楼主: naul
菜鸟求助
发表于 2007-4-7 10:40:00 | 显示全部楼层
;;; TESTDCL.LSP .... by M.P.Saju.
;;; This is a freeware. License for use of this application is granted for
;;; distribution, provided it is not mutilated. If there are problems please
;;; feel free to contact the author at mpsaju@yahoo.com
;;; Testing *.DCL files becomes a necessity when developing a good sized lisp
;;; application for easy input and understanding. This routine in lisp was
;;; written for just such a necessity.
;;; Usage is very simple... Just type "Testdcl" in Autocad text screen and press
;;; "enter". A file selection dialog box will open up to select the DCL file.
;;; On entering, the DCL under test will open. This application works under
;;; the assumption that there is an active "accept" or "cancel" button.
;;; I have tried to solve all problems that I have encountered. However if there
;;; are any further issues please feel free to contact me.
(defun c:testdcl (/ nam$ nam id loop)
  ;; lisp for checking dialogboxes at the beginning of their design
  (setq nam$ (getfiled "Select a DCL file" "" "dcl" 0))
  (setq nam (identify nam$))
(defun identify (nam$ / file x dd dd$)
  (setq file (open nam$ "r")
        dd$  nil
        dd   nil
        x    0
  (while (setq dd (read-line file))
    (if (wcmatch dd "*: dialog {")
        (setq dd$ (substr dd 1 (- (strlen dd) 11)))
        (if (wcmatch dd$ " *")
          (setq dd$ (substr dd$ 2 (strlen dd$)))
          ;; added for eliminating blank
        (rundcl nam$ dd$)
  (close file)
  dd$
(defun rundcl (nam$ nam)
  (setq id (load_dialog nam$))
  (if (not (new_dialog nam id))
    (exit)
  (action_tile "cancel" "(done_dialog 0)")
  ;; cancel button dialog.. normally in all DCLs
  (action_tile "accept" "(done_dialog 0)")
  ;; accept button dialog.. normally in all DCLs
  (setq loop (start_dialog))
ref Link:
http://www.autocadokulu.com/portal/forums.php?m=posts&q=3214
GMT+8, 2025-12-18 07:17 , Processed in 0.155505 second(s), 18 queries , Gzip On.
