楼主: linkai2004
[求助]过年了,有一堆数字要统计,大家能帮我夏吗?
发表于 2006-1-24 13:37:00 | 显示全部楼层
linkai2004发表于2006-1-24 9:12:00版主呀 这个怎么用呀 最后得到一个!ss的结果.要怎么用?
  1. (defun c:test ()
  2.   (CMDLA0)
  3.   (setq STR (USTR 1 "\n数字字符串(格式 : a,b,c,...)" STR NIL)
  4. ss  (ssget  (list '(0 . "TEXT") (cons 1 str)))
  5.   )
  6.   (princ"\n选择集为 !ss")
  7.   (CMDLA1)
  8. )
选择集的名称:!ss
主题只要生成选择集,剩下的操作就是你自己的事情了!呵呵……
 楼主| 发表于 2006-1-24 22:21:00 | 显示全部楼层
Andyhon发表于2006-1-24 12:11:00 (defun sslist (sso / n lst)(if (= (type sso) 'PICKSET) ...
好像提示 错误: 输入的列表有缺陷
能不能再帮我改进一下子  谢谢
我要得基本上就是这样的
 楼主| 发表于 2006-1-24 22:31:00 | 显示全部楼层
(setq ss (ssget '((0 . "TEXT"))))
好像是丢了一个括号其他的好像也有点不对,请作者再帮一下忙啦
发表于 2006-1-24 22:35:00 | 显示全部楼层
  http://www.faqs.org/faqs/CAD/autolisp-faq/part2/section-1.html
  ;;; convert selection set to list,
  ;;; Note: it's also wise to use ai_ssget, because some ents could be
  ;;;       on locked layers
  ;;; Ex: (sslist (ai_ssget (ssget))) => list of selected unlocked ents
  ;;; or  (mapcar 'entupd (sslist (ssget "X" '((8 . "TEMP")))))
  ;;;       - regens all entities on layer TEMP
  (defun SSLIST (ss / n lst)
    (if (= (type ss) 'PICKSET)
      (repeat (setq n (sslength ss))
        (setq n (1- n)
              lst (cons (ssname ss n) lst)))))
  http://www.d2cad.nl/lisp/lisps/sslist.html
  (defun SSList (f_sel) ;converts a selection set to a list of enames
  (if f_sel
  (if (/= (type f_sel) 'PICKSET)
    (exit)
  ) ; end if
  (setq f_ss_list nil
 f_loop -1
  ) ; end setq
  (repeat (sslength f_sel)
      (setq f_loop (1+ f_loop))
;      (princ (strcat "\rSorting " (itoa f_loop) " of " (itoa (sslength f_sel)) "     "))
      (setq f_ss_list (append f_ss_list (list (ssname f_sel f_loop))))
    ) ; end progn
  ) ; end repest
  ) ; end progn
    nil
    ) ; end if
) ; end defun
http://forum.paug.org/messages/24/973.html?WednesdayMay1920040929am
;--- sslist -----------------------------------------------
; convert selection-set into a list of entities
; result is the list
; Example: (sslist )
(defun sslist (SS / N P)
(repeat (setq N (sslength SS)) ;seed N
(setq N (1- N) ;index number
P (cons (ssname SS N) P)) ;setq
);repeat
); sslist
 楼主| 发表于 2006-1-24 22:46:00 | 显示全部楼层
Andyhon 师兄能不能帮我整理一下啦
我看不懂呀..
你开始变编的那个就是我想要得,
能不能完善一下,好像一加载就运行了?怎么回事
发表于 2006-1-25 08:23:00 | 显示全部楼层
    (defun dxg (code ele)
      (cdr (assoc code (entget ele)))
         ) ;setq
       );repeat
 ;;; for test only
 ;;; (setq MyStrSet (scopeStr))
 ;;; 返回类如 (<Entity name: 1d232d0> <Entity name: 1d232d8> . . .)
 (defun scopeStr ()
    (setq Lint (getInt "下限值起自: ")
            Uint (getInt "上限结束值: ")
    (princ "\n 框选范围内的数字,生成一个选择集: ")
    (vl-remove-if
     '(lambda (x)
       (setq y (atoi (dxg 1 x)))
       (cond
        ;((< y Lint) x)
        ;((> y Uint) x)
        ((< y Lint))
        ((> y Uint))
      (sslist ss)
 楼主| 发表于 2006-1-25 13:13:00 | 显示全部楼层
Andyhon发表于2006-1-25 8:23:00(defun sslist (sso / n lst)(if (= (type sso) 'PICKSET)&n...
好像还是不能用?
 楼主| 发表于 2006-1-25 13:16:00 | 显示全部楼层
请求大家的帮助亚
发表于 2006-1-25 14:57:00 | 显示全部楼层
那就用阳春型的 SSLIST 好了
这样比较单纯
GMT+8, 2025-12-18 01:13 , Processed in 0.173506 second(s), 19 queries , Gzip On.
