楼主: 品茗新秀
[已解答] 求想打开关闭图层的某个图层,
发表于 2014-3-30 11:37:42 来自手机 | 显示全部楼层
楼主你还初学胡扯蛋………哥不会就说不会……虚伪滴过份……你别回老子的贴
发表于 2014-3-30 15:55:42 | 显示全部楼层
  1. (defun c:tt(/ stb makedcl layonoff lst- dcl lys lysoff lys on ctl a)
  2.   (Defun STB(TAB / snl sll)
  3.     (SetQ snl '()sll (TblNext TAB T))
  4.     (While (SetQ snl (Cons (Cdr (Assoc 2 sll)) snl)sll (TblNext TAB nil)))
  5.     (vl-sort (vl-remove'nil snl)'<))
  6.   (defun makedcl(str_lst / dclfile fileID dclHandle)
  7.     (setq  dclfile(vl-filename-mktemp nil nil ".dcl")fileID(open dclfile "w"))
  8.     (cond((= (type str_lst) 'str)(write-line str_lst fileID))
  9.    ((= (type str_lst) 'list)(foreach n str_lst (write-line n fileID))))
  10.     (close fileID)
  11.     (setq dclHandle(load_dialog dclfile))
  12.     (vl-file-delete dclfile)
  13.     dclHandle)
  14.   (defun layonoff(la onoff / co)
  15.     (setq la(entget(TBLOBJNAME"layer" la))co(assoc 62 la))
  16.     (entmod(subst(cons 62(if onoff(abs(cdr co))(- 0(abs(cdr co)))))co la)))
  17.   (defun getvalue()
  18.     (foreach x(read(strcat"("(get_tile"on")")"))(layonoff(nth x lysoff)t))
  19.     (foreach x(read(strcat"("(get_tile"off")")"))(layonoff(nth x lyson)nil)))
  20.   (defun lst-(lst lst1)
  21.     (foreach x lst1(setq lst(vl-remove x lst)))lst)
  22.   (setq  lys(stb"LAYER")ctl 3)
  23.   (while(> ctl 0)
  24.     (setq lysoff(vl-remove'nil(mapcar'(lambda(x)(if(<(cdr(assoc 62(tblsearch"layer"x)))0)x))lys))
  25.     lyson(LST- lys lysoff)
  26.     dcl(makedcl(list"LAYLIST:dialog{ label=\"~开关图层~\";:boxed_column{:row{"
  27.          (strcat":list_box{label=\"可关闭图层\";key=\"off\";fixed_width=8;height="
  28.           (itoa(+(max(length lysoff)(length lyson))2))";multiple_select = true;}")
  29.          ":list_box{label=\"可打开图层\";key=\"on\";fixed_width=8;height=1;multiple_select = true;}}"
  30.          ":row{:button{key=\"GO\";label=\"执行\";}:button{key=\"ESC\";label=\"退出\";is_cancel=true;}}}}")))
  31.     (new_dialog "LAYLIST" dcl)
  32.     (start_list"on")(mapcar 'add_list lysoff)(end_list)
  33.     (start_list"off")(mapcar 'add_list lyson)(end_list)
  34.     (action_tile "GO""(getvalue)(done_dialog 1)")
  35.     (action_tile"ESC""(done_dialog 0)")
  36.     (setq ctl(start_dialog))
  37.     (unload_dialog dcl)))
纯属好玩,没多大实际上用处, 我自己这么觉得
品茗新秀 + 1 赞一个!
 楼主| 发表于 2014-3-30 18:16:01 | 显示全部楼层
如果能通过选关闭中的图元来打开才好,因为通过众多图层名,一般难确定需打开哪个图层
关闭的图层那是看不到的所以不可能点选到上边的图元  发表于 2014-3-30 20:09
发表于 2014-3-30 19:15:53 | 显示全部楼层
...通过选关闭中的图元来打开才好...
可見乎!?
 楼主| 发表于 2014-3-30 22:21:20 | 显示全部楼层
可見乎!?
我以前曾看到过,执行程序,被关闭的图元显示,选择要打的图元,则该图元的图层被打开,和其它原打开的图层一起显示,目前网上多数程序是通过图层名来选择打开,对于实际运用,不是十分方便。
 楼主| 发表于 2014-3-30 22:25:15 | 显示全部楼层
这个程序的思路可能应该是打开所有关闭图层,然后点选打开的关闭图层,则其它未被选择打开的关闭图层关闭。
发表于 2014-3-30 23:19:56 | 显示全部楼层
这样倒也还可行得通
发表于 2014-3-30 23:22:22 | 显示全部楼层
也可以改下,先打开所有图层,选择一堆图元后恢复图层。再列出哪些图层本来是关闭的,哪些本来是开着的,根据需要进行开头选择,没选到图元的图层不列出来,空了我再弄下玩玩
发表于 2014-3-31 06:08:13 | 显示全部楼层
论坛里搜索一下就有,何必再编程?
发表于 2014-3-31 06:45:44 | 显示全部楼层
关闭图层是没法点取的,输入图层名是可以的...
(defun c:tt (/ la)
(setq la (getstring "\n输入要打开的图层名:"))
(vl-cmdf "-layer" "on" la "" "")
GMT+8, 2025-12-31 13:50 , Processed in 0.169419 second(s), 19 queries , Gzip On.
