楼主: iceberg2509
dcl文件与lsp文件编译后如何加载引用
发表于 2004-11-18 19:15:00 | 显示全部楼层
唉,把你的LSP文件和DCL文件都贴上来吧,究竟你写好了没有?
发表于 2004-11-18 19:32:00 | 显示全部楼层
很简单的问题,没那么麻烦吧!呵呵
 楼主| 发表于 2004-11-18 21:16:00 | 显示全部楼层
好的,例程源代码如下: ;;lisp文件:ctk.lsp ;;; ============================插入图框函数===============================
;; 命令名: ctk
;; 作 者: ICEBERG
;; 时 间: 2002年12月
;;; ===================== load-time error checking ============================
(defun ai_abort (app msg)
(defun *error* (s)
(if old_error
(setq *error* old_error)
(if msg
(alert
(strcat " Application error: " app " \n\n " msg " \n")
(exit)
) ;;; Check to see if AI_UTILS is loaded, If not, try to find it,
;;; and then try to load ;;;
;;; If it can't be found or it can't be loaded, then abort the
;;; loading of this file immediately, preserving the (autoload)
;;; stub function. (cond
((and ai_dcl (listp ai_dcl))) ; it's already loaded. ((not (findfile "ai_utils.lsp")) ; find it
(ai_abort "CTK"
(strcat "Can't locate file AI_UTILS.LSP."
"\n Check support directory."
) ((eq "failed" (load "ai_utils" "failed")) ; load it
(ai_abort "CTK" "Can't load file AI_UTILS.LSP")
) (if (not (ai_acadapp)) ; defined in AI_UTILS.LSP
(ai_abort "CTK" nil) ; a Nil <msg> supresses
) ; ai_abort's alert box dialog.
;;; ==================== end load-time operations ===========================
;;; ====================== 主函数程序 ==============================
(defun c:ctk (/ PaperFile appnames img_number
edt_scale1 edt_scale2 old_cmd old_error
dcl_id but_flag what_next
) ;; =====================初始化==========================
(defun tz_defaults ()
(setq img_number
"0"
but_flag 1
(select_name)
(setq appnames '("A0" "A1" "A2" "A3" "A4" "A0加长图框" "清单"))
(start_list "pop_name")
(mapcar 'add_list appnames)
(end_list)
(set_tile "edt_scale1" "1")
(setq edt_scale1 (get_tile "edt_scale1"))
(set_tile "edt_scale2" "1")
(setq edt_scale2 (get_tile "edt_scale2"))
(set_tile "but_hor" "1")
) ;; ======================= 选择图象函数 ==========================
(defun select_name (/ filename)
(cond
((= "5" img_number)
(setq PaperFile "Haf")
((= "6" img_number)
(setq PaperFile "New_qd")
((= but_flag 1)
(setq PaperFile (strcat "Ha" img_number))
(T
(setq PaperFile (strcat "Va" img_number))
) (if (setq filename (findfile "Iceberg.slb"))
(start_image "image")
(fill_image
0
0
(dimx_tile "image")
(dimy_tile "image")
-16
(slide_image
0
0
(dimx_tile "image")
(dimy_tile "image")
(strcat filename "(" PaperFile ")")
(end_image)
) ;;==============图像显示控制函数======================
(defun tk_control ()
(if (or (= "5" img_number) (= "6" img_number))
(mode_tile "but_hor" 1)
(mode_tile "but_ver" 1)
(mode_tile "but_hor" 0)
(mode_tile "but_ver" 0)
(select_name)
) ;;===================== 插入图框函数 ==============================
(defun insert_tuzhi (/ InsPoint scale rotate)
(setq PaperFile (findfile (strcat PaperFile ".dwg")))
(if PaperFile
(setq rotate 0 InsPoint '(0 0)
scale (/ (atof edt_scale2) (atof edt_scale1))
(setvar "dimscale" scale)
(setvar "ltscale" scale)
(setvar "clayer" "0")
(repeat 3
(command ".purge" "b" "" "n")
(command ".insert" PaperFile InsPoint scale "" rotate)
(command ".zoom" "all")
(command ".explode" "l")
(alert "没有找到指定的图框!")
) ;;======================= 数据检查函数 ======================
(defun check_tuzhi_data ()
(cond
((or (not edt_scale1) (= "" edt_scale1))
(set_tile "error" " 请输入比例!")
(mode_tile "edt_scale1" 2)
nil
((not (distof edt_scale1 2))
(set_tile "error" " 比例只能为数字,请重新输入!")
(mode_tile "edt_scale1" 3)
nil
((or (not edt_scale2) (= "" edt_scale2))
(mode_tile "edt_scale2" 2)
nil
((not (distof edt_scale2 2))
(mode_tile "edt_scale2" 3)
nil
(T (done_dialog 2))
) ;;========================== 控件驱动函数 ============================
(defun insert_tuzhi_main ()
(setq what_next 4)
(while (< 2 what_next)
(if (not (new_dialog "ctk" dcl_id))
(exit)
(tz_defaults) (action_tile
"pop_name"
"(rs_error)(setq img_number $value)(tk_control)"
(action_tile
"but_hor"
"(rs_error)(setq but_flag 1)(select_name)"
(action_tile
"but_ver"
"(rs_error)(setq but_flag 2)(select_name)"
(action_tile
"edt_scale1"
"(rs_error)(setq edt_scale1 $value)"
(action_tile
"edt_scale2"
"(rs_error)(setq edt_scale2 $value)"
(action_tile "accept" "(check_tuzhi_data)")
(action_tile "cancel" "(done_dialog 0)")
(setq what_next (start_dialog))
) ;end while ;; If OK was picked...
(if (= what_next 2)
(insert_tuzhi)
) ;;=========== 清除错误信息 ===========
(defun rs_error ()
(set_tile "error" "")
) ;;==========容错函数=======
(defun MyError (msg)
(if (or (= msg "Function cancelled")
(= msg "quit / exit abort")
(= msg "函数被取消")
(= msg "函数已取消")
(princ (strcat "\n 错误:" msg "\n"))
) (setvar "clayer" clayer)
(setvar "cmdecho" old_cmd)
(setq old_cmd (getvar "cmdecho") ; save current setting of cmdecho
clayer (getvar "clayer")
old_error *error*
*error* MyError
(setvar "cmdecho" 0)
(cond
((not (ai_notrans))) ; transparent not OK
((not (setq dcl_id (ai_dcl "ctk"))))
(T
(graphscr)
(ai_undo_push)
(insert_tuzhi_main) ; proceed!
(ai_undo_pop)
) (setq *error* old_error)
(princ " 插入图框程序已装载!")
(princ) ;;dcl文件:ctk.dcl // 图框对话框驱动程序 //
ctk : dialog {
label="插入图框";
: boxed_column {
label="预览";
: image {
key="image" ;
// width = 16 ;
height = 9 ;
: boxed_column {
label="图幅";
: row {
: popup_list {
key="pop_name" ;
: radio_row {
: radio_button {
label="横幅";
key="but_hor";
: radio_button {
label="竖幅";
key="but_ver";
: boxed_column {
label="比例";
: row {
: edit_box {
key="edt_scale1";
: text {
label=" :";
: edit_box {
key="edt_scale2";
spacer;
spacer;
ok_cancel_err;
} 希望诸位高手编译后能告诉我怎么是对话框显现出来。谢谢!!
发表于 2004-11-19 08:29:00 | 显示全部楼层
You don't have to change anything in your code. Your problem probably is caused by the way your build the .vlx file.
发表于 2004-11-19 09:13:00 | 显示全部楼层
I finally found that your problem maybe caused by ai_utils.lsp
I change (setq dcl_id (ai_dcl "ctk"))) to (setq dcl_id (load_dialog "ctk")))) and it works!
发表于 2004-11-19 13:59:00 | 显示全部楼层
各位大侠﹐怎么我的".lsp"文件打包编译后是".fas"文件﹐不是各位所说的".vlx"文件呢?
我用的是AutoCAD Mechanical 2000 自带的visual lisp编译器
发表于 2004-11-19 16:13:00 | 显示全部楼层
用文件菜单下的生成应用程序向导建立VLX程序
 楼主| 发表于 2004-11-19 21:10:00 | 显示全部楼层
alin发表于2004-11-19 9:13:00I finally found that your problem maybe caused by ai_utils.lsp I change (setq dcl_id (ai_dcl \"ctk\"))) to (setq dcl_id (load_dialog \"ctk\")))) and it...
谢谢斑竹,问题解决
发表于 2004-11-19 22:47:00 | 显示全部楼层
floriya发表于2004-11-19 13:59:00各位大侠﹐怎么我的\".lsp\"文件打包编译后是\".fas\"文件﹐不是各位所说的\".vlx\"文件呢? 我用的是AutoCAD Mechanical 2000 自带的visual lisp编译器
fas文件是单个的,vlx文件才是一个包,他们都生成在你保存的工程文件的目录处,找找看,都有,一个工程文件只有一个vlx文件,却可能有很多个fas文件。
发表于 2008-11-4 20:35:00 | 显示全部楼层
我复制下来,运行了一下,是显示语法错误,根本不能运行。。。。。
GMT+8, 2025-12-16 10:51 , Processed in 0.181400 second(s), 18 queries , Gzip On.
