楼主: mayuezxl
如何用CommonDialog对话框选取多个文件
发表于 2005-8-21 22:20:00 | 显示全部楼层
  1. Public Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" _
  2.     (pOpenfilename As OPENFILENAME) As Long
  3. Public Const OFN_PATHMUSTEXIST = &H800
  4. Public Const OFN_FILEMUSTEXIST = &H1000
  5. Public Const OFN_HIDEREADONLY = &H4 '隐蔽只读复选框
  6. Public Const OFN_ALLOWMULTISELECT = &H200
  7. Private Const OFN_EXPLORER As Long = &H80000
  8. Public Type OPENFILENAME
  9.     lStructSize As Long
  10.     hwndOwner As Long '拥有对话框的窗口
  11.     hInstance As Long
  12.     lpstrFilter As String '装载文件过滤器的缓冲区
  13.     lpstrCustomFilter As String
  14.     nMaxCustFilter As Long
  15.     nFilterIndex As Long
  16.     lpstrFile As String
  17.     nMaxFile As Long
  18.     lpstrFileTitle As String
  19.     nMaxFileTitle As Long
  20.     lpstrInitialDir As String
  21.     lpstrTitle As String '对话框的标题
  22.     flags As Long
  23.     nFileOffset As Integer
  24.     nFileExtension As Integer
  25.     lpstrDefExt As String
  26.     lCustData As Long
  27.     lpfnHook As Long
  28.     lpTemplateName As String
  29. End Type
  30. '选择文件函数GetFile
  31. Function GetFile(strTitle As String, strFilter As String, Optional MultiSelect As Boolean = False, Optional strIniDir As String) As String
  32. On Error Resume Next
  33. Dim FileName As String
  34. Dim OFileBox As OPENFILENAME
  35. With OFileBox
  36.     .lpstrTitle = strTitle '对话框标题
  37.     .lpstrInitialDir = strIniDir '初始目录
  38.     .lStructSize = Len(OFileBox)
  39.     .hwndOwner = ThisDrawing.HWND
  40.     If MultiSelect Then
  41.         .flags = OFN_EXPLORER Or OFN_FILEMUSTEXIST Or OFN_HIDEREADONLY Or OFN_ALLOWMULTISELECT
  42.     Else
  43.         .flags = OFN_EXPLORER Or OFN_FILEMUSTEXIST Or OFN_HIDEREADONLY
  44.     End If
  45.     .lpstrFile = String$(255, 0)
  46.     .nMaxFile = 255
  47.     .lpstrFileTitle = String$(255, 0)
  48.     .nMaxFileTitle = 255
  49.     .lpstrFilter = strFilter  '过滤器
  50.     .nFilterIndex = 1
  51. End With
  52. lntFile = GetOpenFileName(OFileBox) '执行打开对话框
  53. If lntFile <> 0 Then
  54.         FileName = Left(OFileBox.lpstrFile, InStr(OFileBox.nFileOffset + 1, OFileBox.lpstrFile, _
  55.                         Chr(0) & Chr(0), vbBinaryCompare))
  56.     GetFile = FileName
  57. Else
  58.     GetFile = ""
  59. End If
  60. End Function
  61. '示例
  62. Sub gf()
  63.     Dim f As String
  64.     f = GetFile("明经通道 http://www.mjtd.com VBA 示例", "图形文件(*.dwg)" & vbNullChar & "*.dwg", True)
  65.     Debug.Print f
  66. End Sub
GMT+8, 2026-1-15 22:25 , Processed in 0.155118 second(s), 17 queries , Gzip On.
