查看: 1353|回复: 5
[提问] 直接按比例画图形
发表于 2015-2-12 13:16:59 | 显示全部楼层 |阅读模式
直接按比例画图形。比如画园,正方形时先要求输入一个比例值,然后程序按这个比例画出图形,这样的程序如何写
 楼主| 发表于 2015-2-12 14:05:37 | 显示全部楼层
(defun C:test(/ pt1 pt2 scale)
   ;;保存系统变量设置
  (setq old_OS  (getvar "OSMODE")
      old_CMD (getvar "CMDECHO")
       old_OR (getvar "OrthoMode")
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  ;(setvar "OrthoMode" 0)
  (setq scale (getreal "\nScale<100>:"))
        (if (= scale nil)
                (setq scale 100)
  (setq pt1 (getpoint "\nFirst point:"))
  (setq pt2 (getpoint pt1 "\nSecond point:"))
          (command "rectang" pt1 pt2 "")
            (ssadd (entlast) door)
(command "SCALE" door "" pt1 "scale")
   ;;恢复系统变量设置
    (setvar "CMDECHO" old_CMD)
    (setvar "OSMODE" old_OS)
    (setvar "OrthoMode" old_OR)
  (princ)(princ)
没人出手,我自己写了一个,在两句(ssadd (entlast) door)
(command "SCALE" door "" pt1 "scale") 好像有点问题,请高手看看
发表于 2015-2-12 14:08:47 | 显示全部楼层
check 'CmdActive
发表于 2015-2-12 14:15:07 | 显示全部楼层
  1. (setq scale (getreal "\nScale<100>:"))
  2.         (if (= scale nil)
  3.                 (setq scale 100)
  4.         )
  5.   (setq pt1 (getpoint "\nFirst point:"))
  6.   (setq pt2 (getpoint pt1 "\nSecond point:"))
  7.           (command "rectang" pt1 pt2 )
  8.             (setq door (entlast))
  9. (command "SCALE" door "" pt1 scale )
 楼主| 发表于 2015-2-12 16:05:18 | 显示全部楼层
谢谢楼上的朋友,还想问一下,如何读取系统变量DIMLFAC的值赋给上面程序中的scale
发表于 2015-2-13 15:47:39 | 显示全部楼层
(setq scale(getvar "DIMLFAC"))
GMT+8, 2025-12-18 04:06 , Processed in 0.180273 second(s), 30 queries , Gzip On.
