楼主: 小毛草
[源码] 将各种线型反向——多选版
发表于 2025-7-25 16:41:44 | 显示全部楼层
     样条曲线这样就对了。
    ;;━━━━━━ 样条曲线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "SPLINE")
           (command "SPLINEDIT" ENT1 "r" "")
           (command "pedit" e "x" "")
           ;;(command "")暂时注释
发表于 2025-7-25 16:43:31 | 显示全部楼层
修改后的完整程序。(defun C:FS (/ ss i ent ENT1 Q Q2 cp r os)
  (prompt "\n将各种线型反向——多选版")
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  ;; 多选对象
  (if (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,LWPOLYLINE,SPLINE"))))
      (repeat (setq i (sslength ss))
        (setq ent (ssname ss (setq i (1- i)))
              ENT1 ent
              ENT (entget ENT1))
        (cond
          ;;━━━━━━ 多段线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "LWPOLYLINE")
           (reverseLwp ENT1))
          ;;━━━━━━ 直线处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "LINE")
           (setq Q (cons 10 (cdr (assoc 11 ENT)))
                 Q2 (cons 11 (cdr (assoc 10 ENT))))
           (entmod (subst Q2 (assoc 11 ENT) (subst Q (assoc 10 ENT) ENT)))
           ;;(command "")暂时注释
          ;;━━━━━━ 圆弧处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "ARC")
           (command "pedit" ENT1 "y" "n")
           (reverseLwp (entlast))
           (entdel ENT1)
          ;;━━━━━━ 圆处理 ━━━━━━
          ((= (cdr (assoc 0 ENT)) "CIRCLE")
           (setq cp (cdr (assoc 10 ENT))
                 r (cdr (assoc 40 ENT)))
           (entmake
             (list
               '(0 . "LWPOLYLINE")
               '(100 . "AcDbEntity")
               '(67 . 0)
               '(410 . "Model")
               '(100 . "AcDbPolyline")
               '(90 . 2)
               '(70 . 129)
               (cons 10 (polar cp 0 r))
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
               (cons 10 (polar cp pi r))
               '(40 . 0)
               '(41 . 0)
               '(42 . -1)
           (command "_matchprop" ENT1 (entlast) "")
           (entdel ENT1)
    (prompt "\n未选择有效对象")
  (setvar "osmode" os)
;;; 多段线反转子程序(保持不变)
(defun reverseLwp (ent1 / a pl how li1 li2 li3)
  (setq pl (entget ent1 '("*")) how nil)
  (foreach an pl
    (if (setq a (member (car an) '(10 40 41 42)))
      (setq how t))
    (cond
      ((not how)
       (setq li1 (cons an li1)))
      ((and how a)
       (cond
         ((= (car an) 40) (setq an (cons 41 (cdr an))))
         ((= (car an) 41) (setq an (cons 40 (cdr an))))
         ((= (car an) 42) (setq an (cons 42 (- 0 (cdr an)))))
         (t an)
       (setq li2 (cons an li2))
      ((and how (not a))
       (setq li3 (cons an li3)))
  (entmod (append (reverse li1)
                  (append (cdddr li2) (list (car li2) (cadr li2) (caddr li2)))
                  (reverse li3)))
GMT+8, 2026-1-12 07:49 , Processed in 0.162391 second(s), 19 queries , Gzip On.
