楼主: 荒野孤行
[源码] 自制工具箱的自定义快捷键程序
发表于 2014-6-10 07:53:52 | 显示全部楼层
l
  1. (setq lst1 (list wdy501 wdy502 wdy503 wdy504 wdy505))
  2. (setq lst2 (list wdy_zf wdy_ff wdy_py wdy_sy wdy_yy))
  3. (mapcar
  4. '(lambda (x y)
  5.   (setq a (eval(read(strcat "reg_" (vl-princ-to-string x)))))
  6.   (if a (eval(read(strcat "(defun c:" a "() (" (vl-princ-to-string y) "))"))))
  7. )
  8. lst1
  9. lst2
  10. )
还不行,Z版 lst1和lst2的值成了(nil nil nil nil nil)  发表于 2014-6-10 08:04
发表于 2014-6-9 21:47:19 | 显示全部楼层
建议采用这样的方便控制。
  1. (setq lst(list(cons "wdy03" "wdy_zz")(cons "wdy04" "wdy_za")(cons "wdy05" "wdy_zb")))
  2. (mapcar '(lambda(x)(princ(strcat "(defun c:" (car x) "() (" (cdr x) "))"))) lst)
发表于 2014-6-9 21:35:15 | 显示全部楼层
(setq lst2 (list "wdy_zf" "wdy_ff" "wdy_py" "wdy_sy" "wdy_yy"))
(mapcar '(lambda (x y)(eval (read (strcat "(defun c:" x "() (" y "))")))
lst1 lst2
GMT+8, 2026-1-17 14:27 , Processed in 0.755439 second(s), 20 queries , Gzip On.
