楼主: dolphin27
[求助]请教在LISP几个标注样式中的参数
发表于 2007-6-24 23:05:00 | 显示全部楼层
各位告诉我怎么创建标注精度只有一位小数的标住样式,程序怎么写?谢谢了
发表于 2007-6-25 17:12:00 | 显示全部楼层
我自己在用的
(defun S::STARTUP ()
  (setvar "cmdecho" 0)
  (setvar "CELTSCALE" 3)
  (if (not (tblsearch "LAYER" "CENTER"))
    (command "_.layer" "n" "CENTER" "_color" "1" "CENTER" "_ltype" "CENTER"
             "CENTER" ""
  (if (not (tblsearch "layer" "DIM"))  ; 判断是否存在Dim层,无则创建。
    (command "layer" "n" "DIM" "")
  (if (not (tblsearch "STYLE" "mold"))
      (command "STYLE" "mold" "Tssdeng,hztxt" "0" "0.7" "0" "n" "n" "n")
      (setvar "TEXTSTYLE" "mold")
  (if (not (tblsearch "DIMSTYLE" "mold15"))
      (SETVAR "DIMZIN" 8)
      (setvar "DIMDEC" 2)              ; 精度
      (setvar "DIMASZ" 1.2)            ; 箭头大小
      (setvar "DIMADEC" 1)             ; 角度精度
      (setvar "DIMDLI" 1.5)            ; 尺寸线间距
      (setvar "DIMTXT" 1.5)            ; 文字高度
      (setvar "DIMGAP" 0.3)            ; 文字偏移
      (setvar "DIMTOH" 1)              ; 文字对齐ISO
      (setvar "DIMCLRD" 8)             ; 尺寸线 颜色
      (setvar "DIMCLRE" 8)
      (setvar "DIMEXO" 0)              ; 尺寸界线起点偏移
      (command "DIMTXSTY" "mold")
      (command "DIMSTYLE" "S" "mold15")
  (if (not (tblsearch "DIMSTYLE" "mold35"))
      (SETVAR "DIMZIN" 8)
      (setvar "DIMDEC" 3)              ; 精度
      (setvar "DIMTXT" 3.5)            ; 文字高度
      (setvar "DIMGAP" 0.4)            ; 文字偏移
      (setvar "DIMASZ" 2)              ; 箭头大小
      (command "DIMSTYLE" "S" "mold35")
  (if (not (tblsearch "DIMSTYLE" "mold70"))
      (SETVAR "DIMZIN" 8)
      (setvar "DIMTXT" 7.0)            ; 文字高度
      (command "DIMSTYLE" "S" "mold70")
  (command "DIMSTYLE" "r" "mold35")
  (setvar "cmdecho" 1)
GMT+8, 2025-12-17 21:17 , Processed in 0.164240 second(s), 18 queries , Gzip On.
