查看: 1234|回复: 2
[已解答] 窗口读取文件调试定义出错
发表于 2015-5-5 21:47:17 | 显示全部楼层 |阅读模式
高手帮忙看下下面这段程序,是读取文件赋值,运行时出现错误: no function definition: STTA,感觉语句没啥问题的
(defun C:readtxt()
(vl-load-com)
;(setq txt_str (getstring "\nfile's name and path :"))
(setq txt_str (getfiled "Select file to Open" "" "txt" 8))
     (setq str_lst nil)
     (setq bb 1)
     (if (setq ff (open txt_str "r"))
            (while (setq data (read-line ff))
               (princ (strcat "\n*** 数据=" data ))
                                (setq str_lst (cons  str_lst data ))
                 (setq stta (nth bb str_lst))
                (princ (strcat "\n*** 数据="  rtos(stta 2 3) ))
             (setq bb (+ bb 1))
         (close ff)
(prin1)
  str_lst
发表于 2015-5-5 21:57:01 | 显示全部楼层
rtos(stta 2 3) ))
 楼主| 发表于 2015-5-5 22:23:46 | 显示全部楼层
鱼与熊掌 发表于 2015-5-5 21:57
rtos(stta 2 3) ))
谢谢,找到原因了
GMT+8, 2025-12-6 07:08 , Processed in 0.184670 second(s), 30 queries , Gzip On.
