楼主: 啵浪鼓
[提问] 变量转字符串带双引号
 楼主| 发表于 2019-10-19 22:13:46 来自手机 | 显示全部楼层
1291500406 发表于 2019-10-19 20:44
(setq A1 1)
(alert(strcat "label = \"" (vl-princ-to-string A1)"\""))
label = "1"
感谢这个是需要的
之前一直试过无数遍,错误在第一组需要2个双引号
发表于 2019-10-20 18:50:28 | 显示全部楼层
请看strcat函数
  1. (defun c:tt ( / i lst)
  2. (setq i 0 lst '(1 2 "3" "A" B))
  3. (repeat (length lst)
  4. (terpri)
  5. (setq str (nth i lst))
  6. (print (strcat "label=\"key" (vl-princ-to-string str)  "\" ;" ) )
  7. (setq i (1+ i))
  8. )
  9. (textpage)
  10. (princ)
  11. )
  12. ;|print和read-line ,write-line,read-line返回值
  13. "label=\"key1\" ;"
  14. "label=\"key2\" ;"
  15. "label=\"key3\" ;"
  16. "label=\"keyA\" ;"
  17. "label=\"keyB\" ;"
  18. |;
princ 返回值
label="key1" ;
label="key2" ;
label="key3" ;
label="keyA" ;
label="keyB" ;
GMT+8, 2026-1-18 23:18 , Processed in 1.443546 second(s), 19 queries , Gzip On.
