- 积分
- 8355
- 明经币
- 个
- 注册时间
- 2006-7-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2014-8-26 11:34:07
显示全部楼层
2004版本要装et才行的
FULLSCREEN
Resizes the drawing screen to a maximum area. Hides the title bar and the menu bar in the AutoCAD window.
The FULLSCREEN command switches the screen size between normal and full screen.
To display the AutoCAD menu bar while you are working in Full-screen mode, move the pointer to the top of the screen. When the pointer icon changes to include an image of a finger on a mouse button, click once to display the menu bar. The menu bar disappears after you make a selection. You can also display a menu with the standard keyboard shortcut methods (Alt+F for the File menu, Alt+D for the Draw menu, and so on).
The FULLSCREENOPTIONS command displays the Fullscreen Options dialog box. From here you can turn the display of the status bar on and off, while FULLSCREEN is active.
Command line: FULLSCREEN, FULLSCREENON, FULLSCREENOFF, FULLSCREENOPTIONS |
