楼主: jie10121
我是新手,求助入门
 楼主| 发表于 2004-4-27 13:17:00 | 显示全部楼层
我在书上找到另一种写法。我也不是很懂。
(defun C:Star()
                 (initget 1)
         (setq Center(getpoint"星的中心:"))
         (initget(+ 1 2 4))
                (setq OutRad (getdist"外圆半径:"Center))
         (initget(+1 2 4))
         (setq InRad (getdist"内圆半径:"Center))
         (initget(+1 2 4))
         (setq Points(getint"角点数:"))
(setq Incr (/(* 2 pi) Points))
(setq Incr2 (/Incr2))
(command "LINE")
(setq Count 0)
(while (<Count Points)
                         (command (polar Center (* Count Incr ) OutRad))
                         (if (=Count 0)
        (command "width" "0" "0"))
                         (command (polar Center (+(* Count Incr)Incr2) inRad))
                         (setq Count (1+count ))
(command "close")
修改稿
 楼主| 发表于 2004-4-27 16:06:00 | 显示全部楼层
(if (=Count 0)
        (command "width" "0" "0"))是什么意思啊?特别是"width" "0" "0"是什么参数呢?
 楼主| 发表于 2004-4-27 20:59:00 | 显示全部楼层
我还有一个问题,关于六楼的图。圆环里面套小圆,那些小圆是不能相交的,怎么样才能确保小圆不相交,用什么条件呢?真正的轴承是怎样的呢?
救命啊,各位大哥。!!!
GMT+8, 2025-12-17 19:24 , Processed in 0.152243 second(s), 20 queries , Gzip On.
