楼主: 行空雕
求助:VBA创建的非模态界面与CAD干涉
 楼主| 发表于 2014-7-29 08:04:36 | 显示全部楼层
没法做,打算采用链接
发表于 2014-10-12 23:11:00 | 显示全部楼层
用API试试看
Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long
Declare Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal cch As Long) As Long
Declare Function EnumWindows Lib "user32" (ByVal lpEnumFunc As Long, ByVal lParam As Long) As Long
Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Dim ThisHwnd As Long
Public sCurrentCaption As String
Private Sub UserForm_Activate()
    sCurrentCaption = BatPlot.Caption
    Call EnumWindows(AddressOf EnumWindowsProc, vbNull)
    Call SubClass
End Sub
Function EnumWindowsProc(ByVal hwnd As Long, ByVal lParam As Long) As Integer
    Dim title As String * 32
    Call GetWindowText(hwnd, ByVal title, 32)
'    If InStr(title, "示例窗体") Then      '根据窗体的"Caption"值来枚举
    If InStr(title, sCurrentCaption) Then
        ThisHwnd = hwnd              '已找到窗体,则退出
        EnumWindowsProc = False
    Else
        EnumWindowsProc = True       '未找到,继续枚举
    End If
End Function
Public Function SubClass() As Long
    Dim flags As Long
    flags = GetWindowLong(ThisHwnd, GWL_STYLE)
    flags = flags Xor WS_POPUP
    SetWindowLong ThisHwnd, GWL_STYLE, flags
End Function
不知道你的具体情况,你只能试试
发表于 2014-10-15 14:46:06 | 显示全部楼层
在窗口加载时重新设置一下窗口的父窗口为CAD主窗口就行了用setparent
发表于 2014-10-15 15:21:41 | 显示全部楼层
窗口的Initialze事件里加上一句
SetParent FindWindow(vbNullString, Me.Caption),Application.hwnd
这两个API函数你自己声明一下就行了
 楼主| 发表于 2015-1-26 23:50:25 | 显示全部楼层
wwswwswws 发表于 2014-10-12 23:11
用API试试看
Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ...
谢谢! API 还不太会,目前是学习中,多谢
 楼主| 发表于 2015-1-26 23:51:25 | 显示全部楼层
wuyunpeng888 发表于 2014-10-15 15:21
窗口的Initialze事件里加上一句
这两 ...
我试试,谢谢您的指教,
发表于 2018-12-30 03:43:03 | 显示全部楼层
窗口的Initialze事件里加上一句
这两 ...
正解,多谢大神。
发表于 2024-12-27 00:17:05 | 显示全部楼层
其实这个并不是正解,最正确的是用API函数把弹出窗口的属性去掉
发表于 2024-12-27 00:20:15 | 显示全部楼层
flags = GetWindowLong(FindWindow(vbNullString, Me.Caption), GWL_STYLE)
SetWindowLong FindWindow(vbNullString, Me.Caption), GWL_STYLE, flags
GMT+8, 2026-1-11 18:33 , Processed in 0.138330 second(s), 16 queries , Gzip On.
