楼主: 革天明
不知道如何实现字符串连接,请指点
发表于 2012-12-11 14:28:15 | 显示全部楼层
  1. (defun c:tt (/ LST0 LST1 LST2 LST3 STR X Y Z)
  2.   (setq        lst1 (list "101" "102" "103" "104" "105" "106" "107" "108" "109" "110" "111" "112" "113" "114")
  3.   )
  4.   (setq        lst2 (list "201" "202" "203" "204" "205" "206" "207" "208" "209" "210" "211" "212" "213" "214" "215" "216" "217" "218" "219" "220" "221" "222" "223" "224" "225" "226" "227")
  5.   )
  6.   (setq        lst3 (list "301" "302" "303" "304" "305" "306" "307" "308" "309" "310" "311" "312")
  7.   )
  8.   (setq str "0.7-0-0.51-1.81-0.9-120-1.6-15-0-0")
  9.   (setq        lst0 (mapcar
  10.                '(lambda        (z)
  11.                   (apply 'append
  12.                          (mapcar
  13.                            '(lambda (y)
  14.                               (mapcar
  15.                                 '(lambda (x)
  16.                                    (strcat z "@" y "@" x "@" str)
  17.                                  )
  18.                                 lst3
  19.                               )
  20.                             )
  21.                            lst2
  22.                          )
  23.                   )
  24.                 )
  25.                lst1
  26.              )
  27.   )
  28.   (setq lst0 (apply 'append lst0))
  29. )
 楼主| 发表于 2012-12-11 14:34:44 | 显示全部楼层
这是我最终得到的文件,谢谢lijiao
GMT+8, 2025-12-17 11:12 , Processed in 0.131714 second(s), 19 queries , Gzip On.
