楼主: 韩飞翔
[源码] 同位置复制
发表于 2025-8-3 10:29:20 | 显示全部楼层
自己折腾了一个满足缩放和旋转,不过只能以块参照为参考
由于不想计算其它图形与参考图形之间的缩放和旋转量,因此只做以块参照为例,进行了比较偷懒的处理方法,导致使用场景受限,偷懒的办法是把要复制的东西做到一个无名图块,以选定的参考对象(块参照)的基点、插入点,比例,旋转等对新做的图块内的对象通过平移,缩放和旋转进行纠正(由于处理方法过于简单,参考对象必须XY比例一致),然后对所选的每一个要放置东西的图块插入点位置按相应的比例和旋转角插入图块
  1. (vl-load-com)
  2. (defun l2array(l / A)
  3.       (vlax-safearray-fill(vlax-make-safearray 9(cons 0(1-(length l))))
  4.   (mapcar(function(lambda(x / a)(setq a(type x))(cond((='ename a)(vlax-ename->vla-object x))((='VLA-OBJECT a)x))))l)))
  5. (defun c:tt(/ *doc *model *blocks blk blkname s1 s e p Origin ang bl o)
  6.   (setq *doc(vlax-get-property(vlax-get-acad-object)'activedocument)
  7.   *model(vlax-get-property *doc 'modelspace)
  8.   *blocks(vlax-get-property *doc'blocks))
  9.   (while(and(or(PROMPT"\n选选择要复制的图元对象")(setq s1(ssget)))
  10.       (or(PROMPT"\n选择参考图元对象(参照块)")(setq e(ssget":E:S"'((0 . "insert")))))
  11.       (setq e(vlax-ename->vla-object(ssname e 0)))
  12.       (or(PROMPT"\n选择要放置的位置(与参考对象同名块)")
  13.          (setq blkm(vlax-get-property e'name) s(ssget(list'(0 . "insert")(cons 2 blkm))))))
  14.     (setq p1(vlax-safearray->list(vlax-variant-value(vlax-get-property e'InsertionPoint)))
  15.     s1(vl-remove-if'listp(mapcar'cadr(ssnamex s1)))
  16.     p(apply'mapcar(cons'list(apply'append(mapcar'(lambda(x / a b)
  17.                (vlax-invoke-method(vlax-ename->vla-object x)'getboundingbox'a 'b)
  18.                (list(vlax-safearray->list a)(vlax-safearray->list b)))s1))))
  19.     p(mapcar'+'(0 0)(car(vl-sort(mapcar(function(lambda(y)(mapcar'(lambda(x)(apply y x))p)))'(min max))
  20.               '(lambda(x y)(>(distance p1 x)(distance p1 y))))))
  21.     Origin(vlax-get-property(vlax-invoke-method *blocks'item blkm)'Origin)
  22.     blk(vlax-invoke-method *blocks'add Origin"*U")
  23.     blkname(vlax-get-property blk'name)
  24.     ang(-(+ pi pi)(vlax-get-property e'Rotation))
  25.     bl(/ 1(vlax-get-property e 'XScaleFactor)))
  26.     (vlax-invoke-method *doc'copyobjects(l2array s1)blk)
  27.     (vlax-for x blk
  28.       (vlax-invoke-method x 'move(vlax-3d-point p1)Origin)
  29.       (vlax-invoke-method x 'ScaleEntity Origin bl)
  30.       (vlax-invoke-method x 'rotate Origin ang))
  31.     (vlax-for x (vlax-get-property *doc'ActiveSelectionSet)
  32.       (setq o(vlax-invoke-method *model'InsertBlock
  33.          (vlax-get-property x 'InsertionPoint)
  34.          blkname
  35.          (vlax-get-property x'XScaleFactor)
  36.          (vlax-get-property x'YScaleFactor)
  37.          (vlax-get-property x'ZScaleFactor)
  38.          (vlax-get-property x'Rotation)))
  39.       (or(not(VL-CATCH-ALL-ERROR-P(VL-CATCH-ALL-APPLY(function vlax-invoke-method)(list o 'exlpode))))
  40.    (vlax-invoke-method o 'delete))
  41.       )
  42.     (VL-CATCH-ALL-ERROR-P(VL-CATCH-ALL-APPLY(function vlax-invoke-method)(list blk 'exlpode)))
  43.     )
  44. )
大佬牛掰  发表于 2025-8-4 11:15
参与人数 2明经币 +2 收起 理由
USER2128 + 1 很给力!
cj52000 + 1 很给力!
回复 支持 3 反对 0
发表于 2025-8-3 11:35:25 | 显示全部楼层
llsheng_73 发表于 2025-8-3 10:29
楼主放个测试图吧,看看能不能同时满足缩放和旋转
啊, 这个好,这个好,使用场景又丰富了
发表于 2025-8-4 04:29:20 | 显示全部楼层
看了 llsheng_73 的演示图,使用体验应该更好。
我的是使用矩阵变换,不支持不等比例缩放
wosiguwozai0830 + 1 这个很好用,感谢大佬分享!
发表于 2025-8-4 11:00:01 | 显示全部楼层
cj52000 发表于 2025-8-3 11:35
啊, 这个好,这个好,使用场景又丰富了
http://bbs.mjtd.com/forum.php?mo ... &fromuid=202795
用的块搞出来了
发表于 2025-8-4 11:04:39 | 显示全部楼层
我的是使用矩阵变换,不支持不等比例缩放
正好下载这个来好好学习,高飞鸟论矩阵很详细,但一直没认真学习,吃透了矩阵变换的话,很多地方很简单的样子
发表于 2025-8-5 08:34:21 | 显示全部楼层
llsheng_73 发表于 2025-8-4 11:00
http://bbs.mjtd.com/forum.php?mod=redirect&goto=findpost&ptid=193276&pid=1027815&fromuid=202795
谢谢大神,很好用,有个请求,能不能增加支持多段线,因为工作中块用的较少,多段线比较多
发表于 2025-8-5 11:05:08 | 显示全部楼层
多段线的话一条线封闭的可以,哪怕经过了旋转,但和参考对象之间,它们的起点和节点顺序是一样的,可以把起点当成块参照的插入点来看待,从参考对象众多节点里边找一个到起点最远的点作为它的基准方向,以距离作为参考比例,往其它线里边放的时候,根据同样的两个点的方向和距离进行方向改正和缩放处理,实际上可以通过transfromby来完成,如果对变换矩阵熟悉的话,不熟悉也可以搞定,只是麻烦些
发表于 2025-8-5 19:45:27 | 显示全部楼层
这个同位复制,通过计算节点相对坐标  然后 在各图框内重构图形也是可以的   不等比的也可重构实现
发表于 2025-8-20 08:48:32 | 显示全部楼层
感谢楼主分享,
GMT+8, 2026-1-11 22:30 , Processed in 0.198617 second(s), 21 queries , Gzip On.
