楼主: 848818376
标注尺寸加减前后缀
发表于 2021-6-26 16:00:22 | 显示全部楼层
这个是很早之前的了吧
发表于 2021-11-17 22:41:54 | 显示全部楼层
学习一下,看看
发表于 2021-11-21 16:55:36 | 显示全部楼层
  1. <div class="blockcode"><blockquote>(defun c:ttt ( / a ss n i qz hz qz0 hz0)
  2. (setq a (getint "[1:标注添加前后缀 2:标注去除前缀 3:标注去除后缀]:" ))
  3. (princ)
  4. (cond
  5.         ((= a 1)
  6.                 (princ "选择需要添加前后缀的线性标注:")
  7.         (princ)
  8.         (setq ss (ssget '((0 . "DIMENSION")))
  9.                    n (sslength ss)
  10.                    i 0
  11.         )
  12.     (setq qz (getstring "输入要添加的前缀:"))
  13.     (if
  14.             (= qz nil)
  15.             (setq qz "")
  16.     )
  17.     (setq hz (getstring "输入要添加的后缀:"))
  18.     (if
  19.             (= hz nil)
  20.             (setq hz "")
  21.     )
  22.         (while (< i n)
  23.                 (setq qz0 (Vlax-Get (Vlax-Ename->Vla-Object (ssname ss i)) 'TextPrefix )
  24.                           hz0 (Vlax-Get (Vlax-Ename->Vla-Object (ssname ss i)) 'TextSuffix )
  25.                 )
  26.                 (Vlax-Put-Property (Vlax-Ename->Vla-Object (ssname ss i)) 'TextPrefix (if (= qz0 "") qz (strcat qz qz0)))
  27.                 (Vlax-Put-Property (Vlax-Ename->Vla-Object (ssname ss i)) 'TextSuffix (if (= hz0 "") hz (strcat hz0 hz)))
  28.             (setq i (+ i 1))
  29.         )
  30.         )
  31.         ((= a 2)
  32.                                 (princ "选择需要删除前缀的线性标注:")
  33.         (princ)
  34.         (setq ss (ssget '((0 . "DIMENSION")))
  35.                    n (sslength ss)
  36.                    i 0
  37.         )
  38.         (while (< i n)
  39.                 (Vlax-Put-Property (Vlax-Ename->Vla-Object (ssname ss i)) 'TextPrefix "")
  40.             (setq i (+ i 1))
  41.         )
  42.         )
  43.         ((= a 3)
  44.                                 (princ "选择需要删除后缀的线性标注:")
  45.         (princ)
  46.         (setq ss (ssget '((0 . "DIMENSION")))
  47.                    n (sslength ss)
  48.                    i 0
  49.         )
  50.         (while (< i n)
  51.                 (Vlax-Put-Property (Vlax-Ename->Vla-Object (ssname ss i)) 'TextSuffix "")
  52.             (setq i (+ i 1))
  53.         )
  54.         )
  55. )
  56. )
发表于 2023-3-5 08:16:11 | 显示全部楼层
848818376 发表于 2012-12-15 15:17
没人回复,我自己来咯,作者:明经 ZZXXQQ 2008.2.12
感谢楼主分享
发表于 2023-11-24 13:37:47 | 显示全部楼层
GMT+8, 2026-1-14 22:46 , Processed in 0.159152 second(s), 19 queries , Gzip On.
