楼主: 664571221
[提问] 各位大佬看下,相同文字加框的功能
发表于 2023-7-10 16:21:37 | 显示全部楼层
  1. (defun C:tt ()
  2.         (command "UNDO" "be")
  3.         (if (setq E  (cdr (assoc 1 (entget (car (entsel))))))
  4.                 (progn
  5.                         (setq ss (ssget (list '(0 . "TEXT")(cons 1 E))))
  6.                         (setq ss_gs (sslength ss))
  7.                         (setq i 0)
  8.                         (repeat ss_gs
  9.                                 (setq ss_n (ssname ss i))
  10.                                 (command "UCS" "e" ss_n)
  11.                                 (setq ss_data (entget ss_n))
  12.                                 (setq text_box (textbox ss_data))
  13.                                 (setq text_box_1 (car text_box))
  14.                                 (setq text_box_3 (cadr text_box))
  15.                                 (command "RECTANG" text_box_1 text_box_3)
  16.                                 (setq i (1+ i))
  17.                         )
  18.                         (command "UCS" "")
  19.                         (princ (strcat"\n共有" (itoa ss_gs) "个相同文字加框"))
  20.                 )
  21.         )
  22.         (command "UNDO" "e")
  23.         (print)
  24. )
 楼主| 发表于 2023-7-10 20:39:01 | 显示全部楼层
vitalgg 发表于 2023-7-10 13:39
源码:
https://gitee.com/atlisp/packages/blob/main/at-text/box.lsp
兄弟你考虑的很全面啊
 楼主| 发表于 2023-7-10 20:40:41 | 显示全部楼层
谢谢派大.......
 楼主| 发表于 2023-7-10 20:41:54 | 显示全部楼层
发表于 2023-7-14 08:08:26 | 显示全部楼层
http://bbs.mjtd.com/thread-175477-1-1.html
这个查找的改改几句代码就可以加框了
发表于 2023-7-14 08:32:37 | 显示全部楼层
感谢分享,学习一下
 楼主| 发表于 2023-7-14 10:17:43 | 显示全部楼层
这个查找的改改几句代码就可以加框了
大佬能不能改下,我改不来
GMT+8, 2026-1-15 08:38 , Processed in 0.207488 second(s), 19 queries , Gzip On.
