楼主: tryhi
[函数] 拖进绘图区域自动加载至启动组
发表于 2020-12-3 12:08:57 | 显示全部楼层
好东西,留个脚印
发表于 2022-12-5 18:46:02 | 显示全部楼层
感谢海哥分享~
发表于 2023-4-14 16:02:10 | 显示全部楼层
很好的功能!多谢分享!
发表于 2023-4-14 17:43:25 | 显示全部楼层
路过学习了
发表于 2023-5-10 10:58:30 | 显示全部楼层
不知道是不是电脑的问题,昨天拖入黑屏,重启后启动组里一直没有拖入的文件。
发表于 2023-10-19 10:15:14 | 显示全部楼层
  必须给海哥一个赞
发表于 2023-10-23 15:58:43 | 显示全部楼层
路过学习了
发表于 2024-6-10 18:54:49 | 显示全部楼层
楼主的代码,我,加载不成功。我用下面的代码,加载成功
(vl-load-com)
(defun try-tuo-path(/ path str)
        (princ "\n")
        (setq path (getvar "lastprompt"));读取拖进黑框的路径
        (if (wcmatch (strcase path) "*(LOAD \"*")
                (setq str (vl-string-search "(LOAD \"" path)
                        path (substr path (+ str 8) (- (vl-string-search "\")" path) str 7))
        (vl-string-translate "/" "\\" path)
;(gps->appload-addfile "d:\\12.lsp")
(defun gps->appload-addfile (AppName /  $skey numstartup)
(if (= (type appname) 'STR)
  (setq  $skey (strcat "HKEY_CURRENT_USER\\"
                         (vlax-product-key)
                         "\\Profiles\\"
                         (getvar "CPROFILE")
                         "\\Dialogs\\Appload\\Startup")
  (setq NumStartup (vl-registry-read $skey "NumStartup"))
  (if NumStartup
    (vl-registry-write $skey (strcat (itoa (+ 1 (atoi NumStartup))) "Startup") AppName)
    (vl-registry-write $skey "NumStartup"(strcat (itoa (+ 1 (atoi NumStartup)))))
        (vl-registry-write $skey "0Startup" AppName)
    (vl-registry-write $skey "NumStartup" "1")
T
nil
(gps->appload-addfile (try-tuo-path))
参与人数 1明经币 +1 金钱 +5 收起 理由
tryhi + 1 + 5 赞一个!
GMT+8, 2026-1-16 15:59 , Processed in 0.197679 second(s), 20 queries , Gzip On.
