查看: 1398|回复: 4
[提问] 程序还有救人么,参数类型错误
发表于 2015-3-2 17:54:09 | 显示全部楼层 |阅读模式
(defun c:tt()
         (setvar "cmdecho" 0)
     (setq old (getvar "OSMODE"))
     (setvar "osmode" 0)
     (command "style" "HZS" "romanc.shx,msi_fsx.shx" "0" "0.7" "0" "n" "n" "N" )
     (command "insert" "E:\\图库\\图库.dwg" "0,0" "1" "" "")
           (entdel(entlast))
          (setq branchpt (getpoint "选择插入点"))
           (setq Lst '(("wl1" "AL1" "单相" "1.44")
            ("wl3" "AL2" "三相" "2")
                        ("wl2" "AL2" "三相" "2")
                ("wl2" "AL1" "单相" "2")
            ("wl3" "AL2" "三相" "5")
            ("wl1" "AL2" "单相" "2")
            ("wl2" "AL2" "单相" "2")
            ("wl3" "AL3" "三相" "2")
            ("wp2" "AL2" "三相" "4")
           (setq Distribution_Box "AL1" )
           (drawing Distribution_Box Lst )
           (setvar "osmode" old)
     (prin1)
(defun drawing ( Distribution_Box Lst )
(setq i 0)
(setq Phase_Number 1)
(repeat (length Lst)
(setq Lst1 (nth i Lst))
(if (and (= (cadr Lst1) Distribution_Box ) (=(caddr Lst1) "单相"))
  (cond
          ( (wcmatch (car Lst) "zm*")
                (progn (setq  Circuit_Breaker "CH2-63C/16/1") (setq Circuit_Name (car Lst))
                (setq Load_Power (cadddr Lst)) (setq Wire&Cable "ZRBV-3x2.5S15FC")
             (branch1  branchpt ))
         ( (wcmatch (car Lst) "byzm*")
               (setq Load_Power (cadddr Lst)) (setq Wire&Cable "ZRBV-4x2.5S25FC")
                    (branch2  branchpt )    )
         ( (wcmatch (car Lst) "cz*")
               (progn (setq Circuit_Breaker "CH2-63C/20/2 30mA") (setq Circuit_Name (car Lst))
               (setq Load_Power (cadddr Lst))  (setq Wire&Cable "ZRBV-3x4S25FC")
                   (branch1  branchpt )     )
(defun branch1 (branchpt)
        (setq pt1 branchpt)
        (setq pt2 (polar pt1 0 750))
        (command "pline" pt1 "H" 17.5 17.5 pt2 "")
        (command "insert" "断路器" pt2 "1500" "" "90" )
        (setq pt3 (polar pt2 0 1500))
        (setq pt4 (polar pt3 0 5250))
        (command "pline" pt3 "H" 17.5 17.5 pt4 "")
        (setq pt5 (polar pt1 0 250))
        (setq pt6 (polar pt5 (* pi 0.5) 120))
    (command "text" "s" "hzs" "j" "bl" pt6 300 0 Circuit_Breaker) ;断路器型号
        (setq pt7 (polar pt6 0 5700))
        (command "text" "s" "hzs" "j" "bl" pt7 300 0 Load_Power);负载功率
        (setq pt8 (polar pt4 0 600))
        (command "text" "s" "hzs" "j" "ml" pt8 300 0 Circuit_Name);回路名称
        (setq pt9 (polar pt4 0 1900))
        (command "text" "s" "hzs" "j" "ml" pt9 300 0 Wire&Cable);导线&电缆
        (setq pt10 (polar pt6 0 4500))
        (command "text" "s" "hzs" "j" "ml" pt10 300 0 Circuit_Phase);回路相位
        (setq branchpt (polar branchpt (* pi -0.5) 750))
(defun Phase ()
(setq Circuit_Phase (strcat (itoa Phase_Number) (nth (rem Phase_Number 3) '("c" "a" "b"))))
(1+ Phase_Number)
请高人看看这个程序哪里错了,还有救么,总提示参数类型错误: stringp ("wl1" "AL1" "单相" "1.44")
关于参数怎么传递,什么时候用全局的,我总是糊涂,真心请教!
发表于 2015-3-2 19:47:47 | 显示全部楼层
(wcmatch (car Lst) "zm*"),这里有问题。(car Lst)得到是一个LIST,("wl1" "AL1" "单相" "1.44")。不能用wcmatch。可以看看帮助。可以自己看着再改改。
 楼主| 发表于 2015-3-2 20:13:05 | 显示全部楼层
谢谢,才开始学习,哪里确实错误了,lst1,我再仔细改改。自己实在检查不出来。
发表于 2015-3-3 08:16:29 | 显示全部楼层
函数branch2没有
循环变量i未增加
函数Phase未运行
发表于 2015-3-3 09:35:16 | 显示全部楼层
(wcmatch (car Lst) "zm*")=(WCMATCH ("wl1" "AL1" "单相" "1.44") "zm*")
出错的时候看vlisp的【视图】-》【错误跟踪】
GMT+8, 2026-1-26 02:00 , Processed in 1.270911 second(s), 30 queries , Gzip On.
