楼主: wuzhenif
楼梯梯段尺寸标注等式
发表于 2023-9-20 20:26:51 | 显示全部楼层
(defun c:cc ( / tbk ss n i cljl xssz fds cljl0)
    (setvar "cmdecho" 0)
  (princ "\n 选择需要等式标注的标注:")
  (setq ss (ssget '((0 . "DIMENSION")))
        n (sslength ss)
        i 0        )
  (initget "S")
  (if (= (setq fds (getstring "\n 输入等分的数量[恢复标注(S)]")) "S")
    (cond (
           (while (< i n)
             (setq cljl0 (rtos(vla-get-Measurement (Vlax-Ename->Vla-Object (ssname ss i))) 2 1))
             (vla-put-TextOverride (Vlax-Ename->Vla-Object (ssname ss i)) cljl0)
             (setq i (+ i 1))
     (while (< i n)
       (setq cljl (vla-get-Measurement (Vlax-Ename->Vla-Object (ssname ss i)))
       (setq tbk (rtos (/ cljl (atof fds)) 2 1)
             xssz (strcat tbk "x" fds "=" (rtos cljl 2 1)))
       (vla-put-TextOverride (Vlax-Ename->Vla-Object (ssname ss i)) xssz)
       (setq i (+ i 1))
  (setvar "cmdecho" 1)
(princ "\n 加载成功! 启动命令:W_DSBZ-----BY WW \n")
发表于 2023-10-8 11:40:33 | 显示全部楼层
谢谢分享源码,已改为自己想要的显示结果,每家公司的现场表现不同,有的显示一排,有的显示两排,希望不要介意。
如果显示结果可以修改显示格式就好了。比如:(下面是我们对应的公司现场各有各的规范要求)
GMT+8, 2026-1-11 03:59 , Processed in 0.165650 second(s), 17 queries , Gzip On.
