楼主: xj6019
[讨论] cad文件内插入当前文件的路径
 楼主| 发表于 2023-5-2 08:09:12 | 显示全部楼层
XGZS1234 发表于 2023-4-29 17:24
大神 C:%users\Administrator\appdata\local\temp\23FX-06.dwg    如果想要temp\23FX-06怎么改?
(setq tem(last(LM:str->lst (vl-filename-directory (setq str "C:\\Users\\Administrator\\appdata\\local\\temp\\23FX-06.dwg")) "\\")))
(strcat tem "\\" (vl-filename-base str))
;下为调用函数
(defun LM:str->lst (str del / pos)
  (if (setq pos (vl-string-search del str))
    (cons (substr str 1 pos)
                        (lm:str->lst (substr str (+ pos 1 (strlen del))) del)
    (list str)
发表于 2023-5-3 14:20:39 | 显示全部楼层
xj6019 发表于 2023-5-2 08:09
(setq tem(last(LM:str->lst (vl-filename-directory (setq str "C:\%users\\Administrator\\appdata\\lo ...
非常感谢大神!!!
GMT+8, 2026-1-15 13:07 , Processed in 0.157101 second(s), 18 queries , Gzip On.
