
        (setq j (+ j 1)) ;setq
                                                        ) ;while
                                                        (setq a b) ;setq
                                                ) ;repeat
                                                (setq k (+ k 1))
                                        ) ;repeat
                                        (command "")
                                        (if        flag
                                                        ) ;if
                                                        (entdel na) ;get rid of the copy
;(entdel na3);bring back the original
                                                        (acet-ss-visible (ssadd na3 (ssadd)) 0)
                                                        (if        la
                                                        ) ;if
                                                ) ;progn
                                        ) ;if
                                ) ;progn
                                        (princ "\n不接受自交边界。")
                                ) ;progn else invalid self intersecting polyline
                        ) ;if
                ) ;progn then it's a most likely a valid entity.
        ) ;if
) ;defun etrim
(defun another_offset
                         (pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4 / na ss lst da1 da2)
        (setq da1 (abs (- a2 a1))) ;setq
        (setq        da2        (- (* b (max pl2 pl1))
                                                         (/        (* b (abs (- pl2 pl1)))
        2.0
        ) ;setq
        (if        (> (abs (- da2 da1))
                                 (* 0.01 (max a1 a2))
                        (acet-pline-make (list lst2))
                        (setq        na        (entlast)
                                                na2        (entlast)
                                                ss        (ssadd)
                                                ss        (ssadd na ss)
                        ) ;setq
                        (command "_.offset" b na2 a "")
                        (if        (and (not (equal na (entlast)))
                                                         (setq lst3 (acet-geom-vertex-list (entlast)))
                                                         (setq lst3 (intersect_check lst2 lst3 lst4))
                                        ) ;and
                                        (acet-ss-visible (ssadd (entlast) (ssadd)) 1)
                                        (command "_.area" "_ob" (entlast))
                                        (setq        pl2        (getvar "perimeter")
        a2        (getvar "area")
                                        ) ;setq
                                        (setq lst (list (acet-geom-vertex-list (list (entlast) 0))))
;setq
                                        (entdel (entlast))
;then offset was a success so delete the ent after getting it's info
                                ) ;progn then
                                (if        (not (equal na (entlast)))
                                        (entdel (entlast))
                                ) ;if else
                        ) ;if
                        (entdel na2)
                ) ;progn then let's do that second offset
        ) ;if
        lst
) ;defun another_offset
(defun get_fence_points        (na2        a                 lst2        flag plflag                 /                a1         a2
        pl1        pl2         b                c                 d                n                 lst        lst3 lst4
        na
        (if        flag
                        (setq lst2 (cdr lst2)) ;setq
                        (repeat        (fix (/ (length lst2) 2))
                                (setq        lst2 (append (cdr lst2) (list (car lst2))) ;append
                                ) ;setq
                        ) ;repeat
                        (setq lst2 (append lst2 (list (car lst2)))) ;setq
                        (command "_.area" "_ob" na2)
                        (setq        pl1        (getvar "perimeter")
                                                a1        (getvar "area")
                        ) ;setq
                ) ;progn
        ) ;if
        (setq        a                 (trans a 0 1)
                                b                 (* (getvar "viewsize") 0.05) ;initial offset distance
                                n                 3.0 ;number of offsets
                                d                 (/ b (- n 1)) ;delta offset
                                c                 (acet-geom-pixel-unit)
                                lst4 (acet-geom-view-points)
        ) ;setq
        (while (> b c)
                (setq na (entlast))
                                                 (or (not plflag)
                                                 ) ;or
                                ) ;and
                                (setq lst3 (acet-geom-m-trans lst3 1 0))
                                (if        flag
        a2        (getvar "area")
                                                ) ;setq
                                        ) ;progn
                                ) ;if
                                (setq lst (append lst (list lst3))) ;setq
                                (entdel (entlast))
;delete the ent after getting it's vertex info
                                (if        flag
                                        (setq        lst
        (append
        lst
        (another_offset pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4)
        ) ;append
                                        ) ;setq
                                ) ;if
                        ) ;progn then offset was a success
                                (entdel (entlast))
                        ) ;if else
                ) ;if
                (setq b (- b d)) ;setq
        ) ;while
        (setq na (entlast))
        (command "_.offset" c na2 a "")
                                         (or (not plflag)
                                         ) ;or
                        ) ;and
                        (if        flag
        a2        (getvar "area")
                                        ) ;setq
                                ) ;progn
                        ) ;if
                        (entdel (entlast))
                        (if        flag
                                (setq
                                        lst        (append
        lst
        (another_offset pl1 pl2 a1 a2 c na2 lst2 a lst3 lst4)
                                                        ) ;append
                                ) ;setq
                        ) ;if
                ) ;progn then
                        (entdel (entlast))
                ) ;if else
        ) ;if
        (entdel na2)
        lst
) ;defun get_fence_points
;returns a list of points on screen if the first two lists do not
;contain segments that intersect each other.
(defun intersect_check (lst         lst2        lst3 /                x                 x2                y                 y2                lst4
        flag len        len2 a                aa         b                bb         c                d
        n                 j
        (setq        len         (length lst)
                                len2 (length lst2)
                                x                 (car (car lst3))
                                x2         (car (cadr lst3))
                                y                 (cadr (car lst3))
                                y2         (cadr (cadr lst3))
        ) ;setq
        (setq n 0) ;setq
        (while (and        (not flag)
                                                        (< (+ n 1) len2)
                                 ) ;and
                (setq        aa         (nth n lst2)
                                        bb         (nth (+ n 1) lst2)
                                        a                 (bns_truncate_2_view aa bb x y x2 y2)
                                        b                 (bns_truncate_2_view bb aa x y x2 y2)
                                        lst4 (append lst4 (list a))
                ) ;setq
                (if        (or        (not (equal a aa))
                                                (not (equal b bb))
                                ) ;or
                        (setq lst4 (append lst4 (list b)))
                ) ;if
                (setq j 0) ;setq
        (< (+ j 1) len)
                                         ) ;and
                        (setq        c                 (nth j lst)
                                                d                 (nth (+ j 1) lst)
                                                flag (inters a b c d)
                        ) ;setq
                ) ;while
        ) ;while
        (if        (not (equal b (last lst4)))
                (setq lst4 (append lst4 (list b))) ;setq
        ) ;if
        (if        (not flag)
                (setq flag lst4)
                (setq flag nil)
        ) ;if
        flag
) ;defun intersect_check
(defun zoom_2_object (lst        /        p1 p2        p3 p4        p5 p6        mp dx        dy dx2 dy2 r1        r2 na
        e1 x w h dv1 dv2 x)
        (setq        lst        (acet-geom-m-trans lst 1 2)
                                p1        (acet-geom-m-trans (acet-geom-view-points) 1 2)
;p1 and p2 are the viewpnts
                                p2        (cadr p1)
                                p1        (car p1)
                                p1        (list (car p1) (cadr p1))
                                p2        (list (car p2) (cadr p2))
        ) ;setq
        (if        lst
                        (setq        p5        (acet-geom-list-extents lst)
;p5 and p6 are the geometry points
                                                p6        (cadr p5)
                                                p5        (car p5)
                                                p5        (list (car p5) (cadr p5))
                                                p6        (list (car p6) (cadr p6))
                                                mp        (acet-geom-midpoint p5 p6)
;prepare to resize the geometry rectang to
                                                dx        (- (car p2) (car p1))
;have the same dy/dx ratio as p1 p2.
                                                dy        (- (cadr p2) (cadr p1))
                                                dx2        (- (car p6) (car p5))
                                                dy2        (- (cadr p6) (cadr p5))
                        ) ;setq
                        (if        (equal dx 0.0)
                                (setq dx 0.000001)
                        ) ;just in case div by zero
                        (if        (equal dx2 0.0)
                                (setq dx2 0.000001)
                        (setq        r1 (/ dy dx)
                                                r2 (/ dy2 dx2)
                        ) ;setq
                        (if        (< r2 r1)
                                (setq dy2 (* r1 dx2)) ;then scale dy2 up
                                        (if        (equal r1 0.0)
                                                (setq r1 0.000001)
                                        (setq dx2 (* dy2 (/ 1.0 r1))) ;else scale dx2 up
                                ) ;progn
                        ) ;if
                        (setq        p5 (list (- (car mp) (/ dx2 1.98))
;1.98 is used instead of 2.0 to expand
        (- (cadr mp) (/ dy2 1.98)) ;the rectangle slightly
                                                         ) ;list
                                                p6 (list (+ (car mp) (/ dx2 1.98))
        (+ (cadr mp) (/ dy2 1.98))
                                                         ) ;list
                        ) ;setq
                ) ;progn then lst
        ) ;if
        (if        (and lst
                                         (equal 0 (getvar "tilemode"))
                                         (not (equal 1 (getvar "cvport")))
                        ) ;and
                        (setq        na        (ssget "_x"
        (list '(0 . "VIEWPORT")
        '(67 . 1)
        (cons 69 (getvar "cvport"))
        ) ;ssget
                                                na        (ssname na 0)
                                                e1        (entget na)
                                                x                (cdr (assoc 10 e1))
                                                w                (cdr (assoc 40 e1))
                                                h                (cdr (assoc 41 e1))
                                                p3        (list        (- (car x) (/ w 2.0))
        (- (cadr x) (/ h 2.0))
        ) ;list
                                                p4        (list        (+ (car x) (/ w 2.0))
        (+ (cadr x) (/ h 2.0))
        ) ;list
                                                p3        (trans p3 3 2) ;p3 and p4 are the viewport points
                                                p4        (trans p4 3 2)
                                                dv1        (acet-geom-delta-vector p1 p3)
                                                dv2        (acet-geom-delta-vector p2 p4)
                                                x                (distance p1 p2)
                        ) ;setq
                        (if        (equal 0 x)
                                (setq x 0.000001)
                        ) ;just in case
                        (setq        x                (/ (distance p5 p6)
                                                dv1        (acet-geom-vector-scale dv1 x)
                                                dv2        (acet-geom-vector-scale dv2 x)
                                                p5        (acet-geom-vector-add p5 dv1)
                                                p6        (acet-geom-vector-add p6 dv2)
                        ) ;setq
                ) ;progn then
        ) ;if
        (setq        p1 (list (car p1) (cadr p1) 0.0)
                                p2 (list (car p2) (cadr p2) 0.0)
                                p5 (list (car p5) (cadr p5) 0.0)
                                p6 (list (car p6) (cadr p6) 0.0)
        ) ;setq
        (if        lst
                (setq        lst        (list        (trans p5 2 1)
        (trans p6 2 1)
                                                        ) ;list
                ) ;setq
                (setq lst nil)
        ) ;if
        lst
) ;defun zoom_2_object
(defun explodex        (ss / ss1 i ent flag flag1)
        (cond
                ((= (type ss) 'ENAME)
                 (if (or (= "INSERT" (cdr (assoc 0 (entget ss))))
                                                 (= "HATCH" (cdr (assoc 0 (entget ss))))
                                                 (= "DIMENSION" (cdr (assoc 0 (entget ss))))
                                 (command "_.explode" ss "")
                                 (setq flag t)
                         (setq flag nil)
                ((= (type ss) 'PICKSET)
                 (setq i 0)
                 (repeat (sslength ss)
                         (setq ent (ssname ss i))
                         (setq flag1 (explodex ent))
                         (if flag1
                                         (setq ss1 (ssget "P"))
                                         (if
                                                 (and
                                                         ss1
                                                         (or
        (> (sslength ss1) 1)
        (= "INSERT" (cdr (assoc 0 (entget (ssname ss1 0)))))
        (= "HATCH" (cdr (assoc 0 (entget (ssname ss1 0)))))
        (= "DIMENSION" (cdr (assoc 0 (entget (ssname ss1 0)))))
                                                        (explodex ss1)
                         (setq i (1+ i))
        flag
(princ "\n***切图程序已加载,命令名:TE. __付胜余")
很棒的功能,谢谢~  发表于 2025-4-25 14:51
适合自己的工具就是好工具,谢谢兄弟  发表于 2021-6-3 09:52
发表于 2013-9-10 18:15:45 | 显示全部楼层
谢谢楼主!又学一招。
发表于 2013-9-13 10:31:27 | 显示全部楼层
楼上这个,提示加载失败,什么原因
发表于 2013-9-15 18:37:14 | 显示全部楼层
是少一个文件。
发表于 2013-9-17 21:09:12 | 显示全部楼层
学习啊。。。
发表于 2013-9-29 17:02:17 | 显示全部楼层
还是要钱啊,不知道是不是自己想要的
发表于 2013-10-30 21:55:49 | 显示全部楼层
把不该切的切掉了
当曲线被边界两处切断时,该曲线被整体删除了
请作者修改一下
发表于 2013-11-23 10:27:35 | 显示全部楼层
可以免费么,,
发表于 2013-11-23 12:37:06 | 显示全部楼层
CAD自带的EXPRESS 里就有这个功能,命令是EXTRIM,完整安装CAD就有EXPRESS这项菜单了
GMT+8, 2026-1-16 18:39 , Processed in 2.472736 second(s), 21 queries , Gzip On.
