楼主: xskfq
[已解答] 如何检查直线是否断开(寻找开口)
发表于 2013-12-5 21:15:59 | 显示全部楼层
(defun c:checkdx()
(if (setq ssa (ssget '((0 . "LINE")))) (progn
  (setq ptb nil i -1)
  (repeat (sslength ssa)
   (setq dxf (entget (ssname ssa (setq i (1+ i))))
         ptb (cons (cdr (assoc 11 dxf)) (cons (cdr (assoc 10 dxf)) ptb)))
  (setq jgb nil fhz nil)
  (while (setq pt (car ptb) ptb (cdr ptb))
   (if (member pt ptb)
    (setq ptb (vl-remove pt ptb)
          fhz (cons pt fhz))
    (setq jgb (cons pt jgb))
  (setq oldcol (getvar "CECOLOR"))
  (command "COLOR" 1)
  (mapcar '(lambda(x) (command "_circle" x 50)) jgb)
  (command "COLOR" oldcol)
  (setq tymlb nil)
  (foreach pt fhz
   (setq ssa (ssget "c" pt pt '((0 . "LINE")))
         i   -1)
    (if (not (member (setq ent (ssname ssa (setq i (1+ i)))) tymlb))
     (setq tymlb (cons ent tymlb))
 楼主| 发表于 2013-12-6 00:00:21 | 显示全部楼层
flyfox1047 发表于 2013-12-5 21:15
(defun c:checkdx()
  (setq ptb nil i -1)
你用燕秀试试,结果和你不一样。。
发表于 2013-12-6 00:05:58 | 显示全部楼层
xskfq 发表于 2013-12-6 00:00
你用燕秀试试,结果和你不一样。。
检查线段是否断开-------------------yx_chl  燕秀的我用过,基本差不多,之前你发贴时,我也推荐你用燕秀,你要源码,现在满足你提的条件了,你又要跟燕秀一模一样,无语了!只有赖心秀来回答你的问题了!
GMT+8, 2025-12-18 07:56 , Processed in 0.151952 second(s), 18 queries , Gzip On.
