楼主: liu22737
求助:尺寸标注
 楼主| 发表于 2005-11-7 13:47:00 | 显示全部楼层
多谢楼上几位高手
另外 请求各位斑竹能否把以前的帖子整理分类一下,方便大家查找啊,
里面确实有好多精华帖子,但用的时候不容易找到。
 楼主| 发表于 2005-11-7 21:46:00 | 显示全部楼层
;;程序中尺寸参数dimtad的值 参考龙龙仔的程序求得
(defun c:dim_cen_above(/ d_dim StyleName TempList dim_tad)
(setq d_dim (car(entsel)))
(setq StyleName (cdr(assoc 3 (entget d_dim))))
(if (setq TempList (cddadr (assoc -3 (entget d_dim '("ACAD")))))
    (if (setq pos_s (vl-position (cons 1070 77) templist))
        (setq dim_tad (cdr(nth (+ pos_s 1) templist)))
        (setq dim_tad (cdr(assoc 77 (tblsearch "DIMSTYLE" StyleName)))))
(if (= dim_tad 0)
(command "dimoverride" "dimtad" 1 "" d_dim "")
(command "dimoverride" "dimtad" 0 "" d_dim "")
GMT+8, 2025-12-18 03:06 , Processed in 0.250343 second(s), 19 queries , Gzip On.
