楼主: HGQ8888
[已解答] 外挂突然"no function definition",版主救命...................
发表于 2014-6-11 20:29:13 | 显示全部楼层
HGQ8888 发表于 2014-6-11 20:19
那奇怪了,我明明把系统日期调到2030年测评过没事的啊
我没仔细看,晚饭喝了点酒,要不我把注册日期有关的函数给发上来;我知道是谁写的,但在不清楚真相之前不好说。
  1. (defun TEST_REGX ()
  2.   (setq WDATE (GETVAR "cdate"))
  3.   (setq        Y_DATE (VL-REGISTRY-READ
  4.                  "HKEY_LOCAL_MACHINE\\SOFTWARE\\Y_Cwmold\\R15"
  5.                  "date"
  6.                )
  7.   )
  8.   (setq        Y1_DATE        (VL-REGISTRY-READ
  9.                   (STRCAT "HKEY_LOCAL_MACHINE\" (vlax-product-key))
  10.                   "Information"
  11.                 )
  12.   )
  13.   (setq        Y2_DATE        (VL-REGISTRY-READ
  14.                   (STRCAT "HKEY_CURRENT_USER\" (vlax-product-key))
  15.                   "Information"
  16.                 )
  17.   )
  18.   (setq Y_DATE_ORG Y_DATE)
  19.   (if (= 1
  20.          (- (ATOI (SUBSTR Y_DATE 1 4)) (ATOI (SUBSTR Y1_DATE 1 4)))
  21.       )
  22.     (setq Y_DATE (STRCAT (SUBSTR Y1_DATE 1 4)
  23.                          (ITOA (+ 12 (ATOI (SUBSTR Y_DATE 5 2))))
  24.                          (SUBSTR Y_DATE 7)
  25.                  )
  26.     )
  27.   )
  28.   (if (FINDFILE "ymold_pass.fas")
  29.     (LOAD "ymold_pass.fas")
  30.     (progn (setq Y_MOLD (STRCAT (GETVAR "acadver") "-" (GETVAR "_linfo")))
  31.            (setq MHZ nil)
  32.            (setq CPU
  33.                   (VL-REGISTRY-READ
  34.                     "HKEY_LOCAL_MACHINE\\HARDWARE\\DESCRIPTION\\System\\CentralProcessor\\0"
  35.                     "ProcessorNameString"
  36.                   )
  37.            )
  38.            (setq CPUVER
  39.                   (VL-REGISTRY-READ
  40.                     "HKEY_LOCAL_MACHINE\\HARDWARE\\DESCRIPTION\\System\\CentralProcessor\\0"
  41.                     "VendorIdentifier"
  42.                   )
  43.            )
  44.            (setq ACAD_VER (GETVAR "acadver"))
  45.     )
  46.   )
  47.   (COND
  48.     ((and (= Y_MOLD (STRCAT (GETVAR "acadver") "-" (GETVAR "_linfo")))
  49.           (= "SuperPro" (SUBSTR (GETVAR "_linfo") 1 8))
  50.      )
  51.      (PRIN1)
  52.     )
  53.     ((and
  54.        (=
  55.          CPU
  56.          (VL-REGISTRY-READ
  57.            "HKEY_LOCAL_MACHINE\\HARDWARE\\DESCRIPTION\\System\\CentralProcessor\\0"
  58.            "ProcessorNameString"
  59.          )
  60.        )
  61.        (=
  62.          CPUVER
  63.          (VL-REGISTRY-READ
  64.            "HKEY_LOCAL_MACHINE\\HARDWARE\\DESCRIPTION\\System\\CentralProcessor\\0"
  65.            "VendorIdentifier"
  66.          )
  67.        )
  68.        (= ACAD_VER (GETVAR "acadver"))
  69.      )
  70.      (PRIN1)
  71.     )
  72.     ((> (ATOF Y_DATE) WDATE)
  73.      (if (and (>= (- (ATOF Y_DATE) (ATOF Y1_DATE)) 0)
  74.               (< (- (ATOF Y_DATE) (ATOF Y1_DATE)) 300)
  75.          )
  76.        (SETVAR "modemacro" "刚ノ戳骸")
  77.        (progn (SETVAR "modemacro" "刚ノ戳骸")
  78.               (PRINC "\n刚ノ戳(3る)筁,磅︽硉穦搭絯!!!")
  79.        )
  80.      )
  81.      (while (< (- (GETVAR "cdate") WDATE) 1.0e-006) nil)
  82.     )
  83.     ((and (>= (- (ATOF Y_DATE) (ATOF Y1_DATE)) 0)
  84.           (< (- (ATOF Y_DATE) (ATOF Y1_DATE)) 300)
  85.           (= Y1_DATE Y2_DATE)
  86.      )
  87.      (SETVAR "modemacro" "刚ノ")
  88.     )
  89.     (T
  90.      (SETVAR "modemacro" "刚ノ戳骸")
  91.      (PRINC "\n刚ノ戳(3る)筁,磅︽硉穦搭絯!!!")
  92.      (while (< (- (GETVAR "cdate") WDATE) 1.0e-006) nil)
  93.     )
  94.   )
  95. )
 楼主| 发表于 2014-6-11 20:33:20 | 显示全部楼层
nzl1116 发表于 2014-6-11 20:15
大概看了下,是有和日期有关的,存储在注册表里,你油箱多少,我发你源码
谢谢!邮件收到了.请查看邮件再帮忙处理下.十分感谢!
 楼主| 发表于 2014-6-11 20:35:54 | 显示全部楼层
nzl1116 发表于 2014-6-11 20:29
我没仔细看,晚饭喝了点酒,要不我把注册日期有关的函数给发上来;我知道是谁写的,但在不清楚真相之前不 ...
查看注册标的确原程序有这有这样的动做.
GMT+8, 2025-11-1 08:10 , Processed in 0.160593 second(s), 19 queries , Gzip On.
