楼主: 佣兵
请大家帮忙解决一下,谢了
发表于 2004-10-28 21:50:00 | 显示全部楼层
改成这样 (command "circle" p1 1 )
 楼主| 发表于 2004-10-28 22:02:00 | 显示全部楼层
谢谢楼上兄的提醒,太低级的错误,惭愧啊,另外问一句:“实心圆怎么做?“
发表于 2004-10-28 22:29:00 | 显示全部楼层
(defun c:test()
(setvar "DONUTID"0)
(setq no1 (ureal 1 "" "半径" no1))
(setvar "DONUTOD"no1)
(command "donut" "" "")
(defun ureal (bit kwd msg def / inp)
(if def
(setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")
bit (* 2 (fix (/ bit 2)))
(setq msg (strcat "\n" msg ": "))
(initget bit kwd)
(setq inp (getreal msg))
(if inp inp def)
 楼主| 发表于 2004-10-28 22:45:00 | 显示全部楼层
谢谢楼上的兄弟,这个论坛的兄弟太棒了
GMT+8, 2025-12-16 23:51 , Processed in 0.167745 second(s), 19 queries , Gzip On.
