查看: 2257|回复: 8
[已解答] 求大神帮忙合并下这个对话框
发表于 2013-7-2 11:34:08 | 显示全部楼层 |阅读模式
各位大侠,我想学习下,怎样把LSP和DCL合并到一起,
求大侠帮忙下,把下面的两个程序合并到一起,谢谢了!
我想对比一下: 合并前和合并后有什么区别,是怎么合并的
这是LSP:
(defun newerr()
  (setq *error* olderr esel nil edata nil d nil new nil do nil ss nil name nil)
  (command "undo" "e")
(defun c:TT2 (/ esel edata enme id new do ss name)
  (setq olderr *error* *error* newerr)
  (gc)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (setq esel (nentsel "\n选择文字"))
  (setq edata (entget (car esel)))
  (if
    (and
      (> (length esel) 2)
      (= (cdr (assoc 0 (entget (car esel)))) "MTEXT")
      (= (cdr (assoc 0 (entget (car (last esel))))) "DIMENSION")
    (setq enme (car (last esel)) edata (entget enme))
  (cond
      (or
(= (cdr (assoc 0 edata)) "TEXT")
        (= (cdr (assoc 0 edata)) "MTEXT")
        (= (cdr (assoc 0 edata)) "DIMENSION")
        (= (cdr (assoc 0 edata)) "ATTRIB")
        (= (cdr (assoc 0 edata)) "ATTDEF")
      (if (> (setq id (load_dialog "wz.dcl")) 0)
        (if (new_dialog "edit" id)
     (cond
                (set_tile "edit" (vl-string-subst  "" "\\A1;" (cdr (assoc 1 (entget (car esel))))))
                (set_tile "error" "尺寸文字")
                (and (> (length esel) 2)(= (cdr (assoc 0 (entget (car (last esel))))) "INSERT"))
                (set_tile "edit" (cdr (assoc 1 edata)))
                (set_tile "error" "块中文字")
                (and (= (length esel) 2)(= (cdr (assoc 0 (entget (car esel)))) "TEXT"))
                (set_tile "error" "普通文字")
                (and (= (length esel) 2)(= (cdr (assoc 0 (entget (car esel)))) "MTEXT"))
                (set_tile "error" "段落文字")
                (and (= (length esel) 2)(= (cdr (assoc 0 (entget (car esel)))) "ATTRIB"))
                (set_tile "error" "属性文字")
                (and (= (length esel) 2)(= (cdr (assoc 0 (entget (car esel)))) "ATTDEF"))
                (set_tile "edit" (cdr (assoc 2 edata)))
                (set_tile "error" "属性定义")
            (mode_tile "edit" 2)
            (action_tile "edit" "(setq new $value)")
            (action_tile "accept" "(setq result T)(done_dialog 1)")
            (action_tile "cancel" "(done_dialog 0)")
            (start_dialog)
      (unload_dialog id)
      (if result
          (if (= (cdr (assoc 0 (entget (car esel)))) "ATTDEF")
     (setq edata (subst (cons 2 new) (assoc 2 edata) edata))
     (setq edata (subst (cons 1 new) (assoc 1 edata) edata))
          (entmod edata)
          (if (and (> (length esel) 2)(= (cdr (assoc 0 (entget (car (last esel))))) "INSERT"))
              (setq name (cdr (assoc 2 (entget (car (last esel))))))
              (setq ss (ssget "x" '((0 . "insert"))) n 0)
              (repeat (sslength ss)
                (setq esel (ssname ss n) n (1+ n))
                (if (= (cdr (assoc 2 (entget esel))) name)(entupd esel))
            (entupd (car esel))
    (T (princ "\n不是文字"))
  (newerr)
这是DCL
edit:dialog
  label="超级文字编辑";
  :edit_box
    label="文字:";
    key="edit";
    edit_width=40;
    allow_accept=true;
  :row
    spacer;
    :errtile
      width=14;
    ok_cancel;
  spacer;
发表于 2013-7-2 11:56:40 | 显示全部楼层
用的yxp大侠的dcl2lsp,论坛收一下
ucuc2003 + 1
发表于 2013-7-2 11:56:41 | 显示全部楼层
 楼主| 发表于 2013-7-2 12:07:09 | 显示全部楼层
感谢老大给我指条明路!
 楼主| 发表于 2013-7-2 12:09:00 | 显示全部楼层
1993063 发表于 2013-7-6 06:56
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=92336
感谢老大给我指了条明路!
 楼主| 发表于 2013-7-2 17:34:45 | 显示全部楼层
问一下,程序运行后 会在电脑里面产生一个DCL垃圾文件,请问在最后面加上什么,可以在程序运行完自动删除DCL文件?
发表于 2013-7-2 17:54:06 | 显示全部楼层
(vl-file-delete "wz.dcl")
 楼主| 发表于 2013-7-2 18:02:23 | 显示全部楼层
太感谢热心的hao3ren了!测试好了!程序运行后没有DCL了!!
发表于 2022-6-23 11:25:07 | 显示全部楼层
   (setq dcl_file (open (setq tmp-dcl-file-name (vl-filename-mktemp nil nil  ".DCL")) "w"))
                 (foreach x
                     "edit:dialog"
                     "  label=\"超级文字编辑\";"
                     "  :edit_box"
                     "    label=\"文字:\";"
                     "    key=\"edit\";"
                     "    edit_width=40;"
                     "    allow_accept=true;"
                     "  :row"
                     "    spacer;"
                     "    :errtile"
                     "      width=14;"
                     "    ok_cancel;"
                     "  spacer;"
     ) (write-line x dcl_file) )
     (setq dcl_file (close dcl_file)))
(defun newerr()
(defun c:wz(/ esel edata enme id new do ss name)
  (gc)
  (if
    (and
      (> (length esel) 2)
  (cond
      (or
      (if (> (setq id (load_dialog tmp-dcl-file-name)) 0)
            (cond
            (start_dialog)
      (unload_dialog id)
      (if result
          (entmod edata)
            (entupd (car esel))
  (newerr)
试试这 参考看看
GMT+8, 2026-1-16 10:10 , Processed in 0.197542 second(s), 35 queries , Gzip On.
