查看: 2122|回复: 3
[提问] 如何得到长宽高
发表于 2013-6-13 23:39:17 | 显示全部楼层 |阅读模式
;功能:返回选择集包围盒
;来自明经网友
;返回值:选择集所有实体做为整体的包围盒
(defun GetSSBoundingbox (ss / i ssn ll rr box ptlist ssbox)
        (if ss
                        (setq i -1)
                        (repeat (sslength ss)
                                (setq ssn (ssname ss (setq i (1+ i))))
                                (vla-GetBoundingBox (vlax-ename->vla-object ssn) 'll 'rr)  ;得到对象的包围盒
                                (setq box (list (vlax-safearray->list ll) (vlax-safearray->list rr)))
                                (setq ptlist (append box ptlist))
                        (setq ssbox (mapcar '(lambda (x) (apply 'mapcar (cons x ptlist))) (list 'min 'max)))
(defun c:asd(/ pt1 pt2 pt3 pt4)
  (VL-LOAD-COM)
  (princ "\n 请选择正视图")
  (setq ssbox (GetSSBoundingbox (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,PLWPOLYLINE"))))))
  (setq pt1 (car ssbox)
pt3 (cadr ssbox)
pt2  (list (car pt3) (cadr pt1) 0)
pt4  (list (car pt1) (cadr pt3) 0)
  (setq distl (distance pt1 pt2))
  (setq distk (distance pt1 pt4))
  (princ "\n 请选择投影视图")
  (setq ssboxt (GetSSBoundingbox (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,PLWPOLYLINE"))))))
  (setq ptt1 (car ssboxt)
ptt3 (cadr ssboxt)
ptt2  (list (car ptt3) (cadr ptt1) 0)
ptt4  (list (car ptt1) (cadr ptt3) 0)
  (setq distl2 (distance ptt1 ptt2))
  (setq distk2 (distance ptt1 ptt4))
  (if (= distl distl2)
    (setq disth distk2)
  (if (= distl distk2)
    (setq disth distl2)
  (if (= distk distk2)
    (setq disth distl2)
  (if (= distk distl2)
    (setq disth distk2)
  (princ "\nL =")
  (PRINC  distl)
  (princ "\nk =" )
  (PRINC  distk)
  (princ "\nh =" )
  (PRINC  disth)
情况1
情况2
如何得到DISTH
我不知道怎么判断
发表于 2013-6-14 08:44:02 | 显示全部楼层
(AND (equal  X X1 0.001 ) (not (equal Y Y1 0.001)) ) ; X軸相等 , Y不相等 ,視圖為上下
長寬高= X*Y*Y1  或  X1*Y1*Y
(AND (equal  Y Y1 0.001 ) (not (equal X X1 0.001)) ) ; Y軸相等 , X不相等 ,視圖為左右
長寬高= X*Y*X1  或  X1*Y1*X
(T  (print "兩視圖無法對應,請檢查視圖"))
 楼主| 发表于 2013-6-14 20:23:33 | 显示全部楼层
長寬高= X*Y ...
对,就是精度问题,我也过这个问题,呵呵谢谢先生了
发表于 2022-3-30 20:56:02 | 显示全部楼层
前辈这个完整代码有吗?求分享
GMT+8, 2025-5-16 02:03 , Processed in 0.246707 second(s), 31 queries , Gzip On.
