楼主: 远方小山
[提问] 检测多段线的起点和终点是否在其个直线上
发表于 2016-3-8 19:20:59 | 显示全部楼层
  1. (defun c:tes ( / #os1 &k1 &kw1 &ob1 &p1 @p1 @p2)
  2. (if (null vlax-dump-object) (vl-load-com) )
  3. (setq #os1 (getvar "osmode"))
  4. (if (setq &kw1 (ssget '((0 . "LWPOLYLINE"))))
  5.   (progn
  6.    (setvar "osmode" 0)
  7.    (while (setq &k1 (ssname &kw1 0))
  8.     (setq &kw1 (ssdel &k1 &kw1) &ob1 (vlax-ename->vla-object &k1))
  9.     (foreach &p1 (list (vlax-curve-getStartPoint &ob1);起点
  10.                        (vlax-curve-getEndPoint &ob1);端点
  11.                  )
  12.      (setq @p1 (polar &p1 (* 1.25 pi) (* (expt 2 0.5) 0.5))
  13.            @p2 (polar &p1 (* 0.25 pi) (* (expt 2 0.5) 0.5)))
  14.      (if (< (sslength (ssget "c" @p1 @p2 '((0 . "LINE,LWPOLYLINE")))) 2);如果少于2线
  15.       (entmake (list '(0 . "CIRCLE") '(62 . 1) (cons 10 &p1) '(40 . 50)));绘制红色,半径50的圆
  16.      );if
  17.     );foreach
  18.    );while
  19.    (setvar "osmode" #os1)
  20.   )
  21. )
  22. (princ)
  23. )
发表于 2016-3-8 19:40:18 | 显示全部楼层
远方小山 发表于 2016-3-8 18:34
我试了下,这个代码有出现错误,我查了用法,没有错啊,求大神指点
(if (and (setq xx (ssget "_cp"
_cp用错了,直接改成_c即可
GMT+8, 2026-1-21 12:45 , Processed in 0.158239 second(s), 20 queries , Gzip On.
