查看: 1401|回复: 4
[讨论] 把数据表导出到excel出错!求解释,谢啦
发表于 2013-5-3 14:50:40 | 显示全部楼层 |阅读模式
(DEFUN C:R1()
  (SETQ P0 (GETPOINT "\n 第一个数据点:"))
  (while (/= nil)
  (setq p1 (polar p0 0 80))
  (setq p2 (polar p1 0 80))
  (setq p3 (polar p2 0 80))
  (setq p4 (polar p3 0 80))
  (setq p5 (polar p4 0 80))
    (setq ss-p (list p0 p1 p2 p3 p4 p5))
  (setq s1 (mapcar '(lambda(x)
        (setq pp (polar (polar x 0 80) (* 1.5 pi) 22))
        (setq s (ssget "c" x pp '((0 . "*text"))))
        (cdr(assoc 1 (entget (ssname s 0)))))
      ss-p
  (setq s2 (apply '(lambda (x y z x1 y1 z1)
       (strcat x "," y "," z "," x1 "," y1 "," z1)
    s1
  (setq ff (open "d:\\2.csv" "w"))
  (write-line s2 ff)
  (close ff)
  (setq p0 (polar p0 (* 1.5 pi) 22))
总是出错!!!
数据表的每个格子大小为(长)80*(宽)22,一行为6格
发表于 2013-5-3 15:21:29 | 显示全部楼层
错的一塌糊涂!
(while (/= nil)
死循环了!
  (write-line s2 ff)
  (close ff)
文件永远只记录一组数据!
其他没细看!
 楼主| 发表于 2013-5-3 19:23:45 | 显示全部楼层
Gu_xl 发表于 2013-5-3 15:21
错的一塌糊涂!
(while (/= nil)
有时候不知道具体有多少组数据就让它循环着,不知道怎么跳出。。。。。。
怪不得最多就一组最后的数据
 楼主| 发表于 2013-5-3 19:35:22 | 显示全部楼层
(DEFUN C:R1()
  (while (/= (progn
           (setq px (polar (polar p0 0 80) (* 1.5 pi) 22))
           (setq sx (ssget "c" p0 px '((0 . "*text"))))
           )nil)
    (setvar "osmode" 0)
             ss-p
                  s1
  (setq ff (open "d:\\2.csv" "a"))
  (write-line s2 ff)
    (close ff)
    (setvar "osmode" 16383)
改了下
发表于 2013-5-4 07:12:52 来自手机 | 显示全部楼层
选择集循环?while的用法查下资料吧!
GMT+8, 2025-5-23 04:59 , Processed in 0.169891 second(s), 30 queries , Gzip On.
