楼主: 夏生生
[讨论] 一个有趣的表变换,请各位网友不吝赐教,谢谢
发表于 2022-2-27 16:31:14 | 显示全部楼层
夏生生 发表于 2022-2-27 16:17
谢谢提醒,您提供的思路已经很清晰了,我顺着这个思路向下走就是
偶数一样有遗漏。
_$ (f2 '("a" "b" "c" "d" "e" "f") 6 2)
(("a" "a") ("a" "a" "a") ("a" "a" "a" "a") ("a" "a" "a" "a" "a") ("a" "a" "a" "a" "a" "a") ("b" "b") ("b" "a" "b") ("b" "a" "a" "b") ("b" "a" "a" "a" "b") ("b" "a" "a" "a" "a" "b") ("b" "b" "b") ("b" "b" "b" "b") ("b" "b" "b" "b" "b") ("b" "b" "b" "b" "b" "b") ("c" "c") ("c" "a" "c") ("c" "a" "a" "c") ("c" "a" "a" "a" "c") ("c" "a" "a" "a" "a" "c") ("c" "b" "c") ("c" "b" "b" "c") ("c" "b" "b" "b" "c") ("c" "b" "b" "b" "b" "c") ("c" "c" "c") ("c" "c" "c" "c") ("c" "c" "c" "c" "c") ("c" "c" "c" "c" "c" "c") ("d" "d") ("d" "b" "d") ("d" "b" "b" "d") ("d" "b" "b" "b" "d") ("d" "b" "b" "b" "b" "d") ("d" "c" "d") ("d" "c" "c" "d") ("d" "c" "c" "c" "d") ("d" "c" "c" "c" "c" "d") ("d" "d" "d") ("d" "d" "d" "d") ("d" "d" "d" "d" "d") ("d" "d" "d" "d" "d" "d") ("e" "e") ("e" "c" "e") ("e" "c" "c" "e") ("e" "c" "c" "c" "e") ("e" "c" "c" "c" "c" "e") ("e" "d" "e") ("e" "d" "d" "e") ("e" "d" "d" "d" "e") ("e" "d" "d" "d" "d" "e") ("e" "e" "e") ("e" "e" "e" "e") ("e" "e" "e" "e" "e") ("e" "e" "e" "e" "e" "e") ("f" "f") ("f" "d" "f") ("f" "d" "d" "f") ("f" "d" "d" "d" "f") ("f" "d" "d" "d" "d" "f") ("f" "e" "f") ("f" "e" "e" "f") ("f" "e" "e" "e" "f") ("f" "e" "e" "e" "e" "f") ("f" "f" "f") ("f" "f" "f" "f") ("f" "f" "f" "f" "f") ("f" "f" "f" "f" "f" "f"))
_$
("f" "f" "d" "d" "f" "f")("f" "f" "e" "e" "f" "f")遗漏了。
发表于 2022-2-27 16:53:12 | 显示全部楼层
不知道楼主这个何用呢?
 楼主| 发表于 2022-2-27 16:56:15 | 显示全部楼层
Bao_lai 发表于 2022-2-27 16:53
不知道楼主这个何用呢?
不是蛮好解释,有序对称排点一类的应用
发表于 2022-2-27 18:07:55 | 显示全部楼层
夏生生 发表于 2022-2-27 15:17
应该向下面截图的这种逻辑
;;;前提m>=2
(defun f(a m n)
(defun f1(a m n)
(setq flst (list a a) i 0 j (max 1 (- a n)) vlst nil)
(while (<= j a)
(while (< i (- m 2))
  (setq fflst (list j))
  (repeat i
       (setq fflst (cons j fflst)))
  (setq vlst (cons fflst vlst))
  (setq i (+ i 1))
(setq j (+ j 1) i 0)
(setq vlst (mapcar '(lambda (x) (cons a (reverse (cons a x)))) vlst))
(setq vlst (cons flst (reverse vlst)))
(defun f2(a m n)
(setq k (max 1 (- a n)) vvlst nil)
(while (< k a)
   (setq plst (list a a k) qlst (list a a k k))
   (while (<= (length plst) (/ (+ m 1) 2))
     (setq ptlst (append plst (cdr (reverse plst))))
     (setq vvlst (cons ptlst vvlst))
     (if (<= (length plst) (/ m 2))
        (setq ptlst (append plst (reverse plst)))
     (setq plst (cons a plst))
   (while (<= (length qlst) (/ (+ m 1) 2))
     (setq qtlst (append qlst (cdr (reverse qlst))))
     (setq vvlst (cons qtlst vvlst))
         (if (<= (length qlst) (/ m 2))
         (setq qtlst (append qlst (reverse qlst)))
     (setq qlst (reverse (cons k (reverse qlst))))
  (setq k (+ k 1))
vvlst
(setq ii 1 lst nil)
(while (<= ii a)
  (setq lst (append (f1 ii m n) lst))
  (setq ii (+ ii 1))
(setq lst (append (f2 a m n) lst))
F
_$ (f 4 3 2)
((4 4) (4 2 4) (4 3 4) (4 4 4) (3 3) (3 1 3) (3 2 3) (3 3 3) (2 2) (2 1 2) (2 2 2) (1 1) (1 1 1))
_$ (f 4 5 2)
((4 4 3 4 4) (4 4 2 4 4) (4 4) (4 2 4) (4 2 2 4) (4 2 2 2 4) (4 3 4) (4 3 3 4) (4 3 3 3 4) (4 4 4) (4 4 4 4) (4 4 4 4 4) (3 3) (3 1 3) (3 1 1 3) (3 1 1 1 3) (3 2 3) (3 2 2 3) (3 2 2 2 3) (3 3 3) (3 3 3 3) (3 3 3 3 3) (2 2) (2 1 2) (2 1 1 2) (2 1 1 1 2) (2 2 2) (2 2 2 2) (2 2 2 2 2) (1 1) (1 1 1) (1 1 1 1) (1 1 1 1 1))
_$ (f 4 4 2)
((4 4) (4 2 4) (4 2 2 4) (4 3 4) (4 3 3 4) (4 4 4) (4 4 4 4) (3 3) (3 1 3) (3 1 1 3) (3 2 3) (3 2 2 3) (3 3 3) (3 3 3 3) (2 2) (2 1 2) (2 1 1 2) (2 2 2) (2 2 2 2) (1 1) (1 1 1) (1 1 1 1))
_$ (f 5 5 2)
((5 5 4 5 5) (5 5 3 5 5) (5 5) (5 3 5) (5 3 3 5) (5 3 3 3 5) (5 4 5) (5 4 4 5) (5 4 4 4 5) (5 5 5) (5 5 5 5) (5 5 5 5 5) (4 4) (4 2 4) (4 2 2 4) (4 2 2 2 4) (4 3 4) (4 3 3 4) (4 3 3 3 4) (4 4 4) (4 4 4 4) (4 4 4 4 4) (3 3) (3 1 3) (3 1 1 3) (3 1 1 1 3) (3 2 3) (3 2 2 3) (3 2 2 2 3) (3 3 3) (3 3 3 3) (3 3 3 3 3) (2 2) (2 1 2) (2 1 1 2) (2 1 1 1 2) (2 2 2) (2 2 2 2) (2 2 2 2 2) (1 1) (1 1 1) (1 1 1 1) (1 1 1 1 1))
_$ (f 6 6 2)
((6 6 5 5 6 6) (6 6 5 6 6) (6 6 4 4 6 6) (6 6 4 6 6) (6 6) (6 4 6) (6 4 4 6) (6 4 4 4 6) (6 4 4 4 4 6) (6 5 6) (6 5 5 6) (6 5 5 5 6) (6 5 5 5 5 6) (6 6 6) (6 6 6 6) (6 6 6 6 6) (6 6 6 6 6 6) (5 5) (5 3 5) (5 3 3 5) (5 3 3 3 5) (5 3 3 3 3 5) (5 4 5) (5 4 4 5) (5 4 4 4 5) (5 4 4 4 4 5) (5 5 5) (5 5 5 5) (5 5 5 5 5) (5 5 5 5 5 5) (4 4) (4 2 4) (4 2 2 4) (4 2 2 2 4) (4 2 2 2 2 4) (4 3 4) (4 3 3 4) (4 3 3 3 4) (4 3 3 3 3 4) (4 4 4) (4 4 4 4) (4 4 4 4 4) (4 4 4 4 4 4) (3 3) (3 1 3) (3 1 1 3) (3 1 1 1 3) (3 1 1 1 1 3) (3 2 3) (3 2 2 3) (3 2 2 2 3) (3 2 2 2 2 3) (3 3 3) (3 3 3 3) (3 3 3 3 3) (3 3 3 3 3 3) (2 2) (2 1 2) (2 1 1 2) (2 1 1 1 2) (2 1 1 1 1 2) (2 2 2) (2 2 2 2) (2 2 2 2 2) (2 2 2 2 2 2) (1 1) (1 1 1) (1 1 1 1) (1 1 1 1 1) (1 1 1 1 1 1))
_$
发表于 2022-2-27 20:08:12 | 显示全部楼层
mahuan1279 发表于 2022-2-27 18:07
;;;前提m>=2
(defun f(a m n)
(defun f1(a m n)
谢谢了,我再仔细研读一下
发表于 2022-2-28 23:42:55 | 显示全部楼层
;;;前提m>=2
(defun f(a m n)
(defun f1(a m n)
由两个表拼凑而成总显得不够完美,直接一步到位。
_$ (defun f(a m n)
  (setq i 1 vvlst nil)
  (while (<= i a)
    (setq k (max 1 (- i n)))
        (while (<= k i)
            (setq vlst nil)
                (setq plst (list (list i k i)))
        (setq qlst (list (list i k k i)))
                (while (<= (length (car plst)) m)
               (setq vlst (append plst vlst))
               (if (= (length plst) 1)
                               (setq plst (list (list i k k k i) (list i i k i i)))
                   (setq plst (cons (cons i (cons k (cdr (reverse (cons i (cons k (cdr (car plst)))))))) (mapcar '(lambda (x) (cons i (reverse (cons i x)))) plst)))
                (while (<= (length (car qlst)) m)
               (setq vlst (append qlst vlst))
                               (setq qlst (list (list i k k k k i) (list i i k k i i)))
                   (setq qlst (cons (cons i (cons k (cdr (reverse (cons i (cons k (cdr (car qlst)))))))) (mapcar '(lambda (x) (cons i (reverse (cons i x)))) qlst)))
                (setq vvlst (append vlst vvlst))
        (setq k (+ k 1))
   (setq vvlst (cons (list i i) vvlst))
   (setq i (+ i 1))
  vvlst
F
_$ (f 4 3 2)
((4 4) (4 4 4) (4 3 4) (4 2 4) (3 3) (3 3 3) (3 2 3) (3 1 3) (2 2) (2 2 2) (2 1 2) (1 1) (1 1 1))
_$ (f 5 4 3)
((5 5) (5 5 5 5) (5 5 5) (5 4 4 5) (5 4 5) (5 3 3 5) (5 3 5) (5 2 2 5) (5 2 5) (4 4) (4 4 4 4) (4 4 4) (4 3 3 4) (4 3 4) (4 2 2 4) (4 2 4) (4 1 1 4) (4 1 4) (3 3) (3 3 3 3) (3 3 3) (3 2 2 3) (3 2 3) (3 1 1 3) (3 1 3) (2 2) (2 2 2 2) (2 2 2) (2 1 1 2) (2 1 2) (1 1) (1 1 1 1) (1 1 1))
_$
发表于 2022-3-1 12:45:23 | 显示全部楼层
_$ (defun f(a m n)
当K=i时,有重复情况,需单独处理。
_$ (defun f(a m n)
  (while (<= i a)
        (while (< k i)
            (setq vlst nil)
        (setq k (+ k 1))
   (if (= k i)
              (setq vlst nil)
              (setq plst (list i i i))
                  (while (<= (length plst) m)
                       (setq vlst (append (list plst) vlst))
                           (setq plst (cons i plst))
   (setq i (+ i 1))
  vvlst
F
_$ (f 3 2 2)
((3 3) (2 2) (1 1))
_$ (f 4 3 2)
((4 4 4) (4 4) (4 3 4) (4 2 4) (3 3 3) (3 3) (3 2 3) (3 1 3) (2 2 2) (2 2) (2 1 2) (1 1 1) (1 1))
_$ (f 4 4 2)
((4 4 4 4) (4 4 4) (4 4) (4 3 3 4) (4 3 4) (4 2 2 4) (4 2 4) (3 3 3 3) (3 3 3) (3 3) (3 2 2 3) (3 2 3) (3 1 1 3) (3 1 3) (2 2 2 2) (2 2 2) (2 2) (2 1 1 2) (2 1 2) (1 1 1 1) (1 1 1) (1 1))
_$ (f 6 4 2)
((6 6 6 6) (6 6 6) (6 6) (6 5 5 6) (6 5 6) (6 4 4 6) (6 4 6) (5 5 5 5) (5 5 5) (5 5) (5 4 4 5) (5 4 5) (5 3 3 5) (5 3 5) (4 4 4 4) (4 4 4) (4 4) (4 3 3 4) (4 3 4) (4 2 2 4) (4 2 4) (3 3 3 3) (3 3 3) (3 3) (3 2 2 3) (3 2 3) (3 1 1 3) (3 1 3) (2 2 2 2) (2 2 2) (2 2) (2 1 1 2) (2 1 2) (1 1 1 1) (1 1 1) (1 1))
_$ (f 6 5 2)
((6 6 6 6 6) (6 6 6 6) (6 6 6) (6 6) (6 5 5 6) (6 5 5 5 6) (6 6 5 6 6) (6 5 6) (6 4 4 6) (6 4 4 4 6) (6 6 4 6 6) (6 4 6) (5 5 5 5 5) (5 5 5 5) (5 5 5) (5 5) (5 4 4 5) (5 4 4 4 5) (5 5 4 5 5) (5 4 5) (5 3 3 5) (5 3 3 3 5) (5 5 3 5 5) (5 3 5) (4 4 4 4 4) (4 4 4 4) (4 4 4) (4 4) (4 3 3 4) (4 3 3 3 4) (4 4 3 4 4) (4 3 4) (4 2 2 4) (4 2 2 2 4) (4 4 2 4 4) (4 2 4) (3 3 3 3 3) (3 3 3 3) (3 3 3) (3 3) (3 2 2 3) (3 2 2 2 3) (3 3 2 3 3) (3 2 3) (3 1 1 3) (3 1 1 1 3) (3 3 1 3 3) (3 1 3) (2 2 2 2 2) (2 2 2 2) (2 2 2) (2 2) (2 1 1 2) (2 1 1 1 2) (2 2 1 2 2) (2 1 2) (1 1 1 1 1) (1 1 1 1) (1 1 1) (1 1))
_$ (f 6 6 3)
((6 6 6 6 6 6) (6 6 6 6 6) (6 6 6 6) (6 6 6) (6 6) (6 5 5 5 5 6) (6 6 5 5 6 6) (6 5 5 6) (6 5 5 5 6) (6 6 5 6 6) (6 5 6) (6 4 4 4 4 6) (6 6 4 4 6 6) (6 4 4 6) (6 4 4 4 6) (6 6 4 6 6) (6 4 6) (6 3 3 3 3 6) (6 6 3 3 6 6) (6 3 3 6) (6 3 3 3 6) (6 6 3 6 6) (6 3 6) (5 5 5 5 5 5) (5 5 5 5 5) (5 5 5 5) (5 5 5) (5 5) (5 4 4 4 4 5) (5 5 4 4 5 5) (5 4 4 5) (5 4 4 4 5) (5 5 4 5 5) (5 4 5) (5 3 3 3 3 5) (5 5 3 3 5 5) (5 3 3 5) (5 3 3 3 5) (5 5 3 5 5) (5 3 5) (5 2 2 2 2 5) (5 5 2 2 5 5) (5 2 2 5) (5 2 2 2 5) (5 5 2 5 5) (5 2 5) (4 4 4 4 4 4) (4 4 4 4 4) (4 4 4 4) (4 4 4) (4 4) (4 3 3 3 3 4) (4 4 3 3 4 4) (4 3 3 4) (4 3 3 3 4) (4 4 3 4 4) (4 3 4) (4 2 2 2 2 4) (4 4 2 2 4 4) (4 2 2 4) (4 2 2 2 4) (4 4 2 4 4) (4 2 4) (4 1 1 1 1 4) (4 4 1 1 4 4) (4 1 1 4) (4 1 1 1 4) (4 4 1 4 4) (4 1 4) (3 3 3 3 3 3) (3 3 3 3 3) (3 3 3 3) (3 3 3) (3 3) (3 2 2 2 2 3) (3 3 2 2 3 3) (3 2 2 3) (3 2 2 2 3) (3 3 2 3 3) (3 2 3) (3 1 1 1 1 3) (3 3 1 1 3 3) (3 1 1 3) (3 1 1 1 3) (3 3 1 3 3) (3 1 3) (2 2 2 2 2 2) (2 2 2 2 2) (2 2 2 2) (2 2 2) (2 2) (2 1 1 1 1 2) (2 2 1 1 2 2) (2 1 1 2) (2 1 1 1 2) (2 2 1 2 2) (2 1 2) (1 1 1 1 1 1) (1 1 1 1 1) (1 1 1 1) (1 1 1) (1 1))
_$
谢谢您的精益求精  发表于 2022-3-1 22:29
夏生生 + 1 赞一个!
发表于 2022-3-1 22:01:59 | 显示全部楼层
  1. ;; (tt lst表 n1中间最大元素数量)
  2. (defun tt (lst n1 / i lst1 j k d)
  3.   (defun abc (x n / b) (repeat n (setq b (cons x b))) b)
  4.   (setq        lst1 '()
  5.         j    0
  6.   )
  7.   (foreach a lst
  8.     (setq i 0)
  9.     (repeat (1+ n1)
  10.       (setq k 0)
  11.       (foreach b lst
  12.         (if (<= k j)
  13.           (setq        d    (append (list a) (abc b i) (list a))
  14.                 lst1 (if (not (member d lst1))
  15.                        (cons d lst1)
  16.                        lst1
  17.                      )
  18.           )
  19.         )
  20.         (setq k (1+ k))
  21.       )
  22.       (setq i (1+ i))
  23.     )
  24.     (setq j (1+ j))
  25.   )
  26.   (reverse lst1)
  27. )
  28. ;; (tt '("a" "b" "c" "d" "e") 3)
  29. ;; '(("a" "a") ("a" "a" "a") ("a" "a" "a" "a") ("a" "a" "a" "a" "a") ("b" "b") ("b" "a" "b") ("b" "b" "b") ("b" "a" "a" "b") ("b" "b" "b" "b") ("b" "a" "a" "a" "b") ("b" "b" "b" "b" "b") ("c" "c") ("c" "a" "c") ("c" "b" "c") ("c" "c" "c") ("c" "a" "a" "c") ("c" "b" "b" "c") ("c" "c" "c" "c") ("c" "a" "a" "a" "c") ("c" "b" "b" "b" "c") ("c" "c" "c" "c" "c") ("d" "d") ("d" "a" "d") ("d" "b" "d") ("d" "c" "d") ("d" "d" "d") ("d" "a" "a" "d") ("d" "b" "b" "d") ("d" "c" "c" "d") ("d" "d" "d" "d") ("d" "a" "a" "a" "d") ("d" "b" "b" "b" "d") ("d" "c" "c" "c" "d") ("d" "d" "d" "d" "d") ("e" "e") ("e" "a" "e") ("e" "b" "e") ("e" "c" "e") ("e" "d" "e") ("e" "e" "e") ("e" "a" "a" "e") ("e" "b" "b" "e") ("e" "c" "c" "e") ("e" "d" "d" "e") ("e" "e" "e" "e") ("e" "a" "a" "a" "e") ("e" "b" "b" "b" "e") ("e" "c" "c" "c" "e") ("e" "d" "d" "d" "e") ("e" "e" "e" "e" "e"))
夏生生 + 1 很给力!
发表于 2022-3-1 22:54:39 | 显示全部楼层
_$ (tt '("a" "b" "c" "d" "e") 4)
(("a" "a") ("a" "a" "a") ("a" "a" "a" "a") ("a" "a" "a" "a" "a") ("a" "a" "a" "a" "a" "a") ("b" "b") ("b" "a" "b") ("b" "b" "b") ("b" "a" "a" "b") ("b" "b" "b" "b") ("b" "a" "a" "a" "b") ("b" "b" "b" "b" "b") ("b" "a" "a" "a" "a" "b") ("b" "b" "b" "b" "b" "b") ("c" "c") ("c" "a" "c") ("c" "b" "c") ("c" "c" "c") ("c" "a" "a" "c") ("c" "b" "b" "c") ("c" "c" "c" "c") ("c" "a" "a" "a" "c") ("c" "b" "b" "b" "c") ("c" "c" "c" "c" "c") ("c" "a" "a" "a" "a" "c") ("c" "b" "b" "b" "b" "c") ("c" "c" "c" "c" "c" "c") ("d" "d") ("d" "a" "d") ("d" "b" "d") ("d" "c" "d") ("d" "d" "d") ("d" "a" "a" "d") ("d" "b" "b" "d") ("d" "c" "c" "d") ("d" "d" "d" "d") ("d" "a" "a" "a" "d") ("d" "b" "b" "b" "d") ("d" "c" "c" "c" "d") ("d" "d" "d" "d" "d") ("d" "a" "a" "a" "a" "d") ("d" "b" "b" "b" "b" "d") ("d" "c" "c" "c" "c" "d") ("d" "d" "d" "d" "d" "d") ("e" "e") ("e" "a" "e") ("e" "b" "e") ("e" "c" "e") ("e" "d" "e") ("e" "e" "e") ("e" "a" "a" "e") ("e" "b" "b" "e") ("e" "c" "c" "e") ("e" "d" "d" "e") ("e" "e" "e" "e") ("e" "a" "a" "a" "e") ("e" "b" "b" "b" "e") ("e" "c" "c" "c" "e") ("e" "d" "d" "d" "e") ("e" "e" "e" "e" "e") ("e" "a" "a" "a" "a" "e") ("e" "b" "b" "b" "b" "e") ("e" "c" "c" "c" "c" "e") ("e" "d" "d" "d" "d" "e") ("e" "e" "e" "e" "e" "e"))
_$
似乎少了("b" "b" "a" "b" "b")、("b" "b" "a" "a" "b" "b") ……等等情形。
发表于 2022-3-2 13:30:21 | 显示全部楼层
(("a" "a") ("a" "a" "a") ("a" "a" "a" "a") ("a" "a" "a" "a" "a") ...
实在是看不太懂楼主的要求
GMT+8, 2026-1-16 18:42 , Processed in 0.180743 second(s), 20 queries , Gzip On.
