楼主: 999999
[提问] 求助各位大神批量倒圆角功能
 楼主| 发表于 2022-11-15 11:16:37 | 显示全部楼层
大神您好,我想安装一下您这个插件,把代码复制进去后输入@@弹不出面板,是怎么回事呀
发表于 2022-11-15 11:27:55 | 显示全部楼层
对于有弧线的处理还不完善。
CAD什么版本?需要关闭360安全卫士之类的。
加签名处QQ群详聊
 楼主| 发表于 2022-11-15 12:28:16 | 显示全部楼层
vitalgg 发表于 2022-11-15 11:27
对于有弧线的处理还不完善。
好的呢,刚刚加群了
发表于 2022-11-15 12:34:34 | 显示全部楼层
楼主找到了没有呢?
发表于 2022-11-24 12:25:03 | 显示全部楼层
(defun c:FR (/  ss pts i ee :ST:SS-Boundingbox :ST:SS->List :ST:SS->ListVla LM:ssget os ov)
(setq
        os '(PeditAccept cmdecho)
        ov (mapcar 'getvar os)
(mapcar 'setvar os '(1 0))
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;Return list ename from ssget
(defun :ST:SS->List(ss / n e l)
  (setq n (sslength ss))
  (while (setq e (ssname ss (setq n (1- n))))
    (setq l (cons e l))
;Return list vla Object from s
(defun :ST:SS->ListVla(s)(mapcar 'vlax-ename->vla-object (:ST:SS->List s)))
(defun :ST:SS-Boundingbox ( lst / llp ls1 ls2 urp )
    (foreach obj lst
        (vla-getboundingbox obj 'llp 'urp)
        (setq ls1 (cons (vlax-safearray->list llp) ls1)
              ls2 (cons (vlax-safearray->list urp) ls2)
    (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list ls1 ls2))
           (or  *newrad* (setq *newrad* 1))
   (setq *newrad* (getdist (strcat "\nB\U+00E1n k\U+00EDnh fillet <" (rtos *newrad*) "> :")))
   (setvar "FilletRad" *newrad*)
   ;(setq ss (ssget '(( 0 . "LINE,ARC,LWPOLYLINE"))))
   (setq ss (LM:ssget "Select Line, Arc, Pline to fillet :" (list '(( 0 . "LINE,ARC,LWPOLYLINE")))))
   (setq pts (:ST:SS-Boundingbox (:ST:SS->ListVla ss )))     ; ET func
   (command "Pedit" "M" ss "" "J" "" "")
   (setq ss (ssget "C" (car pts) (cadr pts) '(( 0 . "LWPOLYLINE")))
          i  0
   (while (setq ee (ssname ss i))
     (command "Fillet" "P" ee)
     (setq i (1+ i))
   (mapcar 'setvar os ov)
Bao_lai + 1 很给力!
发表于 2023-11-8 02:40:52 | 显示全部楼层
kwok 发表于 2022-11-14 13:54
FILLET 空格 p 空格。基本是这样,加个ssget和循环处理就行了。
大佬,多线段,选择圆弧,框选批量修改相同圆弧,如何改?
发表于 2023-12-25 20:57:50 | 显示全部楼层
(setq
不要生成封闭的多段线,怎么处理?谢谢
发表于 2023-12-26 15:39:51 | 显示全部楼层
     (command "explode" ee)
     (setq i (1+ i))
加了一行 (command "explode" ee)把封闭的多段线给分解了
发表于 2023-12-31 16:13:57 | 显示全部楼层
能不能用记住上次输入的R值,直接回车再次重复执行,输入则是新值
GMT+8, 2026-1-14 18:35 , Processed in 0.189693 second(s), 20 queries , Gzip On.
