楼主: shiyan001
[提问] 关于坐标转换的问题。
发表于 2013-7-28 18:06:19 | 显示全部楼层
;;; vp-outline.lsp (VPO)
;;; Creates a polyline in modelspace that
;;; has the outline of the selected viewport.
;;; Supports clipped viewports.
;;; If vp-outline is called when in mspace it detects
;;; the active viewport.
;;; c:vp-outline (C:VPO)
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
;;; 2000-04-10
;;; 2003-11-19 Added support for drawing the outline in other ucs/view than world/current
;;; 2006-04-06 Added support for twisted views Tom Beauford
;;; Tested on AutoCAD 2000, 2000i, 2002, 2004, 2006, 2007
(vl-load-com)
(defun dxf (n ed) (cdr (assoc n ed)))
(defun ax:List->VariantArray (lst)
  (vlax-Make-Variant
    (vlax-SafeArray-Fill
      (vlax-Make-SafeArray
        vlax-vbDouble
        (cons 0 (- (length lst) 1))
      lst
(defun c:VPO (/ ad ss ent pl plist xy n vpbl vpur msbl msur ven vpno ok)
  (setq ad (vla-get-activedocument (vlax-get-acad-object)))
  (if (= (getvar "tilemode") 0)
      (if (= (getvar "cvport") 1)
          (if (setq ss (ssget ":E:S" '((0 . "VIEWPORT"))))
              (setq ent (ssname ss 0))
              (setq vpno (dxf 69 (entget ent)))
              (vla-Display (vlax-ename->vla-object ent) :vlax-true)
              (vla-put-mspace ad :vlax-true) ; equal (command "._mspace")
              ; this to ensure trans later is working on correct viewport
              (setvar "cvport" vpno)
;              (vla-put-mspace ad :vlax-false) ; equal (command "._pspace")
              (setq ok T)
        (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))
              ok  T
      (if ok
          (setq ven (vlax-ename->vla-object ent))
          (if (/= 1 (logand 1 (dxf 90 (entget ent)))) ; detect perspective
            (if (= (vla-get-clipped ven) :vlax-false)
               (progn                 ; not clipped
                 (vla-getboundingbox ven 'vpbl 'vpur)
                   (setq vpbl  (trans (vlax-safearray->list vpbl) 3 2)
                         msbl  (trans vpbl 2 1)
                         msbl  (trans msbl 1 0)
                         vpur  (trans (vlax-safearray->list vpur) 3 2)
                         msur  (trans vpur 2 1)
                         msur  (trans msur 1 0)
                         vpbr (list (car vpur) (cadr vpbl)0)
                         msbr  (trans vpbr 2 1)
                         msbr  (trans msbr 1 0)
                         vpul (list (car vpbl) (cadr vpur)0)
                         msul  (trans vpul 2 1)
                         msul  (trans msul 1 0)
                         plist (list (car msbl) (cadr msbl)
                                            (car msbr) (cadr msbr)
                                            (car msur) (cadr msur)
                                            (car msul) (cadr msul)
               (progn                 ; clipped
                 (setq pl    (entget (dxf 340 (entget ent)))
                       plist (vla-get-coordinates
                               (vlax-ename->vla-object (dxf -1 pl))
                       plist (vlax-safearray->list (vlax-variant-value plist))
                       n     0
                       pl    nil
                 (repeat (/ (length plist) 2)
                   (setq xy (trans (list (nth n plist) (nth (1+ n) plist)) 3 2)
                         xy  (trans xy 2 1)
                         xy  (trans xy 1 0)
                         pl (cons (car xy) pl)
                         pl (cons (cadr xy) pl)
                         n  (+ n 2)
                 (setq plist (reverse pl))
          (setq plist (ax:List->VariantArray plist))
          (vla-Put-Closed
            (vla-AddLightWeightPolyline
              (vla-get-ModelSpace ad)
              plist
            :vlax-True
  (if ss(vla-put-mspace ad :vlax-false)) ; equal (command "._pspace"))
 楼主| 发表于 2013-7-28 18:53:02 | 显示全部楼层
namezg 发表于 2013-7-28 17:35
要不你传了图吧,我的ucs也是有角度的啊,也执行了plan,没发现问题啊
图中三角形的左下角坐标100,100,该点在布局1的坐标为73.9763,73.3014,如何得到这个坐标。
发表于 2013-7-28 19:22:29 | 显示全部楼层
;进入模型空间视口后执行下面的语句
(setq ucs_pt (getpoint "\n拾取模型空间视口内一点: "))
(setq dcs_pt (trans ucs_pt 1 2));当前模型空间视口的 UCS -> 当前模型空间视口的 DCS
(setq psdcs_pt (trans dcs_pt 2 3));当前模型空间视口的 DCS -> 图纸空间 DCS
;进入布局空间后执行下面的语句
(setq psucs_pt (trans psdcs_pt 0 1));图纸空间 DCS -> 图纸空间 UCS
命令: _.MSPACE
命令: (setq ucs_pt (getpoint "\n拾取模型空间视口内一点: "))
拾取模型空间视口内一点: (0.0 0.0 0.0)
命令: (setq dcs_pt (trans ucs_pt 1 2))
(136.603 36.6025 0.0)
命令: (setq psdcs_pt (trans dcs_pt 2 3))
(73.9763 73.3014 0.0)
命令: _.PSPACE
命令: (setq psucs_pt (trans psdcs_pt 0 1))
 楼主| 发表于 2013-7-28 19:45:56 | 显示全部楼层
namezg的方法解决了问题,谢谢你,同时谢谢大家的帮助。
发表于 2015-9-19 07:39:29 | 显示全部楼层
pzweng 发表于 2013-7-28 11:33
查看一个高飞鸟的贴子,专门有一贴介绍trans
你好,大家都说高飞鸟帖子里有介绍trans,但我在高飞鸟所有帖子里都过了一篇,没有发现这样的帖子,能否将该帖子的网址发给我一下吗?谢谢~
发表于 2015-9-19 08:42:44 | 显示全部楼层
GMT+8, 2025-12-17 04:00 , Processed in 0.151002 second(s), 19 queries , Gzip On.
