楼主: yulijin608
vb编程68例
 楼主| 发表于 2005-1-6 11:44:00 | 显示全部楼层
41. 修改窗体系统菜单
module:
Public Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long
Public Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Public Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal lpPrevWndFunc As Long, ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Public Declare Function GetSystemMenu Lib "user32" (ByVal hwnd As Long, ByVal bRevert As Long) As Long
Public Declare Function AppendMenu Lib "user32" Alias "AppendMenuA" (ByVal hMenu As Long, ByVal wFlags As Long, ByVal wIDNewItem As Long, ByVal lpNewItem As Any) As Long
Public Const WM_SYSCOMMAND = &H112
Public Const GWL_WNDPROC = (-4)
Public Const MF_STRING = &H0&
Public Const MF_SEPARATOR = &H800&
Public OldWindowProc As Long
' 保存默认的窗口函数地址
Public SysMenuHwnd As Long
Public Function SubClass1_WndMessage(ByVal hwnd As Long, ByVal Msg As Long, ByVal wp As Long, ByVal lp As Long) As Long
If Msg <> WM_SYSCOMMAND Then
SubClass1_WndMessage = CallWindowProc(OldWindowProc, hwnd, Msg, wp, lp)
' 如果消息不是WM_SYSCOMMAND,就调用默认的窗口函数处理
Exit Function
End If
Select Case wp
Case 2001
Call MsgBox("本程序实现了修改系统菜单的功能 ", vbOKOnly + vbInformation)
Case 2003
Call GetSystemMenu(Form1.hwnd, True)
Call SetWindowLong(Form1.hwnd, GWL_WNDPROC, OldWindowProc)
Call MsgBox("已经恢复了默认的系统菜单 ", vbOKOnly + vbInformation)
Case Else
Exit Function
End Select
SubClass1_WndMessage = True
End Function
窗体:
Private Sub Form_Load()
OldWindowProc = GetWindowLong(Form1.hwnd, GWL_WNDPROC)
' 取得窗口函数的地址
Call SetWindowLong(Form1.hwnd, GWL_WNDPROC, AddressOf SubClass1_WndMessage)
' 用SubClass1_WndMessage代替窗口函数处理消息
SysMenuHwnd = GetSystemMenu(Form1.hwnd, False)
Call AppendMenu(SysMenuHwnd, MF_SEPARATOR, 2000, vbNullString)
Call AppendMenu(SysMenuHwnd, MF_STRING, 2001, "关于本程序(&A)")
Call AppendMenu(SysMenuHwnd, MF_SEPARATOR, 2002, vbNullString)
Call AppendMenu(SysMenuHwnd, MF_STRING, 2003, "恢复系统菜单(&R)")
End Sub
Private Sub Form_Unload(Cancel As Integer)
If OldWindowProc <> GetWindowLong(Form1.hwnd, GWL_WNDPROC) Then
End If
End Sub
42.如何在小画面上显示大图片
方法一:
一个picturebox控件,一个image控件(以picturebox为容器),图片加载在image中,一个HScroll1,VScroll1(以picturebox为容器)。
Private Sub Bar1_Change()
Image1.Left = -bar1.Value
End Sub Private Sub Bar2_Change()
Image1.Top = -Bar2.Value
End Sub Private Sub Form_Load()
Image1.Left = 0
Image1.Top = 0
bar1.SmallChange = 300
Bar2.SmallChange = 300
bar1.Max = Image1.Width - Picture1.Width
Bar2.Max = Image1.Height - Picture1.Height
bar1.Min = 0
Bar2.Min = 0
End Sub
方法二:利用鼠标移动图片
Dim ix As Integer
Dim iy As Integer
Image1.Left = 0
Image1.Top = 0
End Sub
Private Sub Image1_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
If Button = vbLeftButton Then
ix = X
iy = Y
End If
End Sub
Private Sub Image1_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
Dim ipx As Integer
Dim ipy As Integer
ipx = Image1.Left + X - ix
ipy = Image1.Top + Y - iy
If ipx > 0 Then
Image1.Left = 0
Else
If ipx < Picture1.Width - Image1.Width Then
ipx = Picture1.Width - Image1.Width
Else
Image1.Left = ipx
End If
End If
If ipy > 0 Then
Image1.Top = 0
Else
If ipy < Picture1.Height - Image1.Height Then
ipy = Picture1.Height - Image1.Height
Else
Image1.Top = ipy
End If
End If
End If
End Sub
Private Sub Image1_MouseUp(Button As Integer, Shift As Integer, X As Single, Y As Single)
Me.MousePointer = 0
End Sub 43. 使窗体不出屏幕左边界
module:
Option Explicit
Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" _
Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" _
Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" _
(ByVal lpPrevWndFunc As Long, ByVal hwnd As Long, ByVal Msg As Long, _
ByVal wParam As Long, ByVal lParam As Long) As Long Declare Sub CopyMemory Lib "KERNEL32" Alias "RtlMoveMemory" ( _
lpvDest As Any, lpvSource As Any, ByVal cbCopy As Long)
Public Const WM_WINDOWPOSCHANGING = &H46
Type WINDOWPOS
hwnd As Long
hWndInsertAfter As Long
x As Long
y As Long
cx As Long
cy As Long
flags As Long
End Type
Public preWinProc As Long
'而重点就在於Window重新定位之前会传
'出WM_WINDOWPOSCHANGING这个讯息,而lParam指向一个WINDOWPOS的STRUCTURE。
Public Function wndproc(ByVal hwnd As Long, ByVal Msg As Long, _
Dim lwd As Long, hwd As Long
If Msg = WM_WINDOWPOSCHANGING Then
Dim WPOS As WINDOWPOS
CopyMemory WPOS, ByVal lParam, Len(WPOS)
If WPOS.x < 0 Then
WPOS.x = 0
CopyMemory ByVal lParam, WPOS, Len(WPOS)
End If
End If
'将之送往原来的Window Procedure
wndproc = CallWindowProc(preWinProc, hwnd, Msg, wParam, lParam)
End Function
窗体中
Sub Form_Load()
Dim ret As Long
'记录原本的Window Procedure的位址
preWinProc = GetWindowLong(Me.hwnd, GWL_WNDPROC)
ret = SetWindowLong(Me.hwnd, GWL_WNDPROC, AddressOf wndproc)
End Sub Private Sub Form_Unload(Cancel As Integer)
Dim ret As Long
'取消Message的截取,而使之又只送往原来的Window Procedure
ret = SetWindowLong(Me.hwnd, GWL_WNDPROC, preWinProc)
End Sub
44.打开指定的窗体
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Const SW_SHOWNORMAL = 1
Private Sub Command1_Click() '我的文档
ShellExecute Me.hwnd, "open", "explorer", vbNullString, vbNullString, 1
End Sub
Private Sub Command2_Click() '我的电脑
ShellExecute Me.hwnd, "open", "explorer", "::{20D04FE0-3AEA-1069-A2D8-08002B30309D}", vbnulstring, 1
End Sub
Private Sub Command3_Click() '网上邻居
ShellExecute Me.hwnd, "open", "explorer", "::{208d2c60-3aea-1069-a2d7-08002b30309d}", vbNullString, 1
End Sub
Private Sub Command4_Click() '回收站
ShellExecute Me.hwnd, "open", "explorer", "::{645ff040-5081-101b-9f08-00aa002f954e}", vbNullString, 1
End Sub
Private Sub Command5_Click() '控制面板
ShellExecute Me.hwnd, "open", "explorer", "::{21ec2020-3aea-1069-a2dd-08002b30309d}", vbNullString, 1
End Sub
Private Sub Command6_Click() '打开指定的路径
ShellExecute Me.hwnd, "open", "D:\vb练习事例", vbNullString, vbNullString, 1
End Sub
Private Sub Command7_Click() '音量控制
Shell "sndvol32.exe", vbNormalFocus
End Sub
 楼主| 发表于 2005-1-6 11:47:00 | 显示全部楼层
45.窗体分割条 splitter为一picturebox控件。
Option Explicit
Private Const SPLT_WDTH As Integer = 35
Private currSplitPosX As Long
Dim CTRL_OFFSET As Integer
Dim SPLT_COLOUR As Long
CTRL_OFFSET = 5
SPLT_COLOUR = &H808080
currSplitPosX = &H7FFFFFFF
ListLeft.AddItem "VB俱乐部"
ListLeft.AddItem "VB动画篇"
ListLeft.AddItem "VB网络篇"
ListLeft.AddItem "VB控件类"
ListLeft.AddItem "VB界面类"
TextRight = "经常见到窗体上有二个相邻的列表框,可以用鼠标任意拉动中间分割条,改变列表框大小。"
End Sub
Private Sub Form_Resize()
Dim x1 As Integer
Dim x2 As Integer
Dim height1 As Integer
Dim width1 As Integer
Dim width2 As Integer
On Error Resume Next
height1 = ScaleHeight - (CTRL_OFFSET * 2)
x1 = CTRL_OFFSET
width1 = ListLeft.Width
x2 = x1 + ListLeft.Width + SPLT_WDTH - 1
width2 = ScaleWidth - x2 - CTRL_OFFSET
ListLeft.Move x1% - 1, CTRL_OFFSET, width1, height1
TextRight.Move x2, CTRL_OFFSET, width2 + 1, height1
Splitter.Move x1 + ListLeft.Width - 1, CTRL_OFFSET, SPLT_WDTH, height1
End Sub
Private Sub Splitter_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
Splitter.BackColor = SPLT_COLOUR
currSplitPosX = CLng(X)
Else
If currSplitPosX <> &H7FFFFFFF Then Splitter_MouseUp Button, Shift, X, Y
End If
End Sub
Private Sub Splitter_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
If currSplitPosX& <> &H7FFFFFFF Then
If CLng(X) <> currSplitPosX Then
Splitter.Move Splitter.Left + X, CTRL_OFFSET, SPLT_WDTH, ScaleHeight - (CTRL_OFFSET * 2)
End If
End If
End Sub
Private Sub Splitter_MouseUp(Button As Integer, Shift As Integer, X As Single, Y As Single)
End If
Splitter.BackColor = &H8000000F
If Splitter.Left > 60 And Splitter.Left < (ScaleWidth - 60) Then
ListLeft.Width = Splitter.Left - ListLeft.Left
ElseIf Splitter.Left < 60 Then
ListLeft.Width = 60
Else
ListLeft.Width = ScaleWidth - 60
End If
Form_Resize
End If End Sub
46.托盘程序
module:
Option Explicit
Public NewForm As Form
Public NewMenu As Menu
Public Const WM_USER = &H400
Public Const WM_LBUTTONUP = &H202
Public Const WM_MBUTTONUP = &H208
Public Const WM_RBUTTONUP = &H205
Public Const TRAY_CALLBACK = (WM_USER + 1001&)
Public Const GWL_USERDATA = (-21)
Public Const NIF_ICON = &H2
Public Const NIF_TIP = &H4
Public Const NIM_ADD = &H0
Public Const NIF_MESSAGE = &H1
Public Const NIM_MODIFY = &H1
Public Const NIM_DELETE = &H2
Declare Function Shell_NotifyIcon Lib "shell32.dll" Alias "Shell_NotifyIconA" (ByVal dwMessage As Long, lpData As NOTIFYICONDATA) As Long
Public Type NOTIFYICONDATA
cbSize As Long
hwnd As Long
uID As Long
uFlags As Long
uCallbackMessage As Long
hIcon As Long
szTip As String * 64
End Type
Private NOTI As NOTIFYICONDATA
Public Function NewWindone(ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
If Msg = TRAY_CALLBACK Then
If lParam = WM_LBUTTONUP Then
' 单击左键,弹出窗口
If NewForm.WindowState = vbMinimized Then _
NewForm.WindowState = NewForm.LastState
NewForm.SetFocus
Exit Function
End If
If lParam = WM_RBUTTONUP Then
' 单击右键,弹出菜单
NewForm.PopupMenu NewMenu
Exit Function
End If
End If
NewWindone = CallWindowProc(preWinProc, hwnd, Msg, wParam, lParam)
End Function
Public Sub AddToTray(frm As Form, mnu As Menu)
Set NewForm = frm
Set NewMenu = mnu
preWinProc = SetWindowLong(frm.hwnd, GWL_WNDPROC, AddressOf NewWindone)
With NOTI
.uID = 0
.hwnd = frm.hwnd
.cbSize = Len(NOTI)
.hIcon = frm.Icon.Handle
.uFlags = NIF_ICON
.uCallbackMessage = TRAY_CALLBACK
.uFlags = .uFlags Or NIF_MESSAGE
.cbSize = Len(NOTI)
End With
Shell_NotifyIcon NIM_ADD, NOTI
End Sub
'屏蔽托盘
Public Sub RemoveFromTray()
With NOTI
.uFlags = 0
End With
Shell_NotifyIcon NIM_DELETE, NOTI
SetWindowLong NewForm.hwnd, GWL_WNDPROC, preWinProc
End Sub Public Sub SetTrayTip(tip As String)
With NOTI
.szTip = tip & vbNullChar
.uFlags = NIF_TIP
End With
Shell_NotifyIcon NIM_MODIFY, NOTI
End Sub Public Sub SetTrayIcon(pic As Picture)
If pic.Type <> vbPicTypeIcon Then Exit Sub
With NOTI
.hIcon = pic.Handle
.uFlags = NIF_ICON
End With
End Sub
窗体中 Private Sub Form_Load()
AddToTray Me, Tray
SetTrayTip "托盘演示"
End Sub
RemoveFromTray
End Sub
47.led数值显示
添加类模块:(name属性为mcLCD)
Option Explicit
Private Type Coordinate
X As Integer
Y As Integer
End Type
Dim BasePoint As Coordinate
Dim SegWidth As Integer
Dim SegHeight As Integer
Dim p As PictureBox
Property Let BackColor(Color As Long)
p.BackColor = Color
End Property
Private Sub DrawNumber(Number As Integer)
Select Case Number
Case 0
DrawSegment (1): DrawSegment (2): DrawSegment (3): DrawSegment (4)
DrawSegment (5): DrawSegment (6)
Case 1
Case 2
DrawSegment (1): DrawSegment (2): DrawSegment (7): DrawSegment (5)
DrawSegment (4)
Case 3
DrawSegment (1): DrawSegment (2): DrawSegment (7): DrawSegment (3)
DrawSegment (4)
Case 4
DrawSegment (2): DrawSegment (3): DrawSegment (7): DrawSegment (6)
Case 5
DrawSegment (1): DrawSegment (6): DrawSegment (7): DrawSegment (3)
DrawSegment (4)
Case 6
DrawSegment (4): DrawSegment (5)
Case 7
DrawSegment (3)
Case 8
DrawSegment (5): DrawSegment (6): DrawSegment (7)
Case 9
End Select
End Sub
Private Sub DrawSegment(SegNum As Integer)
' 1
' ___
' 6 | | 2
' |-7-|
' 5 | | 3
' |___|
' 4
'画出七段数码管的七个组成部分
Select Case SegNum
Case 1
p.Line (BasePoint.X + 1, BasePoint.Y)-(BasePoint.X + SegWidth - 1, BasePoint.Y)
p.Line (BasePoint.X + 2, BasePoint.Y + 1)-(BasePoint.X + SegWidth - 2, BasePoint.Y + 1)
p.Line (BasePoint.X + 3, BasePoint.Y + 2)-(BasePoint.X + SegWidth - 3, BasePoint.Y + 2)
Case 2
p.Line (BasePoint.X + SegWidth - 1, BasePoint.Y + 1)-(BasePoint.X + SegWidth - 1, BasePoint.Y + (SegHeight \ 2) - 1)
p.Line (BasePoint.X + SegWidth - 2, BasePoint.Y + 2)-(BasePoint.X + SegWidth - 2, BasePoint.Y + (SegHeight \ 2))
p.Line (BasePoint.X + SegWidth - 3, BasePoint.Y + 3)-(BasePoint.X + SegWidth - 3, BasePoint.Y + (SegHeight \ 2) - 1)
Case 3
p.Line (BasePoint.X + SegWidth - 1, BasePoint.Y + (SegHeight \ 2) + 2)-(BasePoint.X + SegWidth - 1, BasePoint.Y + SegHeight)
p.Line (BasePoint.X + SegWidth - 2, BasePoint.Y + (SegHeight \ 2) + 1)-(BasePoint.X + SegWidth - 2, BasePoint.Y + SegHeight - 1)
p.Line (BasePoint.X + SegWidth - 3, BasePoint.Y + (SegHeight \ 2) + 2)-(BasePoint.X + SegWidth - 3, BasePoint.Y + SegHeight - 2)
Case 4
p.Line (BasePoint.X + 3, BasePoint.Y + SegHeight - 2)-(BasePoint.X + SegWidth - 3, BasePoint.Y + SegHeight - 2)
p.Line (BasePoint.X + 2, BasePoint.Y + SegHeight - 1)-(BasePoint.X + SegWidth - 2, BasePoint.Y + SegHeight - 1)
p.Line (BasePoint.X + 1, BasePoint.Y + SegHeight)-(BasePoint.X + SegWidth - 1, BasePoint.Y + SegHeight)
Case 5
p.Line (BasePoint.X, BasePoint.Y + (SegHeight \ 2) + 2)-(BasePoint.X, BasePoint.Y + SegHeight)
p.Line (BasePoint.X + 1, BasePoint.Y + (SegHeight \ 2) + 1)-(BasePoint.X + 1, BasePoint.Y + SegHeight - 1)
p.Line (BasePoint.X + 2, BasePoint.Y + (SegHeight \ 2) + 2)-(BasePoint.X + 2, BasePoint.Y + SegHeight - 2)
Case 6
p.Line (BasePoint.X, BasePoint.Y + 1)-(BasePoint.X, BasePoint.Y + (SegHeight \ 2) - 1)
p.Line (BasePoint.X + 1, BasePoint.Y + 2)-(BasePoint.X + 1, BasePoint.Y + (SegHeight \ 2))
p.Line (BasePoint.X + 2, BasePoint.Y + 3)-(BasePoint.X + 2, BasePoint.Y + (SegHeight \ 2) - 1)
Case 7
p.Line (BasePoint.X + 3, BasePoint.Y + (SegHeight \ 2) - 1)-(BasePoint.X + SegWidth - 3, BasePoint.Y + (SegHeight \ 2) - 1)
p.Line (BasePoint.X + 2, BasePoint.Y + (SegHeight \ 2))-(BasePoint.X + SegWidth - 2, BasePoint.Y + (SegHeight \ 2))
p.Line (BasePoint.X + 3, BasePoint.Y + (SegHeight \ 2) + 1)-(BasePoint.X + SegWidth - 3, BasePoint.Y + (SegHeight \ 2) + 1)
End Select
End Sub
Public Property Let Caption(ByVal Value As String)
Dim OrigX As Integer
OrigX = BasePoint.X
p.Cls
While Value <> ""
If Left$(Value, 1) <> ":" And Left$(Value, 1) <> "." Then
DrawNumber (Val(Left$(Value, 1)))
BasePoint.X = BasePoint.X + SegWidth + 3
Else
If Left$(Value, 1) = "." Then
p.Line (BasePoint.X + (SegWidth \ 2) - 4, BasePoint.Y + (SegHeight \ 2) + 6)-(BasePoint.X + (SegWidth \ 2), BasePoint.Y + (SegHeight \ 2) + 9), , BF
Else
p.Line (BasePoint.X + (SegWidth \ 2) - 4, BasePoint.Y + (SegHeight \ 2) - 6)-(BasePoint.X + (SegWidth \ 2), BasePoint.Y + (SegHeight \ 2) - 3), , BF
p.Line (BasePoint.X + (SegWidth \ 2) - 4, BasePoint.Y + (SegHeight \ 2) + 4)-(BasePoint.X + (SegWidth \ 2), BasePoint.Y + (SegHeight \ 2) + 7), , BF
End If
End If
Value = Right$(Value, Len(Value) - 1)
Wend
BasePoint.X = OrigX
End Property
Property Let ForeColor(Color As Long)
p.ForeColor = Color
End Property Public Sub NewLCD(PBox As PictureBox)
Set p = PBox
p.ScaleMode = 3 ' pixel
p.AutoRedraw = True
BasePoint.X = 2
BasePoint.Y = 2
SegHeight = p.ScaleHeight - 6
SegWidth = (SegHeight \ 2) + 2
End Sub
窗体中:
Option Explicit
Dim lcdTest1 As New mcLCD
lcdTest1.NewLCD picture1
End Sub
Private Sub Timer1_Timer()
lcdTest1.Caption = Time
End Sub
48.将部分菜单放置在窗体的最右段(如帮助等)
在菜单编辑器中在待放置于最右段的菜单前加一标题为空格的菜单,并去掉visable属性前钩号。
Private Type MENUITEMINFO
'.......请自己加上啊
End Type
Private Const MFT_RIGHTJUSTIFY = &H4000
'API函数声明
Private Declare Function SetMenuItemInfo Lib "user32" Alias "SetMenuItemInfoA" (ByVal _ hMenu As Long, ByVal un As Long, ByVal bool As Boolean, lpcMenuItemInfo As _ MENUITEMINFO) As Long
Private Declare Function GetMenuItemInfo Lib "user32" Alias "GetMenuItemInfoA" (ByVal _ hMenu As Long, ByVal un As Long, ByVal b As Long, lpMenuItemInfo As MENUITEMINFO) As Long
Private Declare Function DrawMenuBar Lib "user32" (ByVal hwnd As Long) As Long
Private Declare Function GetMenu Lib "user32" (ByVal hwnd As Long) As Long
'在窗体载入过程(也可放在其他过程)中对菜单设置进行更改
Dim my_menuItemInfo As MENUITEMINFO
Dim return_value As Long
my_menuItemInfo.cbSize = 44
my_menuItemInfo.fMask = 16
my_menuItemInfo.cch = 128
my_menuItemInfo.dwTypeData = Space$(128)
return_value = GetMenuItemInfo(GetMenu(Me.hwnd), 2, 1, my_menuItemInfo)
'这里的2请根据自己的情况而定,为正常显示在左端的菜单数
my_menuItemInfo.fType = MFT_RIGHTJUSTIFY
return_value = SetMenuItemInfo(GetMenu(Me.hwnd), 2, 1, my_menuItemInfo)
End Sub
 楼主| 发表于 2005-1-6 11:50:00 | 显示全部楼层
49.List每行以相应的内容为提示
'----------------------By 陈锐------------------------------
'如果你要在Internet或BBS上转贴文章,请通知我知道(没有通知,不知道犯不犯法,呵呵)
'这个程序演示如何给List Box的每个列表行加上不同的提示行
'运行该程序,当鼠标移动到任一行上后,弹出的ToolTip就会提示该行的完整内容
'Option Explicit
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" _
(ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, _
lParam As Any) As Long
Private Const LB_ITEMFROMPOINT = &H1A9
With List1
.AddItem "aaa"
.AddItem "bbb"
.AddItem "ccc"
End With
End Sub
Private Sub List1_MouseMove(Button As Integer, Shift As Integer, _
' present related tip message
Dim lXPoint As Long
Dim lYPoint As Long
Dim lIndex As Long
If Button = 0 Then ' 如果没有按钮被按下
lXPoint = CLng(X / Screen.TwipsPerPixelX)
lYPoint = CLng(Y / Screen.TwipsPerPixelY)
With List1
' 获得当前的光标所在的的屏幕位置确定标题位置
lIndex = SendMessage(.hwnd, LB_ITEMFROMPOINT, 0, _
ByVal ((lYPoint * 65536) + lXPoint))
' 显示提示行或清除提示行
If (lIndex >= 0) And (lIndex <= .ListCount) Then
.ToolTipText = .List(lIndex)
Else
.ToolTipText = ""
End If
End With
End If
End Sub 50.将部分菜单放置在窗体的最右段(如帮助等)
'.......请自己加上啊
End Type
'API函数声明
End Sub 51. 改变屏幕分辨率
Private Declare Function lstrcpy Lib "kernel32" Alias "lstrcpyA" (lpString1 As Any, lpString2 As Any) As Long
Private Const CCHDEVICENAME = 32
Private Const CCHFORMNAME = 32
Private Const ENUM_CURRENT_SETTINGS = 1
Private Type DEVMODE
.........(请自己添加上)
End Type
Private Declare Function ChangeDisplaySettings Lib "user32" _ Alias "ChangeDisplaySettingsA" (ByVal lpDevMode As Long, ByVal dwflags As Long) As Long
Private Declare Function EnumDisplaySettings Lib "user32" Alias "EnumDisplaySettingsA" _ (ByVal lpszDeviceName As String, ByVal iModeNum As Long, lpDevMode As Any) As Long
Private Declare Function GetSystemMetrics Lib "user32" (ByVal nIndex As Long) As Long
Private Const SM_CXSCREEN = 0
Private Const SM_CYSCREEN = 1
Dim pNewMode As DEVMODE
Dim pOldMode As Long
Dim nOrgWidth As Integer, nOrgHeight As Integer
'设置显示器分辨率的执行函数
Private Function SetDisplayMode(Width As Integer, Height As Integer, Color As Integer) _ As Long ', Freq As Long) As Long
On Error GoTo ErrorHandler
Const DM_PELSWIDTH = &H80000
Const DM_PELSHEIGHT = &H100000
Const DM_BITSPERPEL = &H40000
Const DM_DISPLAYFLAGS = &H200000
Const DM_DISPLAYFREQUENCY = &H400000
With pNewMode
.dmSize = Len(pNewMode)
If Color = 0 Then 'Color = 0 时不更改屏幕颜色
.dmFields = DM_PELSWIDTH Or DM_PELSHEIGHT
Else
.dmFields = DM_BITSPERPEL Or DM_PELSWIDTH Or DM_PELSHEIGHT
End If
.dmPelsWidth = Width
.dmPelsHeight = Height
If Color <> 0 Then
.dmBitsPerPel = Color
End If
End With
pOldMode = lstrcpy(pNewMode, pNewMode)
SetDisplayMode = ChangeDisplaySettings(pOldMode, 1)
Exit Function
ErrorHandler:
MsgBox Err.Description
End Function
Dim nWidth As Integer, nHeight As Integer, nColor As Integer
Select Case Combo1.ListIndex
Case 0
nWidth = 640: nHeight = 480: nColor = 16 '640*480*16位真彩色,256色nColor _
= 8,16色nColor = 4,nColor = 0 表示不改变颜色
Case 1
nWidth = 640: nHeight = 480: nColor = 24
Case 2
nWidth = 640: nHeight = 480: nColor = 32
Case 3
nWidth = 800: nHeight = 600: nColor = 16
Case 4
nWidth = 800: nHeight = 600: nColor = 24
Case 5
nWidth = 800: nHeight = 600: nColor = 32
Case 6
nWidth = 1024: nHeight = 768: nColor = 16
Case 7
nWidth = 1024: nHeight = 768: nColor = 24
Case 8
nWidth = 1024: nHeight = 768: nColor = 32
Case other
End Select
Call SetDisplayMode(nWidth, nHeight, nColor) '注意,系统不支持的显示模式不
'能选,否则准备用安全模式重启动吧.
End Sub
Combo1.AddItem "640*480*16位真彩色"
Combo1.AddItem "640*480*24位真彩色"
Combo1.AddItem "640*480*32位真彩色"
Combo1.AddItem "800*600*16位真彩色"
Combo1.AddItem "800*600*24位真彩色"
Combo1.AddItem "800*600*32位真彩色"
Combo1.AddItem "1024*768*16位真彩色"
Combo1.AddItem "1024*768*24位真彩色"
Combo1.AddItem "1024*768*32位真彩色"
Combo1.Text = Combo1.List(0)
nOrgWidth = GetDisplayWidth
nOrgHeight = GetDisplayHeight
'nOrgWidth = GetSystemMetrics(SM_CXSCREEN)'两种获取初始屏幕大小的方法均可
'nOrgHeight = GetSystemMetrics(SM_CYSCREEN)
End Sub
Private Function GetDisplayWidth() As Integer
GetDisplayWidth = Screen.Width \ Screen.TwipsPerPixelX
End Function
Private Function GetDisplayHeight() As Integer
GetDisplayHeight = Screen.Height \ Screen.TwipsPerPixelY
End Function
Private Sub RestoreDisplayMode()
Call SetDisplayMode(nOrgWidth, nOrgHeight, 0)
End Sub
RestoreDisplayMode
End Sub
52 .各种进制转换
Function Bin2Dec(InputData As String) As Double '二进制转变成十进制
Dim DecOut As Double:Dim I As Integer:Dim LenBin As Double:Dim JOne As String
LenBin = Len(InputData) '确认是否为二进制数
For I = 1 To LenBin
JOne = Mid(InputData, I, 1)
If JOne <> "0" And JOne <> "1" Then
MsgBox "NOT A BINARY NUMBER", vbCritical
Exit Function
End If
Next I
DecOut = 0
For I = Len(InputData) To 1 Step -1
If Mid(InputData, I, 1) = "1" Then
DecOut = DecOut + 2 ^ (Len(InputData) - I)
End If
Next I
Bin2Dec = DecOut
End Function Function Dec2Bin(InputData As Double) As String '十进制转变为二进制
Dim Quot As Double:Dim Remainder As Double:Dim BinOut As String:Dim I As Integer
Dim NewVal As Double:Dim TempString As String:Dim TempVal As Double
Dim BinTemp As String:Dim BinTemp1 As String:Dim PosDot As Integer
Dim Temp2 As String
'检查是否为十进制的小数点
If InStr(1, CStr(InputData), ".") Then
MsgBox "Only Whole Numbers can be converted", vbCritical
GoTo eds
End If
BinOut = ""
NewVal = InputData
DoAgain: '开始计算
NewVal = (NewVal / 2) '如果有余数
If InStr(1, CStr(NewVal), ".") Then
BinOut = BinOut + "1" '得到余数
NewVal = Format(NewVal, "#0")
NewVal = (NewVal - 1)
If NewVal < 1 Then
GoTo DoneIt
End If
Else
BinOut = BinOut + "0"
If NewVal < 1 Then
GoTo DoneIt
End If
End If
GoTo DoAgain
DoneIt:
BinTemp = "" '颠倒结果
For I = Len(BinOut) To 1 Step -1
BinTemp1 = Mid(BinOut, I, 1)
BinTemp = BinTemp + BinTemp1
Next I
BinOut = BinTemp '输出结果
Dec2Bin = BinOut
eds:
End Function Function Bin2Hex(InputData As String) As String '二进制转变成十六进制
Dim I As Integer:Dim LenBin As Integer:Dim JOne As String:Dim NumBlocks As Integer
Dim FullBin As String:Dim HexOut As String:Dim TempBinBlock As String
Dim TempHex As String
LenBin = Len(InputData)'确认是否为二进制数
For I = 1 To LenBin
Exit Function
End If
Next I '设置二进制变量
FullBin = InputData ' 如果这个值的长度小于4,则补0
If LenBin < 4 Then
If LenBin = 3 Then
FullBin = "0" + FullBin
ElseIf LenBin = 2 Then
FullBin = "00" + FullBin
ElseIf LenBin = 1 Then
FullBin = "000" + FullBin
ElseIf LenBin = 0 Then
MsgBox "Nothing Given..", vbCritical
Exit Function
End If
NumBlocks = 1
GoTo DoBlocks
End If
If LenBin = 4 Then
NumBlocks = 1
GoTo DoBlocks
End If
If LenBin > 4 Then
Dim TempHold As Currency
Dim TempDiv As Currency
Dim AfterDot As Integer
Dim Pos As Integer
TempHold = Len(InputData)
TempDiv = (TempHold / 4)
Pos = InStr(1, CStr(TempDiv), ".")
If Pos = 0 Then
NumBlocks = TempDiv
GoTo DoBlocks
End If
AfterDot = Mid(CStr(TempDiv), (Pos + 1))
If AfterDot = 25 Then
NumBlocks = (Len(FullBin) / 4)
ElseIf AfterDot = 5 Then
ElseIf AfterDot = 75 Then
Else
MsgBox "Big Time Screw up happened, WAHHHHHHHHHHH", vbInformation
Exit Function
End If
GoTo DoBlocks
End If
DoBlocks:
HexOut = ""
For I = 1 To Len(FullBin) Step 4
TempBinBlock = Mid(FullBin, I, 4)
If TempBinBlock = "0000" Then
HexOut = HexOut + "0"
ElseIf TempBinBlock = "0001" Then
HexOut = HexOut + "1"
ElseIf TempBinBlock = "0010" Then
HexOut = HexOut + "2"
ElseIf TempBinBlock = "0011" Then
HexOut = HexOut + "3"
ElseIf TempBinBlock = "0100" Then
HexOut = HexOut + "4"
ElseIf TempBinBlock = "0101" Then
HexOut = HexOut + "5"
ElseIf TempBinBlock = "0110" Then
HexOut = HexOut + "6"
ElseIf TempBinBlock = "0111" Then
HexOut = HexOut + "7"
ElseIf TempBinBlock = "1000" Then
HexOut = HexOut + "8"
ElseIf TempBinBlock = "1001" Then
HexOut = HexOut + "9"
ElseIf TempBinBlock = "1010" Then
HexOut = HexOut + "A"
ElseIf TempBinBlock = "1011" Then
HexOut = HexOut + "B"
ElseIf TempBinBlock = "1100" Then
HexOut = HexOut + "C"
ElseIf TempBinBlock = "1101" Then
HexOut = HexOut + "D"
ElseIf TempBinBlock = "1110" Then
HexOut = HexOut + "E"
ElseIf TempBinBlock = "1111" Then
HexOut = HexOut + "F"
End If
Next I
Bin2Hex = HexOut
eds:
End Function Function Hex2Bin(InputData As String) As String
Dim I As Integer:Dim BinOut As String:Dim Lenhex As Integer
InputData = UCase(InputData)
Lenhex = Len(InputData)
For I = 1 To Lenhex
If IsNumeric(Mid(InputData, I, 1)) Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "A" Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "B" Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "C" Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "D" Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "E" Then
GoTo NumOk
ElseIf Mid(InputData, I, 1) = "F" Then
GoTo NumOk
Else
MsgBox "Number given is not in Hex format", vbCritical
Exit Function
End If
NumOk:
Next I
BinOut = ""
For I = 1 To Lenhex
If Mid(InputData, I, 1) = "0" Then
BinOut = BinOut + "0000"
ElseIf Mid(InputData, I, 1) = "1" Then
BinOut = BinOut + "0001"
ElseIf Mid(InputData, I, 1) = "2" Then
BinOut = BinOut + "0010"
ElseIf Mid(InputData, I, 1) = "3" Then
BinOut = BinOut + "0011"
ElseIf Mid(InputData, I, 1) = "4" Then
BinOut = BinOut + "0100"
ElseIf Mid(InputData, I, 1) = "5" Then
BinOut = BinOut + "0101"
ElseIf Mid(InputData, I, 1) = "6" Then
BinOut = BinOut + "0110"
ElseIf Mid(InputData, I, 1) = "7" Then
BinOut = BinOut + "0111"
ElseIf Mid(InputData, I, 1) = "8" Then
BinOut = BinOut + "1000"
ElseIf Mid(InputData, I, 1) = "9" Then
BinOut = BinOut + "1001"
BinOut = BinOut + "1010"
BinOut = BinOut + "1011"
BinOut = BinOut + "1100"
BinOut = BinOut + "1101"
BinOut = BinOut + "1110"
BinOut = BinOut + "1111"
Else
MsgBox "Something is Screwed up, Wahhhhhhhhhhh", vbCritical
End If
Next I
Hex2Bin = BinOut
eds:
End Function
Function Hex2Dec(InputData As String) As Double
Dim I As Integer:Dim DecOut As Double:Dim Lenhex As Integer:Dim HexStep As Double
DecOut = 0
For I = 1 To Lenhex
GoTo NumOk
GoTo NumOk
GoTo NumOk
GoTo NumOk
GoTo NumOk
GoTo NumOk
GoTo NumOk
Else
Exit Function
End If
NumOk:
Next I
HexStep = 0
For I = Lenhex To 1 Step -1
HexStep = HexStep * 16
If HexStep = 0 Then
HexStep = 1
End If
DecOut = DecOut + (0 * HexStep)
DecOut = DecOut + (1 * HexStep)
DecOut = DecOut + (2 * HexStep)
DecOut = DecOut + (3 * HexStep)
DecOut = DecOut + (4 * HexStep)
DecOut = DecOut + (5 * HexStep)
DecOut = DecOut + (6 * HexStep)
DecOut = DecOut + (7 * HexStep)
DecOut = DecOut + (8 * HexStep)
DecOut = DecOut + (9 * HexStep)
DecOut = DecOut + (10 * HexStep)
DecOut = DecOut + (11 * HexStep)
DecOut = DecOut + (12 * HexStep)
DecOut = DecOut + (13 * HexStep)
DecOut = DecOut + (14 * HexStep)
DecOut = DecOut + (15 * HexStep)
Else
End If
Next I
Hex2Dec = DecOut
eds:
End Function
调用方式:
Private Sub cmdbin2hex_Click()
txthex.Text = Bin2Hex(txtbinary.Text)
End Sub
Private Sub cmddec2bin_Click()
If IsNumeric(txtdec2bin.Text) Then
txtdec2bin2.Text = Dec2Bin(txtdec2bin.Text)
End If
End Sub
Private Sub cmdDecHex_Click()
If IsNumeric(txtDecimal.Text) Then
txtdechex.Text = Hex(CDbl(txtDecimal.Text))
Else
MsgBox "Not a Number.", vbCritical
End If
End Sub
Private Sub cmdhex2bin_Click()
txtbinary2.Text = Hex2Bin(txthex2.Text)
End Sub
Private Sub cmdhexdec_Click()
txtdec2.Text = CStr(Hex2Dec(txthexdec.Text))
End Sub
 楼主| 发表于 2005-1-6 11:53:00 | 显示全部楼层
53. 控制左右声道
Private Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal _ lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As _
Long, ByVal hwndCallback As Long) As Long
PlaySound "F:\music\incubus\水木年华-再见了最爱的人.mp3"
End Sub
Function PlaySound(ByVal FileName As String) As Boolean
Dim cmd As String, exName As String
exName = Right(FileName, 3)
mciSendString "close " & exName, 0, 0, 0
cmd = "open " & FileName & " alias " & exName
mciSendString cmd, 0, 0, 0
PlaySound = mciSendString("play " & exName, 0, 0, 0)
End Function
Static flag As Boolean ' 设置左声道开关
mciSendString "set all audio all " & IIf(flag, "on", "off"), 0, 0, 0
If flag = False Then
Command2.Caption = "左声道(关)"
Else
Command2.Caption = "左声道(开)"
End If
flag = Not flag
End Sub
Static flag As Boolean ' 设置右声道开关
Command3.Caption = "右声道(关)"
Else
Command3.Caption = "右声道(开)"
End If
flag = Not flag
End Sub
Private Sub Command4_Click() '' 设置mp3设备音量:0--1000,500表示音量适中
mciSendString "set mp3 audio volume to 500", 0, 0, 0
End Sub
54.利用VB产生屏幕变暗的效果(转,别人的代码)
Private Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type Private Declare Function GetDC Lib "user32" (ByVal hwnd As Long) As Long
Private Declare Function ReleaseDC Lib "user32" (ByVal hwnd As Long, ByVal hdc As Long) As Long
Private Declare Function CreatePatternBrush Lib "gdi32" (ByVal hBitmap As Long) As Long
Private Declare Function PatBlt Lib "gdi32" (ByVal hdc As Long, ByVal x As Long, ByVal y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal dwRop As Long) As Long
Private Declare Function DeleteObject Lib "gdi32" (ByVal hObject As Long) As Long
Private Declare Function CreateBitmap Lib "gdi32" (ByVal nWidth As Long, ByVal nHeight As Long, ByVal nPlanes As Long, ByVal nBitCount As Long, lpBits As Any) As Long
Private Declare Function SelectObject Lib "gdi32" (ByVal hdc As Long, ByVal hObject As Long) As Long
Private Declare Function InvalidateRect Lib "user32" (ByVal hwnd As Long, ByVal lpRect As Long, ByVal bErase As Long) As Long Private bybits(1 To 16) As Byte
Private hBitmap As Long, hBrush As Long
Private hDesktopWnd As Long Private Sub Command1_Click()
Dim rop As Long, res As Long
Dim hdc5 As Long, width5 As Long, height5 As Long hdc5 = GetDC(0)
width5 = Screen.Width \ Screen.TwipsPerPixelX
height5 = Screen.Height \ Screen.TwipsPerPixelY rop = &HA000C9
Call SelectObject(hdc5, hBrush)
res = PatBlt(hdc5, 0, 0, width5, height5, rop)
Call DeleteObject(hBrush) res = ReleaseDC(0, hdc5)
End Sub Private Sub Command2_Click()
Dim aa As Long
aa = InvalidateRect(0, 0, 1)
Dim ary
Dim i As Long
ary = Array(&H55, &H0, &HAA, &H0, _
&H55, &H0, &HAA, &H0)
For i = 1 To 16
bybits(i) = ary(i - 1)
Next i
hBitmap = CreateBitmap(8, 8, 1, 1, bybits(1))
hBrush = CreatePatternBrush(hBitmap)
Picture1.ForeColor = RGB(0, 0, 0)
Picture1.BackColor = RGB(255, 255, 255)
Picture1.ScaleMode = 3
End Sub
55.限定鼠标在某一区域内
Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type
Declare Function ClipCursor Lib "user32" (lpRect As Any) As Long
Declare Function ShowCursor Lib "user32" (ByVal bShow As Long) As Long
Declare Function SetCursorPos Lib "user32" (ByVal x As Long, _
ByVal y As Long) As Long
Declare Function GetWindowRect Lib "user32" _
(ByVal hwnd As Long, lpRect As RECT) As Long
'设定Mouse可移动的围是在某个control项之内
Public Function toLockCursor(ByVal ctlHwnd As Long) As Boolean
Dim rect5 As RECT
Dim res As Long
GetWindowRect ctlHwnd, rect5 '取得window的四个角
SetCursorPos (rect5.Top + rect5.Bottom) \ 2, (rect5.Left + rect5.Right) \ 2
res = ClipCursor(rect5)
If res = 1 Then
toLockCursor = True
Else
toLockCursor = False
End If
End Function
'设定Mouse移动的围为个萤幕
Public Sub toUnLockCursor()
Dim rscreen As RECT
rscreen.Top = 0
rscreen.Left = 0
rscreen.Right = Screen.Width \ Screen.TwipsPerPixelX
rscreen.Bottom = Screen.Height \ Screen.TwipsPerPixelY
ClipCursor rscreen
End Sub Private Sub Command1_Click()
Call toLockCursor(Me.hwnd) '把Me.hwnd改为其他控件的句柄,则鼠标就限制在这个区域里。
End Sub
Call toUnLockCursor
End Sub 56.获得屏幕分辨率
方法一:
Debug.Print Screen.Width / Screen.TwipsPerPixelX
Debug.Print Screen.Height / Screen.TwipsPerPixelY
方法二:
Private Declare Function GetDeviceCaps Lib "gdi32" (ByVal hdc As Long, ByVal nIndex As Long) As Long
Public Sub DeviceInfo(DisplayX As Integer, DisplayY As Integer, DisplayColor As Integer)
Dim hdesktopwnd
Dim hdccaps
Dim lblRes As String
Dim DisplayBits
Dim DisplayPlanes
Dim RetVal
hdccaps = GetDC(hdesktopwnd)
DisplayBits = GetDeviceCaps(hdccaps, 12)
DisplayPlanes = GetDeviceCaps(hdccaps, 14)
DisplayX = GetDeviceCaps(hdccaps, 8)
DisplayY = GetDeviceCaps(hdccaps, 10)
RetVal = ReleaseDC(hdesktopwnd, hdccaps)
Select Case DisplayBits
Case 1
If DisplayPlanes = 1 Then
DisplayColor = 1
Else
If DisplayPlanes = 4 Then DisplayColor = 4 Else DisplayColor = 0
End If
Case 8
DisplayColor = 8
Case 16
DisplayColor = 16
Case 24
DisplayColor = 24
Case 32
DisplayColor = 32
Case Else
DisplayColor = 0 '未知色彩度
End Select
Dim x As Integer, y As Integer, color As Integer
DeviceInfo x, y, color
MsgBox "分辨率为 " & x & "x" & y
End Sub
 楼主| 发表于 2005-1-6 11:54:00 | 显示全部楼层
57.动态添加菜单
Const MF_CHECKED = &H8&
Const MF_APPEND = &H100&
Const TPM_LEFTALIGN = &H0&
Const MF_DISABLED = &H2&
Const MF_GRAYED = &H1&
Const TPM_RETURNCMD = &H100&
Const TPM_RIGHTBUTTON = &H2&
Private Type POINTAPI
x As Long
y As Long
End Type
Private Declare Function CreatePopupMenu Lib "user32" () As Long
Private Declare Function TrackPopupMenuEx Lib "user32" (ByVal hMenu As Long, ByVal wFlags As Long, ByVal x As Long, ByVal y As Long, ByVal HWnd As Long, ByVal lptpm As Any) As Long
Private Declare Function AppendMenu Lib "user32" Alias "AppendMenuA" (ByVal hMenu As Long, ByVal wFlags As Long, ByVal wIDNewItem As Long, ByVal lpNewItem As Any) As Long
Private Declare Function DestroyMenu Lib "user32" (ByVal hMenu As Long) As Long
Private Declare Function GetCursorPos Lib "user32" (lpPoint As POINTAPI) As Long
Dim hMenu As Long
Private Sub Form_MouseUp(Button As Integer, Shift As Integer, x As Single, y As Single)
If Button = 2 Then
Dim Pt As POINTAPI
Dim ret As Long
hMenu = CreatePopupMenu()
AppendMenu hMenu, MF_STRING, 1, "Hello !"
AppendMenu hMenu, MF_GRAYED Or MF_DISABLED, 2, "Testing ..."
AppendMenu hMenu, MF_SEPARATOR, 3, ByVal 0&
AppendMenu hMenu, MF_CHECKED, 4, "TrackPopupMenu"
GetCursorPos Pt
ret = TrackPopupMenuEx(hMenu, TPM_LEFTALIGN Or TPM_RETURNCMD Or TPM_RIGHTBUTTON, Pt.x, Pt.y, Me.HWnd, ByVal 0&)
DestroyMenu hMenu
Select Case ret
Case 1
MsgBox "Hello !"
Case 4
MsgBox "TrackPopupMenu"
End Select
End If
End Sub
58.利用API函数实现定时器功能
模块中:
Option Explicit
Public lTimerId As Long
Private Declare Function SetTimer Lib "user32" (ByVal hWnd As Long, ByVal nIDEvent As Long, ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
Private Declare Function KillTimer Lib "user32" (ByVal hWnd As Long, ByVal nIDEvent As Long) As Long
Private Sub TimerProc(ByVal lHwnd As Long, ByVal lMsg As Long, ByVal lTimerId As Long, ByVal lTime As Long)
Static i As Long
Form1.Label1.Caption = i
i = i + 1
End Sub
Public Sub StartTimer(lMinute As Long)
lTimerId = SetTimer(0, 0, lMinute, AddressOf TimerProc)
End Sub
Public Function StopTimer(lTimerId As Long) As Long
StopTimer = KillTimer(0, lTimerId)
End Function 窗体中:
StartTimer 1000
StopTimer lTimerId
End Sub
59.创建GUID 'GUID是Globally Unique IDentifier的缩写.由一个特殊的算法来产生这些128位的数,并保证不产生重复的GUID—重复的可能性当然存在,但有太多可用的数了,因此算法特别防止产生重复的数,这种情况你一生都不会看到. ActiveX控件都有一个用于相互区别的GUID.你如何在自己的程序中使用GUID呢? 例如,当一个数据库的每个条目都需要由一个唯一的键值时.下面的代码将给你一个答案: Option Explicit
Private Type GUID
Data1 As Long
Data2 As Long
Data3 As Long
Data4(8) As Byte
End Type
Private Declare Function CoCreateGuid Lib "ole32.dll" (pguid As GUID) As Long
Private Declare Function StringFromGUID2 Lib "ole32.dll" (rguid As Any, ByVal lpstrClsId As Long, ByVal cbMax As Long) As Long
Private Function GUIDGen() As String
Dim uGUID As GUID
Dim sGUID As String
Dim bGUID() As Byte
Dim lLen As Long
Dim RetVal As Long
lLen = 40
bGUID = String(lLen, 0)
CoCreateGuid uGUID '把结构转换为一个可显示的字符串
RetVal = StringFromGUID2(uGUID, VarPtr(bGUID(0)), lLen)
sGUID = bGUID
If (Asc(Mid$(sGUID, RetVal, 1)) = 0) Then RetVal = RetVal - 1
GUIDGen = Left$(sGUID, RetVal)
End Function
Private Sub cmdGUID_Click()
txtGUID.Text = GUIDGen
End Sub 60.创建渐变窗体
Private Declare Function CreateSolidBrush Lib "gdi32" (ByVal crColor As Long) As Long
Private Declare Function FillRgn Lib "gdi32" (ByVal hdc As Long, ByVal hRgn As Long, ByVal hBrush As Long) As Long
Private Declare Function FillRect Lib "user32" (ByVal hdc As Long, lpRect As RECT, ByVal hBrush As Long) As Long
Private Type RECT
left As Long
top As Long
right As Long
bottom As Long
End Type
Private Sub Form_Paint()
Dim Color As Long
Dim hBrush As Long
Dim OldMode As Long
Dim RetVal As Long
Dim StepSize As Long
Dim X As Long
Dim FillArea As RECT
OldMode = Me.ScaleMode
Me.ScaleMode = 3
StepSize = 1 + Me.ScaleHeight / 80
Color = 255
FillArea.left = 0
FillArea.right = Me.ScaleWidth
FillArea.top = 0
FillArea.bottom = StepSize
For X = 1 To 80
hBrush = CreateSolidBrush(RGB(Color / 2, Color * 2, Color))
RetVal = FillRect(Me.hdc, FillArea, hBrush)
RetVal = DeleteObject(hBrush)
Color = Color - 2
If Color < 0 Then Color = 0
FillArea.top = FillArea.bottom
FillArea.bottom = FillArea.bottom + StepSize
Next
Me.ScaleMode = OldMode
End Sub
 楼主| 发表于 2005-1-6 11:56:00 | 显示全部楼层
61.禁止屏幕保护
Private Declare Function SystemParametersInfo Lib "user32" Alias "SystemParametersInfoA" (ByVal uAction As Long, ByVal uParam As Long, ByVal lpvParam As Long, ByVal fuWinIni As Long) As Long
Const SPI_SETSCREENSAVEACTIVE = 17
Const SPIF_SENDWININICHANGE = &H2
Const SPIF_UPDATEINIFILE = &H1 Private Sub Form_Load()
SystemParametersInfo SPI_SETSCREENSAVEACTIVE, 0, 0, SPIF_UPDATEINIFILE Or SPIF_SENDWININICHANGE
End Sub 62.类似QQ界面的按钮。
command以picturebox为容器。
Me.WindowState = 2
With Picture1
.Width = 1200 + 60
.Height = 4860
End With
Dim i As Integer
For i = Command1.Count - 1 To 0 Step -1
With Command1(i)
.Width = 1200
.Height = 300
.Top = Picture1.ScaleHeight - 300 * (Command1.Count - i)
.Left = 0
.Caption = "分组 " & i + 1
End With
Next i
Command1(0).Top = 0
End Sub Private Sub Command1_Click(Index As Integer)
Picture1.SetFocus
'把焦点给Picture1是为了不让按钮出现难看的黑框
Dim i As Integer
For i = 1 To Index
Command1(i).Top = 300 * i
Next i
For i = Command1.Count - 1 To Index + 1 Step -1
Command1(i).Top = Picture1.ScaleHeight - 300 * (Command1.Count - i)
Next i
End Sub 63.alpha blend
Private Declare Function AlphaBlend Lib "msimg32" ( ByVal hDestDC As Long, _
ByVal x As Long, ByVal y As Long, ByVal nWidth As Long, ByVal nHeight As Long, _
ByVal hSrcDC As Long, ByVal xSrc As Long, ByVal ySrc As Long, ByVal widthSrc As Long, _
ByVal heightSrc As Long, ByVal dreamAKA As Long) As Long 'only Windows 98 or Latter
Dim Num As Byte, nN%, nBlend&
Private Sub Run_Blending()
Num = 255
nN = 5
Do
DoEvents
nBlend = vbBlue - CLng(Num) * (vbYellow + 1)
Num = Num - nN
If Num = 0 Then
nN = -5
ElseIf Num = 255 Then
nN = 5
End If
Me.Cls
AlphaBlend Me.hDC, 0, 0, picSrc.ScaleWidth, picSrc.ScaleHeight, picSrc.hDC, 0, 0, picSrc.ScaleWidth, picSrc.ScaleHeight, nBlend
Loop
End Sub
Private Sub Form_Activate()
Call Run_Blending
End Sub
End ' STOP Do Loop
End Sub 64.简单贝赛尔曲线绘制
Option Explicit
x As Long
y As Long
End Type Private Declare Function PolyBezier Lib "gdi32" _
(ByVal hdc As Long, _
lppt As POINTAPI, _
ByVal cpoints As Long) As Long Dim Points(0 To 3) As POINTAPI
Dim oldPoint As POINTAPI
Dim Index As Integer
Private Sub form_load()
Caption = "绘制贝塞尔曲线"
ScaleMode = 3
End Sub Private Sub form_mousedown(button As Integer, _
shift As Integer, x As Single, y As Single)
Points(Index).x = x: Points(Index).y = y
If Index = 0 Then
Cls
Else
Line (oldPoint.x, oldPoint.y)-(x, y) '绘制特征多边形
End If
oldPoint.x = x: oldPoint.y = y
Circle (x, y), 3, vbBlue
If Index = 3 Then
Form1.ForeColor = vbRed
PolyBezier Me.hdc, Points(0), 4 '绘制贝赛尔曲线
Index = 0
Else
Index = Index + 1
End If
End Sub
 楼主| 发表于 2005-1-6 11:59:00 | 显示全部楼层
65.读写INI文件模块 Option Explicit
'读写INI文件模块
Public Declare Function GetPrivateProfileString Lib "kernel32" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As Any, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long, ByVal lpFileName As String) As Long
Public Declare Function WritePrivateProfileString Lib "kernel32" Alias "WritePrivateProfileStringA" (ByVal AppName As String, ByVal KeyName As String, ByVal keydefault As String, ByVal Filename As String) As Long Public Function myReadINI(iniFileName, iniSection, iniKey, iniDefault)
'该函数的使用与读注册表类似
'inifilename为INI文件名,inisection为INI文件中的项目,inikey为项目下的键名称,inidefault为默认键值
'If no section (appname), default is first appname
'(若无项目名,默认为初始名称)
'if no key, default is first key
'(若无键名,默认为初始键名)
Dim lpApplicationName As String
Dim lpKeyName As String
Dim lpDefault As String
Dim lpReturnedString As String
Dim nSize As Long
Dim lpFileName As String
Dim retval As Long
Dim Filename As String
'判断INI文件是否存在
If Dir(iniFileName) <> "" Then
lpDefault = Space$(254)
lpDefault = iniDefault
lpReturnedString = Space$(254)
nSize = 254
lpFileName = iniFileName
lpApplicationName = iniSection
lpKeyName = iniKey
Filename = lpFileName
retval = GetPrivateProfileString(lpApplicationName, lpKeyName, lpDefault, lpReturnedString, nSize, lpFileName)
myReadINI = lpReturnedString
End If
End Function Public Function myWriteINI(iniFileName As String, iniSection As String, iniKey As String, Info As String) As String
'该函数的使用与写注册表类似,可在INI文件中添加或修改项、键、值
'iniFileName为INI文件名,inisection为INI文件中的项目,inikey为项目下的键名称,Info为键值
Dim retval As Long
retval = WritePrivateProfileString(iniSection, iniKey, Info, iniFileName)
myWriteINI = LTrim$(Str$(retval))
End Function Public Sub DelSectionINI(iniFileName As String, iniSection As String)
'该过程可删除INI文件中指定的项
'iniFileName为INI文件名,iniSection为指定的项
'判断INI文件是否存在
WritePrivateProfileString iniSection, vbNullString, vbNullString, iniFileName
End If
End Sub Public Sub DelKeyINI(iniFileName As String, iniSection As String, iniKey As String)
'该过程可删除INI文件中指定的键
'iniFileName为INI文件名,iniSection为指定的项,iniKey为指定的键
'判断INI文件是否存在
WritePrivateProfileString iniSection, iniKey, vbNullString, iniFileName
End If
End Sub Public Sub DelValueINI(iniFileName As String, iniSection As String, iniKey As String)
'该过程可删除INI文件中指定键的值
'判断INI文件是否存在
WritePrivateProfileString iniSection, iniKey, "", iniFileName
End If
End Sub Public Sub DelFileINI(iniFileName As String)
'该过程可删除INI文件
'iniFileName为INI文件名
'判断INI文件是否存在
Kill iniFileName
End If
End Sub
66.显示浏览文件夹对话框 Option Explicit
'显示浏览文件夹对话框
' 调用方式:: string = BrowseForFolders(Hwnd,TitleOfDialog)
' 例如:String1 = BrowseForFolders(Hwnd, "Select target folder...")
Public Type BrowseInfo
hwndOwner As Long
pIDLRoot As Long
pszDisplayName As Long
lpszTitle As Long
ulFlags As Long
lpfnCallback As Long
lParam As Long
iImage As Long
End Type
Public Const BIF_RETURNONLYFSDIRS = 1
Public Const MAX_PATH = 260
Public Declare Sub CoTaskMemFree Lib "ole32.dll" (ByVal hMem As Long)
Public Declare Function lstrcat Lib "kernel32" Alias "lstrcatA" (ByVal lpString1 As String, ByVal lpString2 As String) As Long
Public Declare Function SHBrowseForFolder Lib "shell32" (lpbi As BrowseInfo) As Long
Public Declare Function SHGetPathFromIDList Lib "shell32" (ByVal pidList As Long, ByVal lpBuffer As String) As Long Public Function BrowseForFolder(hwndOwner As Long, sPrompt As String) As String
Dim iNull As Integer
Dim lpIDList As Long
Dim lResult As Long
Dim sPath As String
Dim udtBI As BrowseInfo
'初始化变量
With udtBI
.hwndOwner = hwndOwner
.lpszTitle = lstrcat(sPrompt, "")
.ulFlags = BIF_RETURNONLYFSDIRS
End With
'调用 API
lpIDList = SHBrowseForFolder(udtBI)
If lpIDList Then
sPath = String$(MAX_PATH, 0)
lResult = SHGetPathFromIDList(lpIDList, sPath)
Call CoTaskMemFree(lpIDList)
iNull = InStr(sPath, vbNullChar)
If iNull Then sPath = Left$(sPath, iNull - 1)
End If
'如果选择取消, sPath = ""
BrowseForFolder = sPath
End Function
67.注册表读写模块 Option Explicit
'注册表读写模块
'This program needs 3 buttons
Public Const REG_DWORD = 4
Const ERROR_SUCCESS = 0&
Const KEY_ALL_ACCESS = &H3F
Public Const REG_SZ = 1 ' Unicode nul terminated string
Public Const REG_BINARY = 3 ' Free form binary
Public Const HKEY_CURRENT_USER = &H80000001
Public Const HKEY_LOCAL_MACHINE = &H80000002
Public Const REG1_KEY = "software\microsoft\windows\currentversion\run"
Public Const REG2_KEY = "software\microsoft\windows\currentversion\RunServices" Public Declare Function RegCloseKey Lib "advapi32.dll" (ByVal hKey As Long) As Long
Public Declare Function RegCreateKey Lib "advapi32.dll" Alias "RegCreateKeyA" (ByVal hKey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Public Declare Function RegDeleteValue Lib "advapi32.dll" Alias "RegDeleteValueA" (ByVal hKey As Long, ByVal lpValueName As String) As Long
Public Declare Function RegOpenKey Lib "advapi32.dll" Alias "RegOpenKeyA" (ByVal hKey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Public Declare Function RegQueryValueEx Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, lpData As Any, lpcbData As Long) As Long
Public Declare Function RegSetValueEx Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, lpData As Any, ByVal cbData As Long) As Long
Public Function RegQueryStringValue(ByVal hKey As Long, ByVal strValueName As String) As String
Dim lResult As Long, lValueType As Long, strBuf As String, lDataBufSize As Long
'retrieve nformation about the key
lResult = RegQueryValueEx(hKey, strValueName, 0, lValueType, ByVal 0, lDataBufSize)
If lResult = 0 Then
If lValueType = REG_SZ Then
'Create a buffer
strBuf = String(lDataBufSize, Chr$(0))
'retrieve the key's content
lResult = RegQueryValueEx(hKey, strValueName, 0, 0, ByVal strBuf, lDataBufSize)
If lResult = 0 Then
'Remove the unnecessary chr$(0)'s
RegQueryStringValue = Left$(strBuf, InStr(1, strBuf, Chr$(0)) - 1)
End If
ElseIf lValueType = REG_BINARY Then
Dim strData As Integer
'retrieve the key's value
lResult = RegQueryValueEx(hKey, strValueName, 0, 0, strData, lDataBufSize)
If lResult = 0 Then
RegQueryStringValue = strData
End If
End If
End If
End Function
Public Function GetString(hKey As Long, strPath As String, strValue As String)
Dim Ret
'Open the key
RegOpenKey hKey, strPath, Ret
'Get the key's content
GetString = RegQueryStringValue(Ret, strValue)
'Close the key
RegCloseKey Ret
End Function
Public Sub SaveString(hKey As Long, strPath As String, strValue As String, strData As String)
Dim Ret
'Create a new key
RegCreateKey hKey, strPath, Ret
'Save a string to the key
RegSetValueEx Ret, strValue, 0, REG_SZ, ByVal strData, Len(strData)
'close the key
RegCloseKey Ret
End Sub
Public Sub SaveStringLong(hKey As Long, strPath As String, strValue As String, strData As String)
Dim Ret
'Create a new key
'Set the key's value
RegSetValueEx Ret, strValue, 0, REG_BINARY, CByte(strData), 4
'close the key
RegCloseKey Ret
End Sub
Public Sub DelSetting(hKey As Long, strPath As String, strValue As String)
Dim Ret
'Create a new key
'Delete the key's value
RegDeleteValue Ret, strValue
'close the key
RegCloseKey Ret
End Sub
Public Sub SaveRegDWORD(hKey As Long, strPath As String, strValueName As String, strData As String)
Dim Ret
'Create a new key
'Save a DWORD to the key
RegSetValueEx Ret, strValueName, 0, REG_DWORD, CByte(strData), 4
'close the key
RegCloseKey Ret End Sub
68.API打造浮动按钮 Option Base 1
Public Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination As Any, Source As Any, ByVal Length As Long)
Public Declare Function CreateWindowEx Lib "user32" Alias "CreateWindowExA" (ByVal dwExStyle As Long, ByVal lpClassName As String, ByVal lpWindowName As String, ByVal dwStyle As Long, ByVal X As Long, ByVal Y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal hWndParent As Long, ByVal hMenu As Long, ByVal hInstance As Long, lpParam As Any) As Long
Public Declare Function TrackMouseEvent Lib "user32" (lpEventTrack As TRACKMOUSEEVENTTYPE) As Long
'--------------------------------------------------------------------------------------------GDI相关函数
Public Declare Function DeleteDC Lib "gdi32" (ByVal hdc As Long) As Long
Public Declare Function LoadImage Lib "user32" Alias "LoadImageA" (ByVal hInst As Long, ByVal lpsz As String, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As Long
Public Declare Function DeleteObject Lib "gdi32" (ByVal hObject As Long) As Long
Public Declare Function SelectObject Lib "gdi32" (ByVal hdc As Long, ByVal hObject As Long) As Long
Public Declare Function BitBlt Lib "gdi32" (ByVal hDestDC As Long, ByVal X As Long, ByVal Y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal hSrcDC As Long, ByVal xSrc As Long, ByVal ySrc As Long, ByVal dwRop As Long) As Long
Public Declare Function CreateCompatibleDC Lib "gdi32" (ByVal hdc As Long) As Long
Public Declare Function CreateCompatibleBitmap Lib "gdi32" (ByVal hdc As Long, ByVal nWidth As Long, ByVal nHeight As Long) As Long
Public Declare Function GetDC Lib "user32" (ByVal hwnd As Long) As Long
Public Const TME_LEAVE = &H2&
Public Const ODS_SELECTED = &H1
Public Const ODT_BUTTON = 4
Public Const WM_DRAWITEM = &H2B
Public Const WM_MEASUREITEM = &H2C
Public Const IMAGE_BITMAP = 0
Public Const LR_LOADFROMFILE = &H10
Public Const BS_OWNERDRAW = &HB&
Public Const WM_MOUSEMOVE = &H200
Public Const WM_MOUSELEAVE = &H2A3
Public Const WS_CHILD = &H40000000
Public Const WS_VISIBLE = &H10000000
Public Const SRCCOPY = &HCC0020 ' (DWORD) dest = source
'-------------------------以下是自定义按钮状态常数
Public Const Leave = 1 '离开按钮范围
Public Const Click = 2 ' 按下按钮
Public Const Undo = 3 '松开按钮
Public Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type
Public Type DRAWITEMSTRUCT '自绘控件的绘图结构,另外由于它在WIN32里面是唯一的结构,所以在VB里面要用到CopyMemory这个API函数直接指向它的地址
CtlType As Long
CtlID As Long
ItemID As Long
itemAction As Long
itemState As Long
hwndItem As Long
hdc As Long
rcItem As RECT
itemData As Long
End Type
Public Type MEASUREITEMSTRUCT '自绘时候设置控件的大小'同上
CtlType As Long
CtlID As Long
ItemID As Long
itemWidth As Long
itemHeight As Long
itemData As Long
End Type
Public Type TRACKMOUSEEVENTTYPE
cbSize As Long
dwFlags As Long
hwndTrack As Long
dwHoverTime As Long
End Type
Public ImageHandle(3) As Long
Public OldMainProc As Long
Public OldButtonProc As Long
Public CmdHwnd As Long
Public MouseLeave As Boolean
Public Sub Initialize() '初始化
LoadPic
MouseLeave = True
MainProc
CreateOwnerDrawButton
ButtonProc
End Sub
Public Sub MainProc() '窗口自类化(NewMainProc)
OldMainProc = SetWindowLong(Form1.hwnd, GWL_WNDPROC, AddressOf NewMainProc)
End Sub
Public Sub ButtonProc() '按钮自类化(NewButtonProc)
OldButtonProc = SetWindowLong(CmdHwnd, GWL_WNDPROC, AddressOf NewButtonProc)
End Sub
Public Sub CreateOwnerDrawButton() '创造一个自绘按钮
CmdHwnd = CreateWindowEx(0, "Button", "", WS_CHILD Or BS_OWNERDRAW Or WS_VISIBLE, 50, 60, 70, 25, Form1.hwnd, 0, App.hInstance, 0)
Dim dc As Long
dc = GetDC(CmdHwnd)
drawPic Leave End Sub
Public Function NewMainProc(ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long '处理主窗口消息
Select Case Msg
Case WM_DRAWITEM
OnDrawItem lParam
Exit Function
Case WM_MEASUREITEM
OnMeasureItem lParam
End Select
NewMainProc = CallWindowProc(OldMainProc, hwnd, Msg, wParam, lParam)
End Function
Public Function NewButtonProc(ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long '处理按钮消息
Select Case Msg
Case WM_MOUSELEAVE
Button_MouseLeave
MouseLeave = True
Case WM_MOUSEMOVE
Button_MouseMove
Case WM_LBUTTONUP
Button_MouseLButtonUp
End Select
NewButtonProc = CallWindowProc(OldButtonProc, hwnd, Msg, wParam, lParam)
End Function
Public Sub Button_MouseMove() '鼠标移动事件
drawPic Undo
If MouseLeave = True Then
MouseLeave = False
Dim MouseTrack As TRACKMOUSEEVENTTYPE
With MouseTrack
.cbSize = Len(MouseTrack)
.dwFlags = TME_LEAVE
.hwndTrack = CmdHwnd
End With
TrackMouseEvent MouseTrack
End If
End Sub
Public Sub Button_MouseLButtonUp() '左键按下事件
Debug.Print "已按下左键"
End Sub
Public Sub Button_MouseLeave() '离开事件
drawPic Leave
Debug.Print "已离开按钮的范围"
End Sub
Public Sub OnMeasureItem(lParam As Long) '设置的大小
Dim lpMIS As MEASUREITEMSTRUCT
CopyMemory lpMIS, ByVal lParam, Len(lpMIS)
lpMIS.itemHeight = 25
lpMIS.itemWidth = 70
CopyMemory ByVal lParam, lpMIS, Len(lpMIS)
End Sub
Public Sub OnDrawItem(lParam As Long) '为按钮绘制样貌
Dim lpDIS As DRAWITEMSTRUCT
CopyMemory lpDIS, ByVal lParam, Len(lpDIS)
Dim mem As Long
Dim Object As Long
mem = CreateCompatibleDC(hdc)
If lpDIS.CtlType = ODT_BUTTON Then
If lpDIS.itemState And ODS_SELECTED Then '按下时外貌
drawPic Click
Else '松开时外貌
drawPic Leave
Else
drawPic Undo
End If
End If
End If
CopyMemory ByVal lParam, lpDIS, Len(lpDIS)
End Sub
Public Sub LoadPic() '读取图片
ImageHandle(1) = LoadImage(App.hInstance, App.Path & "\" & "1.bmp", IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE)
ImageHandle(2) = LoadImage(App.hInstance, App.Path & "\" & "2.bmp", IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE)
ImageHandle(3) = LoadImage(App.hInstance, App.Path & "\" & "3.bmp", IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE)
End Sub
Public Sub drawPic(State As Long) '为按钮绘制不同状态的图案
Dim hdc As Long
Dim mem As Long
Dim Object As Long
hdc = GetDC(CmdHwnd)
Object = SelectObject(mem, ImageHandle(State))
BitBlt hdc, 0, 0, 70, 25, mem, 0, 0, SRCCOPY
DeleteObject Object
DeleteDC mem
End Sub
 楼主| 发表于 2005-1-6 12:04:00 | 显示全部楼层
终于上传完了,希望对大家会有所帮助。
发表于 2005-1-6 22:06:00 | 显示全部楼层
如此好贴,真是不顶不行!
发表于 2005-1-8 08:21:00 | 显示全部楼层
好贴,顶
GMT+8, 2026-1-13 22:51 , Processed in 0.259757 second(s), 17 queries , Gzip On.
