查看: 6347|回复: 20
[已解答] 求两个程序的合并(关于圆心处打断直线)
发表于 2014-1-23 09:12:52 | 显示全部楼层 |阅读模式
5明经币
我的思路是分2步:(参见图片)
第一步:把圆心挪到直线上,程序“挪圆.lisp”
第二步:在圆心处打断直线,程序“圆心打断.lisp”
如何把这2个程序合并为一个程序?
挪圆.lisp;
(defun c:ny(/ center circle index lineobj point point_01 point_02 radius ssline syh)
  (vl-load-com)
  (setvar "cmdecho" 0)
  (princ "\n请选取要处理的直线对象")
  (if(setq ssLine (ssget '((0 . "LINE"))))
    (progn (setq syh 0)
      (vl-cmdf ".zoom" "e")
      (repeat (sslength ssLine)
(entmod(setq LineObj(ssname ssLine syh)syh(1+ syh)
       point(entget LineObj)
       LineObj(vlax-ename->vla-object LineObj)
       Point_01(cdr(assoc 10 point))
       Point_01(list(car Point_01)(cadr Point_01)0)
       Point_02(cdr(assoc 11 point))
       Point_02(list(car Point_02)(cadr Point_02)0)
       point(subst(cons 10 Point_01)(assoc 10 point)point)
       point(subst(cons 11 Point_02)(assoc 11 point)point)))
(if(setq ssCircle(ssget"F"(list Point_01 Point_02)'((0 . "CIRCLE"))))
   (progn (setq index 0)
     (repeat (sslength ssCircle)
       (entmod(setq Circle (entget(ssname ssCircle index))index(1+ index)
      radius(cdr(assoc 40 Circle))
      Center(vlax-curve-getClosestPointTo LineObj (cdr(assoc 10 Circle)) t)
      center(if(<(distance Point_01 Center)radius)Point_01
       (if(<(distance Point_02 Center)radius)Point_02 Center))
      circle(subst(cons 10 Center)(assoc 10 Circle)Circle)))))))
    (vl-cmdf ".zoom" "p")
    (alert "完成!")
圆心打断.lisp
;; 圆心点打段线
(defun c:dd ()
  (if (and (princ "\n选择圆: ")
           (setq ss (ssget '((0 . "circle")))
                 i  -1
    (while (setq s1 (ssname ss (setq i (1+ i))))
      (setq pc (cdr (assoc 10 (entget s1)))
            j  -1
      (if (setq ss1 (ssget "c" pc pc '((0 . "*line"))))
        (while (setq s2 (ssname ss1 (setq j (1+ j))))
          (command "break" (list s2 pc) pc)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
掉线了。。 CAD2006测试通过批量打断
发表于 2014-1-23 09:12:53 | 显示全部楼层
掉线了。。
CAD2006测试通过批量打断
  1. (defun c:ny(/ center circle index lineobj point point_01 point_02 radius ssline syh center_lst)
  2.   (vl-load-com)
  3.   (setvar "cmdecho" 0)
  4.   (princ "\n请选取要处理的直线对象")
  5.   (if(setq ssLine (ssget '((0 . "LINE"))))
  6.     (progn (setq syh 0)
  7.       (vl-cmdf ".zoom" "e")
  8.       (repeat (sslength ssLine)
  9. (entmod(setq LineObj(ssname ssLine syh)syh(1+ syh)
  10.        point(entget LineObj)
  11.        LineObj(vlax-ename->vla-object LineObj)
  12.        Point_01(cdr(assoc 10 point))
  13.        Point_01(list(car Point_01)(cadr Point_01)0)
  14.        Point_02(cdr(assoc 11 point))
  15.        Point_02(list(car Point_02)(cadr Point_02)0)
  16.        point(subst(cons 10 Point_01)(assoc 10 point)point)
  17.        point(subst(cons 11 Point_02)(assoc 11 point)point)))
  18. (if(setq ssCircle(ssget"F"(list Point_01 Point_02)'((0 . "CIRCLE"))))
  19.    (progn (setq index 0 center_lst '())
  20.      (repeat (sslength ssCircle)
  21.        (entmod(setq Circle (entget(ssname ssCircle index))index(1+ index)
  22.       radius(cdr(assoc 40 Circle))
  23.       Center(vlax-curve-getClosestPointTo LineObj (cdr(assoc 10 Circle)) t)
  24.       center(if(<(distance Point_01 Center)radius)Point_01
  25.        (if(<(distance Point_02 Center)radius)Point_02 Center))
  26.       circle(subst(cons 10 Center)(assoc 10 Circle)Circle)))
  27.        (setq center_lst (cons Center center_lst))
  28.        )
  29.      (if (/= center_lst '())(mapcar '(lambda(x)(vl-cmdf "_.break" x  x )) center_lst))
  30.      )))
  31.     (vl-cmdf ".zoom" "p")
  32.     (alert "完成!")
  33.     ))
  34.   (princ)
  35.   )
参与人数 1明经币 +1 金钱 +6 收起 理由
xskfq + 1 + 6
发表于 2014-1-23 09:36:29 | 显示全部楼层
  1.   (defun c:ny(/ center circle index lineobj point point_01 point_02 radius ssline syh)
  2.   (vl-load-com)
  19.    (progn (setq index 0)
  26.       circle(subst(cons 10 Center)(assoc 10 Circle)Circle))))
  27.      (entmod(subst(cons 10 Center)(assoc 10 point)point))
  28.      (entmake(list'(0 . "LINE")(assoc 67 point)(assoc 8 point)(assoc 6 point)(assoc 10 point)(cons 11 Center)))
  29.      )))
  30.     (vl-cmdf ".zoom" "p")
  31.     (alert "完成!")
  32.     ))
  33.   (princ)
  34.   )
如果一条线上有多个圆它好象会出问题,不清楚你具体的情况是怎么样
出错了,再帮看看,谢谢  发表于 2014-1-23 10:04
发表于 2014-1-23 09:49:10 | 显示全部楼层
  • ;; 圆心点打段线
    (defun c:dd ( / box box1 box2 center ed i j lineobj pc s1 ss ss1)(vl-load-com)
      (defun MTL-objBox (obj / Minp Maxp)
             (vla-GetBoundingBox obj 'Minp 'Maxp)
             (mapcar 'vlax-safearray->list (list Minp Maxp))
                     i  -1
               (setq box (MTL-objBox (vlax-ename->vla-object s1))
                     box1 (car box)
                     box2 (cadr box)
                     ed (entget s1)
                     pc (cdr (assoc 10 ed))
                      j  -1
          (if (setq ss1 (ssget "c" box1 box2 '((0 . "*line"))))
            (progn (while (setq LineObj (ssname ss1 (setq j (1+ j))))
                          (setq Center (vlax-curve-getClosestPointTo LineObj pc t))
                          (entmod (subst (cons  10 Center) (assoc 10 ed) ed))
                          (command "break" (list LineObj Center) Center)
 楼主| 发表于 2014-1-23 10:16:57 | 显示全部楼层
cable2004 发表于 2014-1-23 09:49
  • ;; 圆心点打段线
    (defun c:dd ( / box box1 box2 center ed i j lineobj pc s1 ss ss1)(vl-load-com) ...
  • 新程序啊,能实现,谢谢!!。
    不过我想要原程序合并。。
     楼主| 发表于 2014-1-23 11:11:38 | 显示全部楼层
    不好合并吗?
    发表于 2014-1-23 11:52:57 | 显示全部楼层
    不知道什么是合并!总之是合并2个功能!
     楼主| 发表于 2014-1-23 14:32:16 | 显示全部楼层
    cable2004 发表于 2014-1-23 11:52
    不知道什么是合并!总之是合并2个功能!
    速度没有原版快
    发表于 2014-1-23 19:04:37 | 显示全部楼层
    2.   (vl-load-com)
    27.        (vl-cmdf "break" (list (vlax-vla-object->ename LineObj) Center) Center)
    28.        ))))
    29.     (vl-cmdf ".zoom" "p")
    30.     (alert "完成!")
    31.     ))
    32.   (princ)
    33.   )
    发表于 2014-1-23 19:14:18 | 显示全部楼层
    entmake打断版本
    比break命令要要些。
    2.   (vl-load-com)
    28.      (entmake (subst(cons 11 Center)(assoc 11 point)point))
    29.      (entmake (subst(cons 10 Center)(assoc 10 point)point))
    30.      )))
    32.     (alert "完成!")
    33.     ))
    34.   (princ)
    35.   )
    GMT+8, 2025-7-2 00:03 , Processed in 0.224671 second(s), 35 queries , Gzip On.
