楼主: 皇上快溜
[提问] 这个程序有时会漏选
发表于 2016-9-14 22:54:08 | 显示全部楼层
  1. ;; tt(圆或弧统计);; [url]http://bbs.mjtd.com/thread-173339-1-1.html[/url]
  2. (defun c:tt ()
  3.   (setq        p4  (getpoint "\n请输入图框左下角: ")
  4.         p5  (getcorner p4 "\n请输入图框右上角: ")
  5.         p1  (getpoint "\n请输入要统计的左下角: ")
  6.         p0  (getcorner p1 "\n请输入要统计的右上角: ")
  7.         p3  (getpoint "\n请输入统计文字位置: ")
  8.         p8  (getpoint "\n请输入座标放置位置: ")
  9.         x1  (car p1)
  10.         y1  (cadr p1)
  11.         x4  (car p4)
  12.         x5  (car p5)
  13.         w   (- x5 x4)
  14.         h   (* (/ w 280 1.) 2)
  15.         p9  (polar p8 0 (* 4 h))
  16.         p10 (polar p8 0 (* 14 h))
  17.         p11 (polar p8 0 (* 22 h))
  18.         p12 (polar p8 (* 1.5 pi) h)
  19.         p13 (polar p11 (* 1.5 pi) h)
  20.   )
  21.   (command "line" p12 p13 "")
  22.   (command "text" "ml" p9 h 0 "X")
  23.   (command "text" "ml" p10 h 0 "Y")
  24.   (setq        txt "ABCDEFGHIJKLMNOPQ"
  25.         ss  (ssget "w" p1 p0 '((0 . "arc,circle")))
  26.         i   1
  27.         pt  p3
  28.   )
  29.   (while (and ss (> (sslength ss) 0))
  30.     (setq en (ssname ss 0))
  31.     (setq end (entget en))
  32.     (setq rad (+ (cdr (assoc 40 end)) 0.000))
  33.     (setq pci (cdr (assoc 0 end)))
  34.     (setq d (rtos (* 2 rad)))
  35.     (setq ssa (ssget "w" p1 p0 (list (cons 40 rad) (cons 0 pci))))
  36.     (setq nn (sslength ssa))
  37.     (setq stxt (substr txt i 1))
  38.     (setq m 0)
  39.     (setq x 0)
  40.      (repeat nn
  41.       (setq een (ssname ssa m))
  42.       (setq eend (entget een))
  43.       (setq cen (cdr (assoc 10 eend)))
  44.       (setq xxx (- (+ (car cen)) x1))
  45.       (setq yyy (- (+ (cadr cen)) y1))
  46.       (setq xxxt (rtos xxx))
  47.       (setq yyyt (rtos yyy))
  48.       (setq ssb (ssget "x" (list (cons 10 cen))))
  49.       (setq nnn (sslength ssb))
  50.       (if (= nnn 2)
  51.         (progn
  52.           (setq f (ssname ssb 0))
  53.           (setq g (ssname ssb 1))
  54.           (setq fn (entget f))
  55.           (setq gn (entget g))
  56.           (setq radf (+ (cdr (assoc 40 fn)) 0.000))
  57.           (setq radg (+ (cdr (assoc 40 gn)) 0.000))
  58.           (setq radma (max radf radg))
  59.           (setq radmi (min radf radg))
  60.           (setq p2 (polar cen (* 1.75 pi) (+ 4 radma)))
  61.           (if (= rad radf)
  62.             (setq ss (ssdel g ss))
  63.             (setq ss (ssdel f ss))
  64.           )
  65.           (if (= rad radf)
  66.             (setq hn fn)
  67.             (setq hn gn)
  68.           )
  69.           (setq ty (cdr (assoc 0 hn)))
  70.           (setq dma (rtos (* 2 radma)))
  71.           (setq dmi (rtos (* 2 radmi)))
  72.           (if (= ty "CIRCLE")
  73.             (setq sssstxt (strcat " %%c" dma "<CB>"))
  74.             (setq sssstxt (strcat " M" dma))
  75.           )
  76.           (setq ssstxt (strcat "-%%C" dmi "<THR>" sssstxt))
  77.         )
  78.         (setq p2     (polar cen (* 1.75 pi) (+ 3 rad))
  79.               ssstxt (strcat "-%%C" (rtos (* 2 rad) 2 3) "<THR>")
  80.         )
  81.       )
  82.       (setq x (+ 1 x))
  83.       (setq xt (itoa x))
  84.       (setq xtxt (strcat stxt xt))
  85.       (setq xxxxt (strcat xtxt ":"))
  86.       (command "text" "ml" p2 h 0 xtxt)
  87.       (setq p8 (polar p8 (* 1.5 pi) (* 2 h)))
  88.       (setq p9 (polar p9 (* 1.5 pi) (* 2 h)))
  89.       (setq p10 (polar p10 (* 1.5 pi) (* 2 h)))
  90.       (setq p11 (polar p11 (* 1.5 pi) (* 2 h)))
  91.       (command "line"
  92.                (polar p8 (* 1.5 pi) h)
  93.                (polar p11 (* 1.5 pi) h)
  94.                ""
  95.       )
  96.       (command "text" "ml" p8 h 0 xxxxt)
  97.       (command "text" "ml" p9 h 0 xxxt)
  98.       (command "text" "ml" p10 h 0 yyyt)
  99.       (setq ss (ssdel een ss))
  100.       (setq m (+ 1 m))
  101.     )
  102.      (setq sstxt (strcat stxt " : " (itoa nn) ssstxt))
  103.     (command "text" "ml" pt h 0 sstxt)
  104.     (setq i (+ i 1))
  105.     (setq pt (polar pt (* 1.5 pi) (* 1.5 h)))
  106.   )
  107.   (princ)
  108. )
 楼主| 发表于 2016-9-14 23:12:49 | 显示全部楼层
态感谢xyp1964了,这么长的代码,幸苦你了。 因为网页有点问题,没法引用你的帖子回复你。
程序还是有点问题,统计到第二种r值的圆弧,就不再往下统计
我觉得可就跟圆弧有关,它有个识别螺纹的功能,270度圆弧那种,,,,(setq sssstxt (strcat " M" dma)
我试图从这里(setq sssstxt (strcat " M" dma)往上找,找不出关键函数在哪里
发表于 2016-9-18 14:44:41 来自手机 | 显示全部楼层
(defun c:tjj ()
  (setvar "cmdecho" 0)
  (setvar "osmode" 1)
  (command "osnapcoord" 2)
  (command "ucs" "w")
  ;(command "layer" "s" "txt" "");; 没有这个层就去掉吧
;;;  (setq p4 (getpoint "\n 请输入图框左下角:")) 只是为了取字高 可以和P1 P0共用 减少操作吧
;;;  (setq p5 (getpoint "\n 请输入图框右上角:"))
  (setq p1 (getpoint "\n 请输入图框左下角:"))
  (setq        x1 (car p1)
        y1 (cadr p1)
  (setq p0 (getcorner p1 "\n 请输入图框右上角:"));;;可以用这个带有特效的
  (setq p3 (getpoint "\n 请输入统计文字位置:"))
  (setq        x4 (car p1);;;;
        x5 (car p0);;;;
  (setq w (- x5 x4))
  (setq h (* (/ w 280) 2))
;;;  (setq p8 (getpoint "\n 请输入座标放置位置:")) 也是为了减少操作
  (setq p8 (polar p3 0.06 80))
  (setq p9 (polar p8 0 (* 4 h)))
  (setq p10 (polar p8 0 (* 14 h)))
  (setq p11 (polar p8 0 (* 22 h)))
  (setq p12 (polar p8 (* 1.5 pi) h))
  (setq p13 (polar p11 (* 1.5 pi) h))
  (setvar "osmode" 0);;
  (command "line" p12 p13 "");; 语法多了 ""
  (setq txt "ABCDEFGHIJKLMNOPQ")
  (setq ss (ssget "w" p1 p0 '((0 . "circle"))));;;单个弧不再处理
  (setq i 1)
  (setq pt p3)
  (while (> (sslength ss) 0)
    (setq rad (cdr (assoc 40 end)));;;
    (setq d (rtos (* 2 rad) 2));;; 不加指定的话 可以出意外啊 下面也一样
    (setq m 0)
    (setq x 0)
    (repeat nn
;;;      (setq xxx (- (+ 0.000 (car cen)) x1))
;;;      (setq yyy (- (+ 0.000 (cadr cen)) y1))
      (setq xxx (- (car cen) x1))
      (setq yyy (- (cadr cen) y1))
      (setq xxxt (rtos xxx 2));;;
      (setq yyyt (rtos yyy 2));;;
      (setq ssb (ssget "w" p1 p0 (list (cons 10 cen))))
      (if (= nnn 2)
        (progn (setq f (ssname ssb 0))
;;;               (setq radf (+ (cdr (assoc 40 fn)) 0.000))
;;;               (setq radg (+ (cdr (assoc 40 gn)) 0.000))
               (setq radf (cdr (assoc 40 fn)))
               (setq radg (cdr (assoc 40 gn)))
               (if (= rad radf)
                 (setq ss (ssdel f ss));;上下调换
                 (setq ss (ssdel g ss));;
               (if (= rad radf)
                 (setq hn gn);;上下调换
                 (setq hn fn);;
               (setq dma (rtos (* 2 radma) 2 0));;;消零
               (setq dmi (rtos (* 2 radmi) 2));;;;
               (if (= ty "CIRCLE")
              ss     (ssdel een ss);;; D
      (setq x (+ x 1));;;语法
      (setq xt (itoa x))
      (command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "");;语法多了 ""
      ;;;(setq ss (ssdel een ss)) D 放到上面去
      (setq m (1+ m));;;语法
    (setq i (1+ i));;;语法
  (setvar "osmode" 7)
  (princ);;;没见过这函数,自定义的吗?
都是搞模具的 给你改了 拿去看看效果吧
 楼主| 发表于 2016-9-18 20:53:21 | 显示全部楼层
wen1235 发表于 2016-9-18 14:44
(defun c:tjj ()
  (setvar "osmode" 1)
高!不胜感激,我慢慢观摩一下先
 楼主| 发表于 2016-9-18 22:51:46 | 显示全部楼层
(defun c:tjj ()
  (setvar "osmode" 1)
你好,同心圆会重复统计,请问改哪里,谢谢
发表于 2016-9-19 07:38:08 | 显示全部楼层
Sylvanas 发表于 2016-9-14 16:05
并没有漏选,(ssget "w") 和 (ssget "c") 只能选当前显示范围内的图元,应该是缩放导致显示不完整
解 ...
正解,已经说的很清楚了
①视野范围内才可选中
②ssget参数C与W的区别
 楼主| 发表于 2016-9-19 20:53:08 | 显示全部楼层
革天明 发表于 2016-9-19 07:38
正解,已经说的很清楚了
①视野范围内才可选中
②ssget参数C与W的区别
你好,我多次在视野范围内点选,仍出问题,是我理解和表述有误,,,原程序选取动作是没有问题的,单是它一遇到圆弧就出出错,不再往下统计。13的程序完善了这一问题,但是又产生了新问题,同心圆重复统计,即同一圆心上的两个圆,各自有一个不同的编码,想请你帮我看看哪里改一下可以解决这一问题,谢谢
发表于 2016-9-20 14:56:43 | 显示全部楼层
皇上快溜 发表于 2016-9-19 20:53
你好,我多次在视野范围内点选,仍出问题,是我理解和表述有误,,,原程序选取动作是没有问题的,单是它 ...
能否上传dwg进行测试,你给出想要的结果
 楼主| 发表于 2016-9-20 16:11:24 | 显示全部楼层
 楼主| 发表于 2016-9-20 16:12:39 | 显示全部楼层
GMT+8, 2026-1-21 00:32 , Processed in 0.186521 second(s), 20 queries , Gzip On.
