楼主: pizi158545086
[源码] 求助,有大神帮忙写一个延伸闭合线或者矩形的lsp吗?
发表于 2021-12-13 18:03:19 | 显示全部楼层
对,应该是9楼的效果才对
挺简单的,就是讲点技巧  发表于 2021-12-13 20:27
发表于 2021-12-13 20:22:01 | 显示全部楼层
试试
  1. (vl-load-com)
  2. (defun c:test (/    xty-get-dxf    xty-tr-ss2lst
  3.          xty-tr-value2list     EN    LST     PARAM
  4.          PT1    PT2       PT3  PT4     PTA
  5.          PTB    PTC       SS    TEMP
  6.         )
  7.   (defun xty-get-dxf (code en) (cdr (assoc code (entget en))))
  8.   (defun xty-tr-ss2lst (ss form / n en lst)
  9.     (repeat (setq n (sslength ss))
  10.       (setq en (ssname ss (setq n (1- n))))
  11.       (setq lst (cons en lst))
  12.     )
  13.     (setq lst (reverse lst))
  14.     (if  form
  15.       lst
  16.       (mapcar (function vlax-ename->vla-object) lst)
  17.     )
  18.   )
  19.   (defun xty-tr-value2list (value)
  20.     (setq value  (vl-catch-all-apply
  21.       (function vlax-safearray->list)
  22.       (list (vlax-variant-value value))
  23.     )
  24.     )
  25.     (if  (= (type value) (function LIST))
  26.       value
  27.       nil
  28.     )
  29.   )
  30.   (setq  pt1 (getpoint "\n栏选起点:")
  31.   pt2 (getpoint pt1 "\n栏选终点:")
  32.   ss  (ssget "f" (list pt1 pt2) '((0 . "lwpolyline")))
  33.   lst (xty-tr-ss2lst ss nil)
  34.   en  (vlax-ename->vla-object
  35.         (ssname (ssget ":e:s" '((0 . "*line"))) 0)
  36.       )
  37.   pt3 (if  (= (vla-get-ObjectName en) "AcDbXline")
  38.         (xty-tr-value2list(vla-get-basepoint en))
  39.         (vlax-curve-getstartpoint en)
  40.       )
  41.   pt4 (if  (= (vla-get-ObjectName en) "AcDbXline")
  42.         (xty-tr-value2list(vla-get-secondpoint en))
  43.         (vlax-curve-getendpoint en)
  44.       )
  45.   )
  46.   (foreach n lst
  47.     (setq temp (xty-tr-value2list (vla-explode n)))
  48.     (foreach m temp
  49.       (setq pta  (xty-tr-value2list (vla-get-startpoint m))
  50.       ptb  (xty-tr-value2list (vla-get-endpoint m))
  51.       )
  52.       (if (inters pt1 pt2 pta ptb)
  53.   (progn (setq ptc   (inters pt3 pt4 pta ptb nil)
  54.          pta   (if (< (distance ptc pta) (distance ptc ptb))
  55.            pta
  56.            ptb
  57.          )
  58.          param (fix (vlax-curve-getparamatpoint n pta))
  59.          )
  60.          (vla-put-coordinate
  61.      n
  62.      param
  63.      (vlax-safearray-fill
  64.        (vlax-make-safearray vlax-vbDouble '(0 . 1))
  65.        (list (car ptc) (cadr ptc))
  66.      )
  67.          )
  68.   )
  69.       )
  70.       (vla-delete m)
  71.     )
  72.   )
  73. )
参与人数 2明经币 +2 收起 理由
pizi158545086 + 1 很给力!
xj6019 + 1 很给力!
 楼主| 发表于 2021-12-13 20:57:01 | 显示全部楼层
非常感谢帮忙,函数错误是什么回事呢,可以再帮忙下吗
发表于 2021-12-13 21:28:02 | 显示全部楼层
告知我错误
发表于 2021-12-13 21:29:16 | 显示全部楼层
疏忽了*xty-e2o*改成vlax-ename->vla-object
 楼主| 发表于 2021-12-13 21:38:57 | 显示全部楼层
没看到*xty-e2o*这段文字,尴尬,可以发下完整源码吗?谢谢
12楼就是完整的源码,由于嵌套了自己的函数,没拷贝全  发表于 2021-12-13 23:15
发表于 2021-12-13 23:02:35 | 显示全部楼层
在12楼改了
发表于 2021-12-14 07:39:53 | 显示全部楼层
真是高手  !!厉害!!佩服!!
 楼主| 发表于 2021-12-14 08:58:39 | 显示全部楼层
不知道怎么回事  加载了  命令行显示栏选起点 ,下一步就显示错误了  难道是我CAD版本的原因?我用的版本是2021
发表于 2021-12-14 09:17:51 | 显示全部楼层
pizi158545086 发表于 2021-12-14 08:58
不知道怎么回事  加载了  命令行显示栏选起点 ,下一步就显示错误了  难道是我CAD版本的原因?我用的版本 ...
哥们你选的时候 两点穿过你的矩形
GMT+8, 2026-1-16 16:17 , Processed in 0.173980 second(s), 19 queries , Gzip On.
