楼主: 664571221
[提问] 求把一串文字中的空格替换为逗号,把乘号x替换为*
 楼主| 发表于 2018-7-9 14:34:56 | 显示全部楼层
664571221 发表于 2018-7-9 14:32
可以了大侠,两个有啥不同呀,非常感谢
大侠可以加你QQ吗
发表于 2018-7-9 15:48:57 | 显示全部楼层
发表于 2018-7-9 15:50:06 | 显示全部楼层
664571221 发表于 2018-7-9 14:34
大侠可以加你QQ吗
不好意思!我沒有QQ
 楼主| 发表于 2018-7-9 15:58:11 | 显示全部楼层
bluefcc1 发表于 2018-7-9 15:50
不好意思!我沒有QQ
大侠看下这段程序最后生成的文字如何复制到粘贴板
(defun c:ss( / ss osmode i name ent size size_new size_all bak_cecolor)
  (setvar "cmdecho" 0)
  ;(setq osmode (getvar "osmode"))
  (setq i 0)
  (princ "\n选择尺寸")
  (if(setq ss(ssget '((0 . "DIMENSION"))))
      (setq bak_dimzin(getvar 'dimzin))
      (setvar 'dimzin 8)
      (while (setq name (ssname ss 0))
        (setq i (1+ i))
        (setq ent (entget name))
        (setq size (cdr (assoc 42 ent)))
        (if (= i 1)
          (setq num_all size)
          (setq num_all (+ num_all size))
        (setq size_new (rtos(* size 0.001) 2 3))
        (if (= i 1)
          (setq size_all size_new)
          (setq size_all (strcat size_all "+" size_new ))
        (setq ss(ssdel name ss))
      (setq bak_cecolor(getvar 'cecolor))
      (setvar 'cecolor "1")
      (setq size_all(strcat "(" size_all ")"))
      (vl-cmdf "_.text" "j" "mc" (getpoint "\n文本放置点") "250" "0" size_all)
      (and bak_cecolor (setvar 'cecolor bak_cecolor))
      (and bak_dimzin (setvar 'dimzin bak_dimzin))
  ;(setvar "osmode" osmode)
  (setvar "cmdecho" 1)
发表于 2018-7-9 16:09:42 | 显示全部楼层
   (setq i 0)
   (princ "\n選擇尺寸")
       (setvar 'dimzin 8)
         (setq i (1+ i))
         (if (= i 1)
           (setq num_all size)
         (if (= i 1)
       (set-clip-string size_all)  ;複製到剪貼簿 (不含括號)
       (vl-cmdf "_.text" "j" "mc" (getpoint "\n文本放置點") "250" "0" size_all)
;;剪貼簿函數
(defun set-clip-string (str / html result)
  (and
    (= (type str) 'str)
    (setq html (vlax-create-object "htmlfile"))
    (setq result (vlax-invoke (vlax-get (vlax-get html 'parentwindow)
                                        'clipboarddata
                              ) 'setdata "Text" str
    (vlax-release-object html)
USER2128 + 1 赞一个!
 楼主| 发表于 2018-7-10 09:15:23 | 显示全部楼层
谢谢大侠,非常感谢.
发表于 2018-7-11 15:05:09 | 显示全部楼层
无需编程,CAD命令行的FIND就实现了
发表于 2018-7-11 20:43:32 | 显示全部楼层
直接用CAD的FIND命令不好么?一样的好用啊。
发表于 2018-7-15 20:05:12 | 显示全部楼层
(vl-string-translate " X" ",*" "我好 你好X他好")
 楼主| 发表于 2018-7-15 20:27:19 | 显示全部楼层
我只是举例,不是指针对这个
GMT+8, 2026-1-20 00:52 , Processed in 0.147809 second(s), 21 queries , Gzip On.
