楼主: 726613
[已解答] 框选统计圆数量程序改善
发表于 2019-6-13 17:11:56 | 显示全部楼层
太好了,大侠啊
发表于 2019-8-19 13:45:45 | 显示全部楼层
改为插入CAD这么写
发表于 2019-8-31 15:58:16 | 显示全部楼层
怎么以表格方式统计?大师们
发表于 2019-9-5 02:12:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2020-11-28 14:43:11 | 显示全部楼层
(defun c:YGS (/ AS D DD DNS FS GET GV K KS LEN NN S ST)
  (princ "\n功能 [统计圆直径数量弹窗]")
  (setq gv (getvar "dimzin"))
  (setvar 'dimzin 8)
  (if (setq get (ssget '((0 . "CIRCLE"))))
      (setq Len (sslength get) k 1)
      (repeat Len
  (setq nn (ssname get (setq Len (1- Len)))
        as (cdr (assoc 40 (entget nn)))
  as (atof (rtos as 2 2))
  (if (null (setq dd (assoc as Dns)))
    (setq Dns (cons (list as k) Dns))
    (setq Dns (subst (list as (1+ (cadr dd))) (assoc as Dns) Dns))
      (foreach x Dns
  (setq d   (car x)
        s   (cadr x)
        st (strcat "直径"
       (rtos (* d 2) 2 2)
       ",数量"
       (rtos s 2 2)
       "\n"
        ks (cons (list st) ks)
      (setq fs (apply 'strcat (mapcar 'car ks)))
      ;(alert fs)
(setq po (getpoint "input point----:"))
(command "text" po "2" "" FS"")
;(setq wz1 (entlast))
;(command "DDEDIT" wz1 "" "")
  (setvar 'dimzin gv)
回复 支持 1 反对 1
发表于 2020-11-29 12:28:46 | 显示全部楼层
能不能扩展到多段线的圆
发表于 2020-11-30 18:04:16 | 显示全部楼层
  1. ;; tt(框选统计圆数量)
  2. (defun c:tt () (if (and (setq ss (ssget '((0 . "CIRCLE")))i  -1)
  3.            (setq p0 (getpoint "\n基点<退出>: "))
  4.       )
  5.     (setq lst (xyp-Ss2List ss)
  6.           lst (mapcar '(lambda (x) (xyp-DXF 40 x)) lst)
  7.           lst (xyp-List-Count lst)
  8.           aa  (xyp-TableAuto p0 lst '("序号" "圆半径" "数量"))
  9.     )
  10.   )
  11.   (princ)
  12. )
发表于 2020-12-2 08:20:52 | 显示全部楼层
能不能扩展到更改为多段线的圆
发表于 2023-7-1 20:57:50 | 显示全部楼层
大哥,不要弹窗,写进CAD里面要怎么改?
GMT+8, 2026-1-26 20:37 , Processed in 0.883104 second(s), 20 queries , Gzip On.
