楼主: yyz123121
求优化折断线命令。
 楼主| 发表于 2020-12-23 20:32:42 | 显示全部楼层
bssurvey 发表于 2020-12-22 11:59
其實我不是大神啦,大家互相學習,和大家互相切磋,大家一起進步
試看看是不是這樣
(defun c:XJ ()
就是这样的效果,非常感谢,在您的基础上,我把各自判断有没有线型那段改成程序一开始就判断,
(defun c:XJ ()
  (setvar "cmdecho" 0)
  (foreach lt '("CENTER" "DASH" "DASHED" "LED_LINE" "BATTING" "ZIGZAG")
    (if (= (tblsearch "ltype" lt) nil)
      (command "_linetype" "l" lt "" "")
  (setq ed1(getstring "\n请输入图层名称:"))
  (setq yans(getint "\n请输入颜色:"))
  (initget "c e d")
  (setq xianxing(getkword "\n请输入线型名称 c<Continuous> e<Center> d<Dash>:<Continuous>"))
   (cond
    ((= xianxing "c")
     (entmake (list
       '(0 . "LAYER")
       '(100 . "AcDbSymbolTableRecord")
       '(100 . "AcDbLayerTableRecord")
       '(70 . 0)
       '(290 . 1) ;1 设为打印 ,0 设为非打印
       (cons 62 yans)
       (cons 2 ed1)
       (cons 6 "Continuous")
    ((= xianxing "e")
     (entmake (list
       '(0 . "LAYER")
       '(70 . 0)
       (cons 62 yans)
       (cons 2 ed1)
       (cons 6 "CENTER");;线型代码
    ((= xianxing "d")
     (entmake (list
       '(0 . "LAYER")
       '(70 . 0)
       (cons 62 yans)
       (cons 2 ed1)
       (cons 6 "DASH");;线型代码
  (setvar "clayer" ed1)
  (setvar "cmdecho" 1)
讚喔 大家互相學習  发表于 2020-12-24 07:56
发表于 2024-2-13 10:48:32 | 显示全部楼层
路过,这样的讨论真不错
GMT+8, 2026-1-18 06:46 , Processed in 0.164307 second(s), 19 queries , Gzip On.
