楼主: joe
如果取得尺寸文字的字高
发表于 2004-2-17 21:14:00 | 显示全部楼层
可以这样 (setq  bn (cdr (assoc 2 (entget (car (entsel "\n选择标注: "))))))然后 用 (setq blk (tblobjname "block" bn))遍历 blk 找 AcDbMtext 就可以取出字高。一段用来测试的代码
  1. (defun c:test (/ e obj)
  2.    (if (setq e (car (entsel)))
  3.        (progn
  4.            (setq obj  (vlax-ename->vla-object e)
  5.          blk  (vla-item (vla-get-blocks
  6.              (vla-get-activedocument (vlax-get-acad-object))
  7.          )
  8.          (cdr (assoc 2 (entget e)))
  9.     )
  10.            )
  11.            (vlax-for  i blk
  12.   (setq elst (cons (vla-get-objectname i) elst))
  13.            )
  14.        )
  15.    )
  16. )
标注返回的表("AcDbPoint" "AcDbPoint" "AcDbPoint" "AcDbMText" "AcDbBlockReference"
"AcDbBlockReference" "AcDbLine" "AcDbLine" "AcDbLine")从中也可以看出DIM生成的顺序,Line、Line、Line、两边的斜线、数字、点
发表于 2004-2-26 20:37:00 | 显示全部楼层
(defun c:zgg()
(SETQ SS(SSGET '((0 . "dimension"))))
(setq d(entget (ssname ss 0)))
(setq pt (cdr (assoc 11 d)))
(setq zg (cdr(assoc 40 ( entget (car (nentselp pt ))))))
(princ"\n\n字高为: ")
(PRINT zg)
GMT+8, 2025-12-16 15:36 , Processed in 0.166258 second(s), 19 queries , Gzip On.
