楼主: lyy
[讨论]征求轮廓线的lisp思路
发表于 2003-11-9 21:44:00 | 显示全部楼层
好帖子,先顶到前边去看:)
发表于 2004-1-17 20:54:00 | 显示全部楼层
这篇帖子不错。保存
发表于 2004-1-20 11:16:00 | 显示全部楼层
贴一个自己的,
(defun c:lkx1 (/ DX DY E E1 IN N P1 P2 P21 P3 P4 S XY)
  (mapcar 'setvar '("cmdecho""blipmode") '(0 0))
  (prompt "\n选择要画外轮廓线的物体:")
  (setq s(ssget)
        p1 (getpoint "\n输入框线左下点:")
        p3 (getcorner p1 "\n输入框线右上点:")
        xy(mapcar '- p3 p1)
        dx (car xy) dy (cadr xy)
        p2 (xd p1 0 dy)                        p4 (xd p1 dx 0)
        p21(xd p2 100 -100))
  (setvar "osmode" 0)
  (#m_pl2 1 0 0 (list p1 p2 p3 p4) (getvar "clayer") -1)
  (setq e1(entlast)s(ssadd e1 s))
  (command "-boundary" "a" "b" "n" s """" p21 ""
           "erase" e1 "")
  (setq s(get-ss e1)n(sslength s)in 0)
  (cond
    ((< n 2))
    ((= n 2)(entdel (ssname s 1)))
    (t
      (repeat (- n 2)
        (setq e(ssname s in) in (1+ in))
        (entdel e)
      (entdel (ssname s (1- n)))
  (mapcar 'setvar '("osmode""cmdecho""blipmode") '(32 1 1))(princ)
(defun xd(#pt #x #y)
  (list (+ (car #pt) #x) (+ (cadr #pt) #y))
(defun #m_pl2 (d70 plw pla pl_list lay_pl color / pb)
  (setq        d90 (length pl_list)
        pb  '()
  (foreach x pl_list
      (setq pb
             (append pb
                     (list (cons 10 x)
                           (cons 40 plw)
                           (cons 41 plw)
                           (cons 42 pla)
  (setq        en000 (append (list
                        (cons 0 "LWPOLYLINE")
                        (cons 100 "AcDbEntity")
                        (cons 8 lay_pl)
                        (cons 100 "AcDbPolyline")
                        (cons 90 d90)
                        (cons 70 d70)
                      pb
  (if (/= -1 color) (setq en000 (append en000 (list (cons 62 color)))))
  (if (= nil (entmake en000)) (princ "\n制造 LWPL 制造失败.")  )
程序是以前写的,不足有:
没加入过滤。
可能出现多个轮廓线,和bon的算法有关。
现在和育游的相比是手动的了。:)
发表于 2004-1-20 11:22:00 | 显示全部楼层
还有几个子函数没给出来吧
发表于 2004-1-20 13:26:00 | 显示全部楼层
一点思路:
用WMFOUT/WMFIN将选择集内的物体处理成临时图块,去掉外边的框后在得到包围盒的焦点坐标,在包围盒和外框之间任意一点作boundary,如果图形吻合,应能找到边界(两个多义线,选面积小的)。
发表于 2004-1-23 01:06:00 | 显示全部楼层
研究了一下,这样也行?
  1. (defun x@outline1 ()
  2.   (setvar "qaflags" 1)
  3.   (setq ss0 (ssget "all")
  4.         ss  (ssget))
  5.   (vl-cmdf "_.copy" ss "" "0,0" "@")
  6.   (vl-cmdf "_.region" "all" "r" ss0 ""
  7.            "_.union" "all" "r" ss0 ""
  8.            "_.explode" "all" "r" ss0 ""
  9.            "_.explode" "all" "r" ss0 ""
  10.            "_.pedit" "m" "all" "r" ss0 "" "y" "j" "1" ""
  11.            "_.region" "all" "r" ss0 ""
  12.            "_.union" "all" "r" ss0 ""
  13.            "_.explode" "all" "r" ss0 ""
  14.            "_.explode" "all" "r" ss0 ""
  15.            "_.pedit" "m" "all" "r" ss0 "" "y" "j" "1" ""
  16.   )
  17. )
  18. (defun x@outline2 ()
  19.   (vl-cmdf ".undo" "be")
  20.   (setq os (getvar "osmode"))
  21.   (setvar "osmode" 0)
  22.   (setvar "qaflags" 1)
  23.   (setq ss0 (ssget "all")
  24.         ss  (ssget '((0 . "*POLYLINE,LINE,ARC,CIRCLE,ELLIPSE")))
  25.         vmin  (getvar "VSMIN")
  26.         vmax  (getvar "VSMAX")
  27.         dist  (* 2 (getvar "VIEWSIZE") (/ (getvar "PICKBOX") 100)))
  28.   (vl-cmdf ".RECTANGLE" (polar vmin (* 1.25 PI) dist) (polar vmax (* 0.25 PI) dist))
  29.   (setq em (entlast))
  30.   (vl-cmdf "_.boundary" "a" "o" "P" "i" "y" "b" "n" ss em "" ""  emin "")
  31.   (setvar "osmode" os)
  32.   (vl-cmdf ".undo" "e")
  33. )
测试了一下,用region只能对封闭实体有效,可惜,可惜。用boundary可以对line,arc等封闭的区域有效,但通用性又没region好。我觉得两者应该结合起来。
发表于 2004-9-29 05:53:00 | 显示全部楼层
再玩玩
发表于 2004-10-19 09:46:00 | 显示全部楼层
我的思路是:做一个能包含你图的大圆,然后在lisp中command"_boundary""region"生成边界。得到两个封闭的面域。其中一个就是你想要的。
发表于 2012-6-12 19:36:03 | 显示全部楼层
各位大侠太厉害了。长见识了。
发表于 2014-4-14 17:56:42 | 显示全部楼层
各位大侠太厉害了。长见识了。非常感谢
GMT+8, 2025-12-17 01:10 , Processed in 0.202217 second(s), 20 queries , Gzip On.
